jrdial(at)hal-pc.org Guest
Posted: Wed Aug 02, 2006 12:34 pm Post subject: Vacuum pump fitting |
I have an RV-6 without a vacuum system but a friend that rents hanger space from me is installing a new 0-360 in his RV6A and the fitting for the inlet side (suction) of the vacuum pump appears that it is going to be very close to the motor mount. Question is this normal or is there a different fitting people that have vacuum system and 0-360 in RV6s use?
You can answer direct to my email.
Dick Dial
N89DD
DO NOT ARCHIVE
FLYaDIVE(at)aol.com Guest
Posted: Wed Aug 02, 2006 1:35 pm Post subject: Vacuum pump fitting |
In a message dated 8/2/06 4:37:02 PM Eastern Daylight Time, jrdial(at)hal-pc.org
writes:
| Quote: | I have an RV-6 without a vacuum system but a friend that
RV6s use?
Dick Dial
N89DD
Dick:
You have to be a bit more specific. Can you answer the following questions:
1 - Which engine mount are you referring to?
2 - Which fittings are you referring to? Check out ACS Catalog, and give me
a part number. They are interchangeable and different fittings are available.
My general response is:
As long as you are using a standard store bought engine mount (dynalfocal)
the vacuum Pump will fit.
You are talking about a DRY Vacuum Pump?
The intake and exhaust fittings can be varied in shape and location to have
things fit. DO NOT OVER TIGHTEN!
The ONLY problem I can foresee is the left lower NUT! You must have the
special wrench to tighten that one.
The RV-6A and RV-6 I fly both have dry vacuum pumps and fit is NOT a problem.
Both have 360's an O-360 and an IO-360 respectively.
Super Cautionary Note: I know the installation instructions say do not use
Teflon Tape. I am a bit scared to recommend it, because, quite honestly most
people do not know how to use it properly. There is a trick in its safe use.
But Teflon tape may be required if when alignment is accomplished the fitting
is still loose.
Barry
"Chop'd Liver"
"Show them the first time, correct them the second time, kick them the third
time."
Yamashiada
Posted: Wed Aug 02, 2006 4:01 pm Post subject: Vacuum pump fitting |
The vacuum pump is on the engine but will have to be removed to
install the inlet fitting which is no problem but it sure looks like the
90 degree inlet fitting is going to hit the dynafocal mount.
DO NOT ARCHIVE
Posted: Wed Aug 02, 2006 6:58 pm Post subject: Vacuum pump fitting |
Dick:
would recommend that you:
1 - Remove the pump from the engine.
2 -Set up the input fitting in a direction that will not hit the dynafocal
mount.
3 - Reinstall the pump to the engine.
As mentioned before the only difficult part is that you will need the special
vacuum pump wrench.
Barry
"Chop'd Liver"
third
time."
Yamashiada
DO NOT ARCHIVE
