wvu(at)ameritel.net Guest
Posted: Mon Jul 17, 2006 7:43 pm Post subject: Static Ports |
I have a hard time keeping the static lines on the pop-rivet ports. Any suggestions?
Anh
#141
capsteve
Joined: 09 Jan 2006 Posts: 111 Location: NIAGARA FALLS NY
Posted: Mon Jul 17, 2006 8:10 pm Post subject: Static Ports |
I really like the static ports from cleaveland tool, worth the $$....i didn’t rivet them, but I used structural epoxy and its looks great…
Steve
40205
dlm46007(at)cox.net Guest
dmaib@me.com
Posted: Mon Jul 17, 2006 9:02 pm Post subject: Static Ports |
I have read some comments that seem to say that the Vans static port kit is actually very accurate in spite of being cheap and simple. Does anybody have any comparison with the Aircraft Spruce and other more sophisticated systems? I know they look way better, but am interested in performance.
David Maib
40559 tailcone
On Jul 17, 2006, at 11:24 PM, David McNeill wrote:
get some real static ports. See aircraft spruce http://www.aircraftspruce.com/catalog/inpages/staticports2.php. These will also take the nyflo fittings.
[quote]---
_________________ David Maib
RV-10 #40559
New Smyrna Beach, FL |
jhstarn(at)verizon.net Guest
Posted: Mon Jul 17, 2006 11:33 pm Post subject: Static Ports |
Will second that notion. I have responded many times before on the this subject. Contact me off list if you need or want help. Somewhere you have to turn the line 90 degrees to get it to the panel. I suggest using the ports with female threads & the 90 degree adaptor fittings that screw into them. Much more secure than "glued on" in a place that you can't visit/inspect/repair that easily. KABONG HR II, 280hrs plus. Do Not Archive
VHMUM(at)bigpond.com Guest
Posted: Mon Jul 17, 2006 11:55 pm Post subject: Static Ports |
I used epoxy on my 6 and have used on 10 as well.
Chris
Tim(at)MyRV10.com Guest
Posted: Tue Jul 18, 2006 3:22 am Post subject: Static Ports |
Anh, so far the responses are just like I'd say....probably just time to
get a good static port system. Best now before you paint, so you don't
have to drill your tailcone after painting. I have the Cleaveland.
I know some have questioned in the past which brands are accurate and
which have errors. So far, it looks like mine are accurate. I need
to fly the box to see if the precision is perfect, but they really
seem to be good right now. My guess is that perhaps people had
issues with various ones in the past on other airframes, but on the
-10 they don't have much of a problem.....the placement has more to
do with the reading than the port, would be my guess.
So anyway, as usual, the best fix is probably just digging through
the sofa for some more quarters. The nice thing about the ones
that I'm using is it has allowed me to use nice 1/4" ID Tygon tubing
that is real flexible and seals great with push-on fittings.
JOHN STARN wrote:
[quote] Will second that notion. I have responded many times before on the this
Not Archive
flysrv10(at)gmail.com Guest
Posted: Tue Jul 18, 2006 3:45 am Post subject: Static Ports |
Proseal around the tube and the pop rivet.
Rob Kermanj
On Jul 17, 2006, at 11:42 PM, DejaVu wrote:
| Quote: | I have a hard time keeping the static lines on the pop-rivet ports. Any suggestions?
Anh
#141
mike(at)learningplanet.co Guest
Posted: Tue Jul 18, 2006 6:51 am Post subject: Static Ports |
On my -9A I installed the Static kit from SafeAir1 and I am glad I did. When I had my pitot/static/transponder test done, the tech found no leaks and commented that the number one problem that he sees with RV avionics is the use of those pop rivets. He couldn't imagine why someone would spend so much money on an airplane and nice avionics only to attach it to a cheap and unreliable static source.
Anyways, I'm sure there are folks who use the pop rivets with success. But I will be going with the SafeAir1 kit for the -10.
By the way, I'll be up at Oshkosh all week, camping with the -9A in the homebuilt camping area.
Mike Schipper
RV-10 #40576 - Emp - www.rvten.com
RV-9A N63MS - Flying - www.my9a.com
On Jul 18, 2006, at 12:00 AM, David Maib wrote:
| Quote: | | I have read some comments that seem to say that the Vans static port kit is actually very accurate in spite of being cheap and simple. Does anybody have any comparison with the Aircraft Spruce and other more sophisticated systems? I know they look way better, but am interested in performance. |
Posted: Tue Jul 18, 2006 10:07 am Post subject: Static Ports |
There are thousands of RVs with Vans static kits. We never had a problem.
Chris
Posted: Tue Jul 18, 2006 10:59 am Post subject: Static Ports |
You obviously have not talked to ALL those who tried to use, didn't like the looks of, had to change, repair, re-attach and/or modify the 'cheapo" way.
"We never had a problem", ya'll must have a mouse in your pocket.
I haven't keep track over the years how many have looked over our set up at fly-ins, airshow, OSH etc & then asked for a parts list & how to install instructions.
It's all in what you want in a finished product, that's why it's called an "experimental" aircraft. To borrow from a Burger King slogan "You build it your way". KABONG 8*) HRII Do Not Archive
danbenua(at)yahoo.com Guest
Posted: Tue Jul 18, 2006 1:06 pm Post subject: Static Ports |
I installed fancy flush static ports in my RV-6A, and
they worked fine until it started raining. As water
droplets ran along the fuselage in flight, they wicked
into the static port holes and caused dramatic (~200')
altimeter and VSI gyrations. Since I was on an IMC
approach at the time, I felt that a fix was needed.
I solved it by drilling out the hole in each static
port, installing an LP4-3 pop rivet, and driving out
the mandrel; just like Van's suggested. The head of
the pop-rivet protruding above the skin surface is
just enough to keep the water drops away from the vent
hole.
On my RV-10 (not yet flying) I chose a compromise
solution. I installed the pop-rivet static port as
per plans, but on the inside of the tailcone behind
each port I riveted fuel tank drain flanges (available
from Van's). This allows for the installation of
threaded fittings (Nylo-Seal 269-N 04x02) that
transition to poly tubing (Poly-Flow 44-P). This
solution gives a secure connection and a proven port
profile; and a very low cost.
- Dan Benua
#40001
finish & fwf
| Quote: | I have read some comments that seem to say that the
Vans static port
cheap and simple.
better, but am
David Maib
40559 tailcone
Posted: Tue Jul 18, 2006 1:59 pm Post subject: Static Ports |
Ok your right Im wrong!
Dick Sipp
Posted: Tue Jul 18, 2006 7:13 pm Post subject: Static Ports |
I used the SafeAir1 pitot static kit as well. Very easy to install and a real time saver. All the normal fittings are included in the kit and so far all of the necessary conversion couplings to go from aluminum to SafeAir and from SafeAir lines to various components are available. With all the new avionics people are using there are more and more pitot static drops required I.E. AOA, TruTrak ADI, encoder, stby instruments, AHARS, etc. I "stacked" the T drop fittings on top of each other on a longer screw attached to the bottom flange of the subpanel. This created a compact pitot and stactic "manifold" for the various required "drops."
Dick Sipp
40065 finishing
