decompression sickness and narcosis (was: AYS-bound)
brian
PostPosted: Tue Jan 17, 2006 9:51 pm    Post subject: decompression sickness and narcosis (was: AYS-bound) Reply with quote
Roger Kemp wrote:
Brian,
Best check again on the nitrogen Narcosis thing at altitude It happens.
It is called decompression sickness.
Go read your books again. Nitrogen narcosis is a malady that occurs when
too much N2 is dissolved in the tissues, especially the tissues of the
nervous system. The symptoms are similar to drunkenness but
hallucination is not uncommon. Divers who are "narc'd" have been known
to offer their regulator mouthpiece to passing fish. When N2 is
dissolved in the tissues it isn't coming out in bubbles.
When the body then decompresses again if it is done too quickly, the N2
can come out of the tissue in bubbles. These tend to lodge in the joints
and cause pain which often causes the victim to contort him/herself in
an attempt to relieve the pain, hence the term "the bends". The official
name for this malady is decompression sickness. This is a completely
different malady from nitrogen narcosis. Both involve nitrogen, both
involve pressure change, but the pathology is different as are the symptoms.
The treatment for it is recompression in a dive chamber.
The treatment for decompression sickness is to increase the pressure
again so that the N2 goes back into solution in the blood and tissues.
The prevention of decompression sickness is to reduce the pressure
gradually so that the excess N2 in the tissues can stay in solution and
move into the bloodstream where it can move to the lungs and be exhaled.
I have had to fly two military aviators to the chamber
one at Brooks, AFB and the other was at Beale AFB. Both had to be flown
with the cabin pressurized to sea level because of the risk of worsening
the decompression sickness. One of those pilots was my Squadron cc. He had
a gradual cabin pressure leak due to a slow leaking canopy seal.
Had he been diving? Remember, the pressure change going from sea level
to FL250 is less than the pressure change from the surface to 30 feet
underwater. I suppose it is possible for someone to get decompression
sickness loss of cabin pressure but a slow leak is unlikely to cause the
problem. I am not saying it can't happen but I am skeptical unless there
was some other mechanism acting to raise the level of N2 in the tissue.
Living at sea level is not likely to cause enough N2 to dissolve in the
blood to cause the bends to happen at FL250, especially if the pressure
drops gradually.
There are two ways to get the "Bends." One is from decompression and the
other is from compression.
Sorry, no. The Bends occur *only* on decompression. Compression just
causes more N2 to dissolve in the tissues. If the person is suffering
from The Bends recomressing him/her causes the N2 bubbles to go back
into solution. Once that happens you can begin slow decompression thus
allowing the N2 to slowly and safely move from the tissue to the blood
to the lungs and then be exhaled.
In either case, N2 comes out of solution in blood.
No, it doesn't. It *only* does that on decompression, hence the name
It coleses into gas bubbles in the tissue. Most commonly in an
injured joint. It also can happen in the spinal cord, brain (neurological
nitrogen narcosis), and the pulmonary tree. (the chokes). That is putting
it in simple terms.
You are describing only decompression sickness. You also called it
nitrogen narcosis which it isn't. Now nitrogen narcosis does happen when
you compress the body in the presence of N2. The greater the pressure,
the greater the symptoms of narcosis.
This is why divers use special breathing gasses that reduce or eliminate
the N2 in the breathing mix (heliox or nitrox) -- so that they are less
likely to experience narcosis while down and less likely to experience
The Bends upon ascending.
In otherwords, every time you take that unpressurised twin above FL 180,
you are at risk for for developing the "bends".
Any time you reduce the pressure on the body there is some chance of
developing decompression sickness. OTOH, the chance is very, very,
*VERY* small for people living at sea level or above who don't dive and
smaller still if the pressure change is gradual, i.e. standard rates of
ascent and not explosive decompression. I think if you go back and
research this you will find that this is an *extremely* rare event.
As a pilot who spent three years operating in the Virgin Islands who
dives and flies, I am *VERY* aware of the dangers from rapid pressure
changes and of going directly from a dive to a flight in an airplane.
For safety we use a rule of thumb of 24 hours between a decompression
dive to a flight because we know that even after a successful and safe
decompression dive, the tissues are still saturated to a higher level of
N2 than someone who has not been diving. The extra 24 hours allows the
body to come back to equilibrium before flying. My rule of thumb is
that, if you have been diving today, we don't fly until tomorrow.
So, yeah, I have some idea how all this works. The threat is vanishingly
small compared to what you are implying unless you have been diving and
then the threat is very real.
