Cold weather
kirk(at)mninter.net
PostPosted: Tue Jan 17, 2006 7:36 pm    Post subject: Cold weather Reply with quote
For those of you who fly with a Rotax 912 in cold weather (20 to -20 degrees F), what are your cylinder head temps, and oil temps? Do you use a radiator flap? Does anyone use a cowling blanket between flights?
Kirk Martenson
Classic IV Rotax 912
kingjohne(at)adelphia.net
PostPosted: Thu Jan 19, 2006 7:28 pm    Post subject: Cold weather Reply with quote
Kirk,
I fly in the winter, but the temperatures in Northern Virginia are not
that cold. I have a cockpit controlled cowl flap on my radiator and
sliding shutters on my oil cooler so I can keep the engine and oil
temperatures where I want to maintain them. While hangared in the
winter I keep a 40 watt bulb under the cowl and a blanket over the
cowl. I have no problems starting the 912/ULS engine.
John King
Warrenton, VA
Kirk Martenson
