jhasbrouck(at)woh.rr.com Guest
Posted: Wed Jul 26, 2006 4:13 pm Post subject: Slo-build fuse. gotcha |
For those of us with the slo-build fuse. I've either found a gotcha or am
now openly admitting my stupidity. Look at page 26-1 for the parts I'm
about to reference and this will be make sense. I did not dimple the 3/32
holes in the F-1015A outboard seat rib before I finished construction of
this section. The plans tell you to dimple the 3/32 holes in the F-1018
outboard rear seat rib but make no mention ( here's the possible stupidity
part) of the F-1015A unless I missed it. Which means that, now that the
side skins are ready for dimpling, I have to go back and dimple these bad
boys while they are firmly riveted to the rest of the structure and the
bottom skins. Not impossible but a real PITA. Also, you will notice
nutplates on the bottom skin under the F-1015A. These will have to come off
for me to get to some of the holes in the F-1015 and to final rivet. So
here's my suggestion: dimple the 3/32 holes in the F-1015A L & R that
correspond to rivets in the side skin before you do the final assembly in
section 26 and hold off on the nutplates on the bottom skin shown on 26-7
Fig. #1 untill side skins are riveted in place. What's killing me is that I
looked at this problem when I was in this section but moved on without
addressing it. And if you find the instruction to dimple the F-1015A
somewhere in the plans please tell me where so I can have it tatooed on my
butt! John Hasbrouck # 40264 Wishing I was in OSH!!!
ericmpmail-rv10(at)yahoo. Guest
Posted: Wed Jul 26, 2006 6:27 pm Post subject: Slo-build fuse. gotcha |
Thanks for the reminder, I'm sure you saved at least
one builder. This was discussed online about 6 months
ago and it was timely for me as someone's comments
saved me from making the same mistake.
It sure would be nice if they issued plan revisions to
make a great set of plans even better....
Eric (Just arrived at Oshkosh and hanging out in the U
of Wisc dorms with free internet)
--- John Hasbrouck <jhasbrouck(at)woh.rr.com> wrote:
holes in the F-1018
to final rivet. So
F-1015A L & R that
dimple the F-1015A
OSH!!!
browse
Subscriptions page,
FAQ,
Admin.
