frank.hinde(at)hp.com Guest
Posted: Wed Jul 26, 2006 10:20 am Post subject: Antennas general |
Frank,
For the wingtip NAV, IIRC the coax shield is to be grounded with the shield approx where it ends and the foil begins.
For my marker beacon, I am using bulkhead fittings to penetrate the firewall so I am considering mine grounded to the SSFirewall.
I'm gonna use the 40" stripped coax on the bottom of my cowl too - along with another stripped length (gotta figure out the math) for my AM/FM/MP3 player.
When you're really finished and flying - come visit N06 Laurel, DE....
Ralph
Posted: Wed Jul 26, 2006 10:59 am Post subject: Antennas general |
Now there is an idea...I just passed my RG56 thru a grommet in the
firewall but a bulkhead fitting would take care of the grounding...I
have not fire sealed it yet so I might do the same thing...assuming
Radio Shack sells the fittings of course.
Thanks Ralph
Frank
brian
Joined: 02 Jan 2006 Posts: 643 Location: Sacramento, California, USA
Posted: Wed Jul 26, 2006 12:10 pm Post subject: Antennas general |
On Jul 26, 2006, at 12:58 PM, Hinde, Frank George (Corvallis) wrote:
(Corvallis)" <frank.hinde(at)hp.com>
On my Vans kit they provided a wingtip NAV antenna which is just a
strip of copper foil. Do not suggest how one is supposed to ground
it to
the airframe.
I assume one has to ground the coax braid to the wing somehow??
Also I intend to run my marker beacon antenna (40" lentgh of stripped
coax) in the bottom of my cowl. Assuming this will work do I need to
bond that coax to the firewall or similar?
Not really. A 50W transmitter shooting its signal at you using a
directional antenna when you are less than 2000' away does not
require much from the receiver and its antenna. The signal level is
so high that making a perfect antenna is not necessary.
Brian Lloyd 361 Catterline Way
brian-yak AT lloyd DOT com Folsom, CA 95630
— Antoine de Saint-Exupéry
_________________ Brian Lloyd
brian-yak at lloyd dot com
- Antoine de Saint-Exupery |
Posted: Wed Jul 26, 2006 2:26 pm Post subject: Antennas general |
They might - but digi-key does for sure.......
europa flugzeug fabrik
Joined: 13 Feb 2006 Posts: 65 Location: North Coast, USA
Posted: Wed Jul 26, 2006 3:58 pm Post subject: Re: Antennas general |
| brian wrote: | | A 50W transmitter shooting its signal at you using a directional antenna when you are less than 2000' away does not require much from the receiver and its antenna. |
I believe they’re as little as 2.5W, though as highly directional, the moral equivalent of higher power relative to like a COM. Perhaps you are referring to that.
Also, the sensitivity of the receiver isn’t good, maybe 200 times less sensitive than a COM. So, the antenna has to be reasonably good. I wonder if we could use wire or copper tape to fake an equivalent of a sled antenna. One end to shield, center wire about 10” down or wherever, but we need a ramp tester to tune it. Or rig it up in the car, and find a marker shed we can drive up close to. A coax monopole w/o ground plane as proposed will probably be OK.
Fred F.
nuckollsr(at)cox.net Guest
Posted: Thu Jul 27, 2006 5:03 am Post subject: Antennas general |
At 04:58 PM 7/26/2006 -0700, you wrote:
<n3eu(at)comcast.net>
referring to that.
Fred F.
Lets put some rough orders of magnitude numbers to
this discussion. Assuming 2.5 W transmitter driving
a corner reflector (lets assume 3db gain) for an
ERP of 5 watts, let's plug into:
http://www.megalithia.com/elect/fieldstr.html
With an ERP of .005 Kw and distance of .2 KM.
Leave the channel defaulted at CH44.
This calculator is for UHF frequencies the the
performance at 75 MHz would be only slightly different
due to tiny differences in path losses.
The calculator says we can expect a field strength
on the order of 80 dBuV at .2 Km above this marker
site.
Go to:
http://www.radioing.com/eengineer/rfcalc.html
and enter 80 (dBuV) before punching the box in the lower
right column for DbUv -> Volts conversion and we get:
0.01 volts, or 10,000 microvolts.
Marker beacon receiver sensitivity is on the order of
1500 uV in the LO SENS position and 200 uV in the
HI SENS position. So barring errors in data or logic
it seems that there's a LOT of head-roon for loss of
antenna efficiency.
I've had a number of builders in glass/epoxy airplanes
simply lay a 40" piece of wire out in the tailcone
and run a coax to the marker receiver report excellent
results.
But the bottom line is that what ever one installs that
departs from the installation instructions (hence departures
from the manufacturer's expectations) the installation should
be flight checked by overflying a marker beacon facility
at various altitudes. Returning to
Enter 1.5 KM into the distance box (5x higher than anything
we would expect to do in a real approach) and we get
62 dBuV field strength. Which converts to a potential
signal level of 1200 uV to a receiver in an IDEAL installation.
