bonanza(at)vodamail.co.za Guest
Posted: Tue Aug 01, 2006 2:46 am Post subject: Radio noise/interference |
Good day listers.
I normally lurk on the Beech list but this query is far more suited to this forum!
I fly a 1949 A35 Bonanza with an IO 470 engine and two Becker radios. I have had endless problems with interference.
There is a loud “ticking” noise about 3 times per second when I hear someone else transmit. I have had the alternator overhauled,(suspected diode problem) the regulator changed, relocated the alternator wires inside the cockpit together with the relevant circuit breakers to the far left of the panel (radios on RHS), wired the radio power wire direct to the battery, rerouted the antenna wires and fitted a suppressor to the B terminal. There is also a wining noise audible as soon as the Alt Field is switched on, usually at low RPM. This corresponds with the flicking of the Ampmeter needle as the regulator cuts in and out.
Any suggestions appreciated!
Bob Verwey
A35 ZU-DLW
brian
Joined: 02 Jan 2006 Posts: 643 Location: Sacramento, California, USA
Posted: Tue Aug 01, 2006 10:26 am Post subject: Radio noise/interference |
On Aug 1, 2006, at 6:36 AM, Bob Verwey wrote:
| Quote: | There is a loud “ticking” noise about 3 times per second when I
It is hard to troubleshoot things we can't hear for ourselves. Here
are some additional questions:
1. Does the ticking change with changes in the engine speed?
2. Does the ticking correspond to the flickering of your ammeter?
The whine may mean that you have one or more diodes out in the
alternator but I suspect something else.
Do you have an intercom? When you unplug all your mics do the noises
get less or disappear?
Brian Lloyd 361 Catterline Way
brian-yak AT lloyd DOT com Folsom, CA 95630
— Antoine de Saint-Exupéry
_________________ Brian Lloyd
brian-yak at lloyd dot com
- Antoine de Saint-Exupery |
