coop85(at)bellsouth.net Guest
Posted: Tue Jul 25, 2006 1:32 am Post subject: Grand Rapids Wiring |
I have the GRT EFIS and EIS and can’t seem to brake the code on wiring the fuel level wiring. As luck would have it, all the folks are at Oshkosh and not available for questions.
I suspect that I need to use the 4.8V source wire but I can’t find how to employ it in the instructions. Does it just get tied to the wire going the tank level sensor?
Also, when I ran the engine, my RPM showed 0. I have the signal wire tied to the digital RPM signal from the Lightspeed output and the EIS Tach is set to ‘0’ for 6 cyl Lycoming.
If anyone has any experience with this I’d sure appreciate any and all guidance.
Marcus
Desperately close and yet so far it seems
n142ds(at)gmail.com Guest
Posted: Tue Jul 25, 2006 2:50 pm Post subject: Grand Rapids Wiring |
Contact me off line... it's a piece of cake.
On 7/25/06, Marcus Cooper <coop85(at)bellsouth.net (coop85(at)bellsouth.net)> wrote: | Quote: |
I have the GRT EFIS and EIS and can't seem to brake the code on wiring the fuel level wiring. As luck would have it, all the folks are at Oshkosh and not available for questions.
I suspect that I need to use the 4.8V source wire but I can't find how to employ it in the instructions. Does it just get tied to the wire going the tank level sensor?
Also, when I ran the engine, my RPM showed 0. I have the signal wire tied to the digital RPM signal from the Lightspeed output and the EIS Tach is set to '0' for 6 cyl Lycoming.
If anyone has any experience with this I'd sure appreciate any and all guidance.
Marcus
David W. Schaefer
RV-6A N142DS "Geek One"
www.n142ds.com
Tim(at)MyRV10.com Guest
Posted: Sat Jul 29, 2006 3:44 pm Post subject: Grand Rapids Wiring |
Marcus,
Sorry I couldn't reply sooner. Here's a file that you might want:
http://www.myrv10.com/files/GRT/GRT_Probes_Install.tif
It's a multi-page .tif and shows how to hook up most of the
special probes, including that 4.8 V. source.
Not sure what you might have going on the RPM readout though. I
have mine directly connected to the Lightspeed from the input
to the EIS 6000. Make sure Tack P/R is 3. Giving a Zero
readout makes me wonder if there's not a mis-wiring issue
though, or perhaps if you're grounding the keyswitch option
wire on the Lightspeed and it's not firing. I only took the
tach input from the lightspeed and just guess and check
by ear on the mag side. So when I turn the key to turn off
the lightspeed, my RPM readout drops to zero. You can hear
when going to ground the mag that the lightspeed idles it
at a higher RPM. The most important thing is that the
engine sounds like it's not losing lots of RPM and runs
smooth on the mag, so I didn't care to do the gymnastics
of hooking it to both.
Just FYI, here's an old (now unverified recently) list of the
settings in my EIS6000. You may find it handy.
Aux1 ManP
Aux2 LEFT
Aux3 RITE
Aux4 Fpsi
Aux5 AMPS
Aux6
Units IFG
FC1 0
FC2 0
FloCal 200
FloCalR 0
Tach P/R 3
Peak 10
Max Fuel 60
HRS 29.8
Tim-RPM 0
AspdLo 0
AspdHI 0
TachLo 0
TachHi 0
1SF 198
1OFF 64
2SF 44
2OFF 119
3SF 47
3OFF 127
4SF 63
4OFF 47
5SF 93
5OFF 177
6SF 0
6OFF 0
I/D DIIDII
AltCor 128
ID1 Tach
IP1 1
ID2 Ax1
1P2 6
1D3 Ax2
1P3 10
1D4 CHH
1P4 14
1D5 OT
1P5 17
1D6 /
1P6 20
1D7 OP
1P7 21
1D8 Flow
1P8 24
1D9 EGH
1P9 29
1D10 OFF
1P10 0
1D11 OFF
1P11 0
1D12 OFF
1P12 0
2D1 Tach
2P1 1
1D2 Crb
2P2 6
2D3 Oat
2P3 10
2D4 CHH
2P4 14
2D5 OT
2P5 17
2D6 /
2P6 20
2D7 OP
2P7 21
2D8 Volt
2P8 24
2D9 EGH
2P9 29
2D10 Off
2P10 0
2D11 Off
2P11 0
2D12 Off
2P12 0
GD1 CHH
GP1 9
GD2 EGH
GP2 13
GD3 Tach
GP3 17
GD4 Off
GP4 0
GD5 Ax1
GP5 23
GD6 Flow
GP6 29
GD7 Off
GP7 0
GD8 Off
GP8 0
GD9 Off
GP9 0
Marcus Cooper wrote:
| Quote: | I have the GRT EFIS and EIS and can’t seem to brake the code on wiring
guidance.
Marcus