And nitrogen narcosis is NOT decompression sickness.
Brian Lloyd 2243 Cattle Dr.
brian-yak at lloyd dot com Folsom, CA 95630
- Antoine de Saint-Exupery
Brian Lloyd
brian
PostPosted: Tue Jan 17, 2006 10:18 pm    Post subject: decompression sickness and narcosis (was: AYS-bound) Reply with quote
But don't take my word for it. Here is a really good article on what
nitrogen narcosis is.
http://en.wikipedia.org/wiki/Nitrogen_narcosis
Brian Lloyd
cjpilot710(at)aol.com
PostPosted: Wed Jan 18, 2006 5:27 am    Post subject: decompression sickness and narcosis (was: AYS-bound) Reply with quote
Frankly I don't see any difference except by degree.
You takeoff and go up - - you decompress.
You come down to land  - -  you compress.
You jump in the water and go down - -  you compress.
You (hopefully) bob to the surface - - you decompress.
Now you can never go deeper (there is a bottom) than you go high (a vacuum mean decompress right?  Boy, I bet that would hurt ).
But water is thicker than air, sooooooo it would have more effect per foot than air.
But how fast you go up in the air would have the same effect as if you went up to fast in water?  So a guy is sitting in a rocket is going to have the same effect on him as a guy coming up from the bottom of the ocean?
Hmmmmmmmmmmmmmmm
Gee I'm being to see what that old fart ment: "If God want man to swim He'd given him fins and he were suppose to fly He'd given him feathers.  Dearn foolishness!"
FD44- CAVU, brisk breeze from the NW, 55 F on the patio.
Jim " Pappy" Goolsby
viperdoc(at)mindspring.co
PostPosted: Wed Jan 18, 2006 7:11 am    Post subject: decompression sickness and narcosis (was: AYS-bound) Reply with quote
Well Pappy, in your infinite wisdom you have boiled the issue of altitude verses diving decompression sickness down to its essence. Brilliant! As I was prepared to condense the 1st 8 chapters of Fundamentals of Aerospace Medicine Third Edition, Roy L. DeHart  M.D. MPH, M.S.I.A., pp.1-161, Diving Medicine Second Edition, Alfred A. Bove, M.D. and Jefferson C. Davis, M.D., pp. 5-47, The Society of United States Air Force Flight Surgeons Check List,revised biannually by the USAFSAM residents- 5th edition, pp 83-85 (the down and dirty version) for a discussion of decompression sickness Type I and Type II. But, Pappy since you so eloquently boiled this topic down to its essence, I will refrain from discussions of partial pressures of nitrogen, water, oxygen, carbon dioxide, and inert gasses at 1/2 ATA, 1/4 ATA, 0.10 ATA, 1 ATA, 2 ATA, 3 ATA, and 4 ATA. These all being common altitudes and feet of sea water that man flying and diving are exposed to. Brian will only claim to know more.
Dogmatic Viperdoc
Roger W. Kemp M.D.
Col. M.C., CFS
State Air Surgeon
HQ ALANG
Senior Aeromedical Examiner -FAA
Boarded in Anesthesia and Pain Management.
With a whole lot of alphebet following my name down.
brian
PostPosted: Wed Jan 18, 2006 9:32 am    Post subject: decompression sickness and narcosis (was: AYS-bound) Reply with quote
_Fundamentals of Aerospace Medicine Third Edition,_ Roy L. DeHart M.D.
MPH, M.S.I.A., pp.1-161, _Diving Medicine_ Second Edition, Alfred A.
Bove, M.D. and Jefferson C. Davis, M.D., pp. 5-47, _The Society of
United States Air Force Flight Surgeons Check List_,revised biannually
I don't claim to know more. But I do know when I am right. When I am not
sure I look it up. When it is not a topic I have studied I let someone
else speak in the hope that I will learn something.
That you are an MD with a whole alphabet behind your name does not make
you automatically correct and/or immune from making mistakes. But you
made an error. You then compounded that error when you argue about
correcting your error.
You know what Doc? I don't think I am either smarter or more
knowledgeable than you are. You don't manage to become an MD by being an
idiot. Given that you have been trained far more than I have in this
area I would expect you would have much more knowledge than I. But I
make it a point to know a fair bit about the things that I do. I try to
ensure that the information I have and that I give to my students (in
many areas) is correct. If I discover that I am wrong I go back and make
sure that I correct that information.