Hmmmm . . . one would probably not expect even the best of
installations to function at 5,000 AGL in LO sensitivity but
it should come back alive when you select the HI sensitivity.
A little bit of flight testing is all it takes to see how much
headroom your installation possesses. Data-in-hand trumps
un-quantified supposition every time. The above exercise suggests
that considerable degradation of gross antenna performance is
tolerable and worthy of further exploration.
sportav8r(at)aol.com Guest
Posted: Thu Jul 27, 2006 5:34 am Post subject: Antennas general |
While we're discussing dB's, I note that the installation instructions for my Garmin GMA 340 audio panel mention several times a feature provinding "10 times gain (20 dB)" for the entertainment channel input. I have labored all my life under the impression that 10dB was 10x gain, and 20 dB was 100x gain. It seems unlikely that the people who design this stuff professionally know more about decibels and power gain than a radio hobbyist does, so it's safe to assume I'm the one who is missing something. What gives?
Sorry to hijack an antenna thread for this, Bob. But I've just got to get this straight before I go nuts
-Bill B
Hopperdhh(at)aol.com Guest
Posted: Thu Jul 27, 2006 5:52 am Post subject: Antennas general |
In a message dated 7/27/2006 9:39:55 A.M. Eastern Daylight Time, sportav8r(at)aol.com writes:
| Quote: | While we're discussing dB's, I note that the installation instructions for my Garmin GMA 340 audio panel mention several times a feature provinding "10 times gain (20 dB)" for the entertainment channel input. I have labored all my life under the impression that 10dB was 10x gain, and 20 dB was 100x gain. It seems unlikely that the people who design this stuff professionally know more about decibels and power gain than a radio hobbyist does, so it's safe to assume I'm the one who is missing something. What gives?
-Bill B
Bill,
You are correct for POWER gain. For VOLTAGE gain Garmin is right.
Db=10 log (P1/P2)
Db=20 log (V1/V2)
Dan Hopper
K9WEK
RV-7A
Posted: Thu Jul 27, 2006 8:37 am Post subject: Antennas general |
At 09:58 AM 7/26/2006 -0700, you wrote:
strip of copper foil. Do not suggest how one is supposed to ground it to
the airframe.
How is the foil installed? Does it begin right at the edge of
the tip fairing such that transition from coax to antenna is
closely located to metallic portions of the wing? If so, ground
the coax shield to the nearest practical wing-metal.
| Quote: | Also I intend to run my marker beacon antenna (40" lentgh of stripped
Here's where having access to a piece of test equipment is
a real help! An MFJ-259 antenna analyzer (See:
http://www.mfjenterprises.com/products.php?prodid=MFJ-259B )
would allow you to run say 10" of straight wire, coil 20"
or so around a piece of plastic or wooden dowel, then extend
the remainder out straight for an overall length of 20"
or so. Then use the antenna analyzer to look at the characteristics
of this shortened antenna. You'll find that it resonates lower
than 75 Mhz. Trim the 10" extension beyond the coil to bring
the antenna up to 75 Mhz then glass over what remains.
Posted: Thu Jul 27, 2006 11:25 am Post subject: Antennas general |
Aw, shoot! Make that P=E^2/R. I knew better than that. Hit "send" too quickly.
-Stormy
Ah, the old P=E^2*R ploy. I see now. Thanks.
Dale Ensing
Joined: 11 Jan 2006 Posts: 524 Location: Aero Plantation Weddington NC
Posted: Thu Jul 27, 2006 3:42 pm Post subject: Antennas general |
Are you sure it is not E=mc2 ;<)
-Stormy
DO NOT ARCHIEVE |
_________________ Dale Ensing
RV-6A
Aero Plantation
Weddington NC |
brian
Posted: Fri Jul 28, 2006 5:00 am Post subject: Antennas general |
gives?
10dB is a ten-fold increase in *power*.
Since power is V^2/R if you increase voltage by a factor of 10 you
increase power by a factor of 100 (10x10). A 100-fold increase in
power is 20dB.
A gain of 10 (voltage increased ten times) results in a power gain of
20dB.
altoq(at)cebridge.net Guest
Posted: Fri Jul 28, 2006 11:08 am Post subject: Antennas general |
NOT RV Related
Just as a point of intrest, if you want V˛2/R, turn Number Lock on, hold
down Alt key and type 0178 on the Number Pad. When you release the Alt key
the ˛ pops up. Degrees (X°) is 0176 and (Xł) is 0179. This is done through
Charicter Map and there are many more. Check it out in System Tools. It is
an automatic install for Windows XP but you might have to install it in
98/SE. Its on the Windows Disk.
John D.
| Quote: | Since power is V^2/R if you increase voltage by a factor of 10 you
increase power by a factor of 100 (10x10). A 100-fold increase in power
is 20dB.
