lwinger
Posted: Fri Jul 28, 2006 6:47 am Post subject: Stabilizer end rib cutout position for 601XL |
I'm fabricating 6T1-1 and have a question about the 18mm cutout at the back of the rib. While the plans say "2 req'd" (not "1L+1R"), it appears that I don't make two identical ribs. Rather, I presume that I should make one rib with the cutout as shown, and the other rib with it on the opposite side. Is that correct?
_________________ Larry Winger
Tustin, CA
Plans building 601XL/650 with Corvair
Installing fuel system
www.mykitlog.com/lwinger |
admin(at)arachnidrobotics Guest
Posted: Fri Jul 28, 2006 7:25 am Post subject: Stabilizer end rib cutout position for 601XL |
You're right Larry. You're going to cut two identical ribs. Then
you're going to form them in OPPOSITE directions. The end result is
that you'll have one left and one right rib. If you're like many who
don't like so see the mill writing on the outside of their parts, layout
two ribs opposite of each other. Sounds like your project is coming
along. Post some pics if you get a chance.
Tom Henderson
601XL Fusealge
lwinger wrote:
Larry Winger
Tustin, CA
601XL #6493 from scratch
Building stabilizer & rudder parts
http://forums.matronics.com/viewtopic.php?p=50307#50307