This is actually kind of scary. There are probably people who base
life-critical decisions on what you tell them. I now see that, when
faced with evidence that you have made a mistake, rather than saying,
"gee, you're right and I will correct the information," you go off and
try to blow smoke up everyone's ass. You will belittle the source of the
correct information in an attempt to get people to ignore the source
rather than ensure that the others around you have the correct
information. Yup, that is just plain ol' f----- scary.
And Pappy is right about it all being about pressure. It is just that
the devil is in the details. Albert Einstein one put it very succinctly
when he said, "Things should be made as simple as possible -- and no
simpler."
Dogmatic Viperdoc
Roger W. Kemp M.D.
Col. M.C., CFS
State Air Surgeon
HQ ALANG
Brian Lloyd
Gadfly
Annoying son-of-a-bitch
Asshole
Plain ol' guy with no alphabet after his name
Ordinary pilot
Ordinary CFI
-- but right
Brian Lloyd
Ernie
PostPosted: Wed Jan 18, 2006 10:56 am    Post subject: decompression sickness and narcosis (was: AYS-bound) Reply with quote
We call it being "Narced" in diving circles. Diving physiology 101.
You go deep, compress, and nitrogen disolves into your tissues, and
you get into a druken like state due to factors beyond my knowledge.
Decompression sickeness also called the bends, is from rapid
de-compression and nitrogen quickly coming out of its soluable state
and back into a gas in your arteries, shake a can of Coke and open,
same thing occurs except its CO2 doing its thing. Those bubbles will
can cause pain or even death due to brain embolisms.
Being narced and the bends are 2 different things and happen at 2 ends
of the spectrum. The only way you would get narced at altitude is if
you were at 90,000 ft and dropped to 20,000 in about 5 seconds, but
getting narced would be the least of your worries.
We have dive computers and tables that we follow which tells us how
many hours we have to wait before acending to any altitude depending
on our dive profile, in order to avoid the bends.
Ernie
PostPosted: Wed Jan 18, 2006 12:04 pm    Post subject: decompression sickness and narcosis (was: AYS-bound) Reply with quote
Brian,
You are right Narcosis is a malady of descent generally below 150 feet
ocean water. I wrote wrong the term when I was speaking of decompression.
Both are related to Nitrogen going into and out of solution in the blood
and tissue.
My first statement about pre-breathing 100% O2 prior to ascending to an
unpressurized altitude was in reference (inferred at the time) to
decreasing the risk of altitude decompression sickness. For that you
asserted that you can only get decompression sickness from diving. And
there you are also wrong. I am wrong for saying Nitrogen Narcosis and you
are wrong for asserting that decompression only comes from ascending from a
compression dive.
The symptoms of Nitrogen Narcosis and Neurological Decompression sickness
can be strikingly similar. One is from descent and the effect of an
increased partial pressure of Nitrogen and other inert gases in
neurological tissue causing mental disorientation. Neurological
Decompression is nitrogen bubbles forming emboli after coming out of
solution as one ascends either from a depth of sea water or from sea level
to altitude. In each case the the common thread is that the the pressure
decreased after the diver or the aviator was subjected to an increased
atmospheric pressure.
An aviator climbing from 1 ATA at sea level to 1/2 ATA at 18000 ft or 1/4
ATA at 33500ft unpressurized is at an increased risk for nitrogen coming
out of solution and forming "bubbles". The same for the diver that was at 4
ATA ~ 100 feet of sea water (fresh water also) and ascending to the surface
without percautionary decompression stops (not that is always protective
either). Yes, bottom time does influence the risk of developing the
"bends". As does other factors such as dehydration, fatigue, exercise at
depth or exercise prior to diving.
Nitrogen Narcosis is from the increased nitrogen in solution disrupting the
electrical potential transfer across the pre and post synaptic cleft of the
CNS. This most likely being in the Reticular Activating system and the
Cortical mantle. It follows the Meyer-Overton hypothesis that states "all
gaseous or volatile substances induce narcosis if they penetrate the lipids
of the cell wall in a definate molar concentraion that is characaristic for
each type of animal tissue aand approximately the same for all narcotics."
That is measured by the mean alveolar concentration (MAC) of the anesthetic
agent. The measure of an anesthetic concentration of an inert gas is the
concentration of the gas at which only 50% of rats will respond to pinching
their tail with a ring forcep. The so called MAC 50. So that is the theory
behind why we can give you an inhaled anesthetic at a concentration
inspired greater than sea level concentration and induce amnesia with
sedation for surgery.
