EnaudZ(at)aol.com Guest
Posted: Tue Jan 17, 2006 7:15 am Post subject: Overreving 582 |
Hello Everyone
We need help ,we have at our airport aman with a rans s7 w/582/3blade
warp
his problem is on climb out the engine (at WOT)runs at 6200 then revs to
Quote: | 6500
then back to 6200 a while then back up to > 6500 etc, etc. help!!!!!.
Duane zollinger
FS2 503
Rittman ,Ohio P.S. T.I.A.
| - The Matronics Kolb-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
Denny Rowe
Joined: 10 Jan 2006 Posts: 89 Location: Leechburg, PA
Posted: Tue Jan 17, 2006 10:45 am Post subject: Overreving 582 |
Sounds like an air leak to me.
Denny
vicsvinyl(at)verizon.net Guest
Posted: Tue Jan 17, 2006 2:27 pm Post subject: Overreving 582 |
How about Prop pitch? Remember I'm just an ex carpenter.
Vic P
MK3X
ulflyer(at)verizon.net Guest
Posted: Tue Jan 17, 2006 6:54 pm Post subject: Overreving 582 |
Is the problem being he is over reving (speeding) the engine or that
the engine rev's are "hunting", that is changing RPM without throttle
or load change.
jerb
At 09:14 AM 1/17/2006, you wrote:
Quote: |
Hello Everyone
warp
>6500
Duane zollinger
FS2 503
Earl Zimmerman
Joined: 13 Jan 2006 Posts: 35 Location: Elizabethtown, PA
Posted: Tue Jan 17, 2006 7:33 pm Post subject: Overreving 582 |
EnaudZ(at)aol.com wrote:
Quote: |
Hello Everyone
warp
>6500
Duane zollinger
FS2 503
I'm assuming that it has a C or E gearbox. If so the "driven" prop. gear
is not splined or keyed to the shaft. It uses a tapered cone sleeve to
tighten it to the shaft. I have heard of some of them slipping at full
power. You can usually hear the ratio of prop to engine speed change
like in the old days when the belt reduction started to slip.
~ Earl
Richard Pike
Joined: 09 Jan 2006 Posts: 1669 Location: Blountville, Tennessee
Posted: Tue Jan 17, 2006 8:41 pm Post subject: Overreving 582 |
Good idea Earl, the B box on my 582 also did that when it was new,
except it was the gear on the end of the crank that was slipping. Lapped
it in with some fine valve grinding compound and that fixed it.
Richard Pike
MKIII N420P (420ldPoops)
Earl & Mim Zimmerman wrote:
>Hello Everyone
>warp
>>6500
> Duane zollinger
>FS2 503
>do not archive
~ Earl
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
jbhart(at)onlyinternet.ne Guest
Posted: Wed Jan 18, 2006 5:36 am Post subject: Overreving 582 |
Denny
Denny Rowe
Posted: Wed Jan 18, 2006 6:14 am Post subject: Overreving 582 |
Jack has a point here, if the fuel pump is not keeping up with demand at
full throttle, the float bowel level could be dropping enough to lean the
mixture causing the engine to rev slightly. Between the lean burn being
hotter and lack of lubricating fuel oil mix this could lead to a seizure on
climb out. Not good.
Regardless I'll bet its one of the problems mentioned by Earl, Jack or
myself, please let us know what you find.
Denny
Jim Ballenger
Joined: 12 Jan 2006 Posts: 18 Location: Virginia Beach, Virginia
Posted: Wed Jan 18, 2006 1:48 pm Post subject: Overreving 582 |
All
I had a similar problem with my 582 in cruise rpm as it would search for a
steady rpm. It turned out to be a to lean issue. I put a larger jet in and
it cured the problem.
Jim Ballenger
MK III X 582
Virginia Beach, VA
EnaudZ(at)AOL.COM Guest
Posted: Thu Jan 19, 2006 3:07 pm Post subject: Overreving 582 |
Hello EARL
you solved the over rev problem thank you.
Denny Rowe
Posted: Thu Jan 19, 2006 4:36 pm Post subject: Overreving 582 |
That was the loose Crank shaft hub right?
Denny Rowe
Earl Zimmerman
Posted: Thu Jan 19, 2006 4:46 pm Post subject: Overreving 582 |
Quote: |
Hello EARL
I'm glad that I could point you in the right direction. Would you mind
telling us what you found and how you fixed it? Did you just tighten the
nut or did you have to replace the cone or use thread locker?? Which
model gearbox? This kind of information should be shared and archived.
~ Earl