We are comparing Apples and Oranges here.
Sorry Brian for mis-stating Narcosis instead of altitude decompression last
night at 11:20.
Doc
[Original Message]
To: <yak-list(at)matronics.com>
Date: 1/17/2006 11:51:15 PM
Subject: decompression sickness and narcosis (was: AYS-bound)
Roger Kemp wrote:
> Brian,
happens.
symptoms.
had
drops gradually.
the
(neurological
putting
> it in simple terms.
brian
PostPosted: Wed Jan 18, 2006 12:12 pm    Post subject: decompression sickness and narcosis (was: AYS-bound) Reply with quote
And if you were at 90,000' pressure altitude you would already be dead.
Even then it wouldn't happen. It requires a partial pressure of N2 at
about 3 BAR before you start getting enough N2 in your system to
interfere with normal nervous system operation. Nitrogen Narcosis can
only happen when the pressure exceeds that of being 100' deep
underwater. It is not going to happen anywhere on or off Earth when you
are in the atmosphere. Period.
Nitrogen Narcosis comes from the total amount of N2 present in the blood
and tissues. Decompression sickness comes from a too-rapid change in
pressure during ascent/decompression. The one time I would really worry
about decompression sickness in an airplane is during explosive
decompression or right after a dive.
You know, I never paid attention to see if the dive computer continues
to do its thing in an aircraft and give you a decompression stop. I
suppose there is no reason why it couldn't. SMOP (small matter of
programming).
Brian Lloyd
Ernie
PostPosted: Wed Jan 18, 2006 12:28 pm    Post subject: decompression sickness and narcosis (was: AYS-bound) Reply with quote
I have 2 diver computers that I use, they both have (I think, since I
havent used them in 2 years) a mode which you can call up that says
"OK to fly" when you've spent enough time out of the water. Same
algoritm which tells you when you can dive again.
If I remember correctly from Dive school, the dive tables also had
some basic method for determining how much time must lapse before
flying.
Also, the fernaderstand coupling to the finnigan motor spignads, will
de-cobobulate when administered in the presence of sinous friggle
dangle near the copious osmobrosis, causing increased cluster bumpkins
over the entire swaggle noodlefrapses region..
Ernie
PostPosted: Wed Jan 18, 2006 12:38 pm    Post subject: decompression sickness and narcosis (was: AYS-bound) Reply with quote
Do you know the first sign of rapid decompression?
You  Fart  like you would not believe.  Just hope its dry.
Pappy
PostPosted: Wed Jan 18, 2006 12:42 pm    Post subject: decompression sickness and narcosis (was: AYS-bound) Reply with quote
And Now Ernie you are a bonified Meyer - Overton expert!
Doc
[Original Message]
Date: 1/18/2006 2:28:14 PM
Subject: Re: decompression sickness and narcosis (was:
AYS-bound)
flying.
disrupting the
the
lipids
for
anesthetic
pinching
Ernie
brian
PostPosted: Wed Jan 18, 2006 1:27 pm    Post subject: decompression sickness and narcosis (was: AYS-bound) Reply with quote
Roger Kemp wrote:
Brian,
and tissue.
compression dive.
Hmm, I just went back and reread what I wrote. I think I made it pretty
clear that any time you have a rapid decrease in pressure, whether
ascending from a dive or ascending into the air, you can experience
decompression sickness. What I was trying to assert is that it is very
unlikely in an aircraft and much more likely from a dive. In fact, here
is what I did say:
"Any time you reduce the pressure on the body there is some chance of
research this you will find that this is an *extremely* rare event."
So, no, I did not assert that decompression sickness only comes from
diving. I did assert it is very difficult to make it happen while flying.
In any of the unpressurized aircraft we fly it is almost impossible to
get a change in pressure that is sufficiently rapid to invoke
decompression sickness. Going up right after a dive so that there is
more N2 in the tissues might cause it tho'.
And a rapid decompression from an 8,000' cabin to a 35,000' cabin might
do it. That is why I made the comment about explosive decompression.
Right, that is decompression sickness.
The rate of ascent is a key part of that. We change pressure all the
time when we fly. When was the last time you heard of a person in an
unpressurized aircraft experiencing decompression sickness when that
person had not been diving prior to flying? I have never known of a case
but I don't have that much exposure.
As an AME and (I presume) flight surgeon, you probably have a lot more
exposure to that sort of thing. Still, without explosive decomp and
without some prior activity to increase the N2 saturation, how many
cases of decomp sickness have occurred? I hold that it occurs so
infrequently that it is not worth worrying about.
Bottom time influences it a lot. It has more effect than all the other
factors you mention. It takes time for the N2 to dissolve in the blood
and then move to the tissues. The longer you are under the greater
partial pressure of N2, the closer you get to equilibrium and the longer
it will take to reach equilibrium again at a lower pressure. That
process can only proceed so fast and any attempt to make it go faster
results in the N2 coming out of solution in gaseous form (bubbles).
Those bubbles hurt.
agent.
I am familiar with that. The problem is finding inert gasses that have
the effect at partial pressures less than 1 atmosphere. Xenon actually
works pretty well but it is too expensive to use for that purpose.
That is all well and good but I wasn't particularly interested in
anesthetizing rats with inert gasses. (Sorry, I couldn't resist.)
BTW, my research experience with blood gasses was working with dogs, not
rats. I worked on a research project to develop a system to
automatically determine blood gas concentrations and then make the data
immediately available as part of a patient monitoring system. Writing
the software and building the dedicated microprocessor hardware for that
project was one of the ways I worked my way through college in the '70s.
We used dogs as research subjects. I am sure that nowadays I would be
drawn and quartered by some PETA enthusiast for even admitting I had
something to do with killing dogs for research purposes.
(We took dogs slated for euthanasia at the pound and performed various
tests on cardiopulmonary function. The dogs were treated kindly and
properly anesthetized prior to operating on them. When we had finished
gathering our data they were then euthenized, which is a nice word for
"killed". I did learn a LOT about cardiopulmonary function from that job
tho'.)
But I digress.
Agreed.
night at 11:20.
Right on bro'. It happens. We all make mistakes. The important thing is
to make sure we then get the proper information into people's hands lest
they make erroneous decisions based on improper information. We already
have to make decisions based on insufficient information (as in deciding
what do to in an off-airport landing). Bad information just compounds
the problem.
You get to buy the first round. I will buy the second. Wink
Darn, still no alphabet soup after my name and I am not old enough yet
to exchange "curmudgeon" for "asshole".
Brian Lloyd
PostPosted: Wed Jan 18, 2006 1:30 pm    Post subject: decompression sickness and narcosis (was: AYS-bound) Reply with quote
Pappy,
That is why you wear a brown fight suit so when you release that wet trapped gas, it does not show up as well!
Doc
brian
PostPosted: Wed Jan 18, 2006 1:33 pm    Post subject: decompression sickness and narcosis (was: AYS-bound) Reply with quote
cjpilot710(at)aol.com wrote:
*/Do you know the first sign of rapid decompression?/*
*/You Fart like you would not believe. Just hope its dry./*
Yeah, that was the worst thing about taking off your mask in the
hypobaric chamber to experience the effects of hypoxia. Everyone had
farted their asses off and the chamber stunk big time.
BTW, if you haven't taken a 'chamber ride' you should. Seeing what it is
like to experience pressure breathing O2 at 42,000' and hypoxia at
25,000' is good experience.
Brian Lloyd
talew(at)bellsouth.net
PostPosted: Wed Jan 18, 2006 3:36 pm    Post subject: decompression sickness and narcosis (was: AYS-bound) Reply with quote
Pappy,
My older captains taught me to never count on a dry fart after 50 years old. I believe they were right. Although, you understand, I can' t confirm that. Smile
Terry Lewis
PostPosted: Wed Jan 18, 2006 4:21 pm    Post subject: decompression sickness and narcosis (was: AYS-bound) Reply with quote
There are no dry farts over age 55. Just old farts.
Doc
JOffice(at)aol.com
PostPosted: Wed Jan 18, 2006 5:06 pm    Post subject: decompression sickness and narcosis (was: AYS-bound) Reply with quote
In a message dated 1/18/2006 3:29:43 PM US Eastern Standard Time, erniel29(at)gmail.com writes:
Ernie
Viperdoc-
   Well, I appreciated it anyway...  buy you didn't talk about Argon and Neon as anesthetics at high pp...
   JSL
   (another anesthesiologist-pilot)
L39parts(at)hotmail.com
PostPosted: Thu Jan 19, 2006 6:27 am    Post subject: decompression sickness and narcosis (was: AYS-bound) Reply with quote
I didn't realize so many CJ pilots were divers.  Here's an interesting story about SCUBA diving to 900 feet HTTP://outside.away.com/outside/features/200508/dave-shaw-1.html in the deepest freshwater lake (cave) in the world.
