jgswartout(at)earthlink.n Guest
Posted: Sun Jul 30, 2006 9:42 pm Post subject: Electrical system for review and critique |
Bob and list:
My planned electrical system for my Zenith STOL CH-801 is now posted at:
http://www.matronics.com/photoshare/jgswartout(at)earthlink.net.07.30.2006/
for your review and critique. A description accompanies the schematic. Comments
pro and con are solicited and welcome.
John
Erich_Weaver(at)URSCorp.c Guest
Posted: Mon Jul 31, 2006 2:33 pm Post subject: electrical system for review and critique |
hey John
Im no expert so everything I say is suspect... but through Bobs
AeroElectric Connection and this list I have managed to wire my RV-7A more
or less according to Z-13/8 and hey - everything on the panel now lights up
when I tell it to.
A couple minor points: I think the ANL- 40 current limiter is probably
fine instead of the -60 if you only have the 40 amp alternator
On your load analysis, note that the battery contactor is shut off in the
event of main alternator failure and switching over to the SD-8, so you
actually have another 1 amp to play with on your endurance buss under this
condition
Im not very familiar with your modifications to the Z-13 alternator
regulator wiring that I guess you "borrowed" Z-14. Remind me - what are
you accomplishing with all those diodes?
Similarly, although there has been some discussion of this on the list, I
still dont get what the benefit is for the SD-8 self-excitation. What is
the scenario where I would wish I had this? (others welcome to jump in
here as you see fit!)
regards,
Erich Weaver
Posted: Mon Jul 31, 2006 5:27 pm Post subject: electrical system for review and critique |
klehman(at)albedo.net Guest
Posted: Mon Jul 31, 2006 6:03 pm Post subject: electrical system for review and critique |
Hi John
I believe that the EIS is fine as a hi voltage warning.
If you have functioning overvoltage protection, it will never illuminate
anyway. Its low voltage warning will then be important though.
Ken
| Quote: | It appears, however that I left out the overvoltage
warning light. I don't remember why (most of this I did about 12
months ago), but it may be that since I will be using the Grand Rapids
Technologies Model 4000 EIS for low-voltage warning, I may have been
intending to use it for overvoltage warning as well. It comes with a
blinding indicator light which comes on when any user-set parameter is
violated. I'd like Bob to comment on this, as I'm finished drilling
holes in the panel and plan to paint it in a few days. Now would be a good
time to drill one more if necessary.
Posted: Tue Aug 01, 2006 8:37 am Post subject: electrical system for review and critique |
Hey again John
I checked the archives regarding your reference on the 60 amp fuse - I
dont think you are interpreting this quite right. The original post was
not really about Z-13, but a modified starter set-up that had been
suggested. Also, the MAX 60 fuse is something different than an ANL
current limiter - check out the link posted in Bob's reply from the
archives:
http://www.bussmann.com/shared/library/catalogs/Buss_Auto-Fuse_Cat.pdf
I cant provide a direct reference - probably something from the
AeroElectric FAQ files - but I still think that the ANL40 is pretty robust
fuse and is fine with the 40 amp alternator. Somebody please correct me if
Im full of it.
Erich Weaver
Posted: Tue Aug 01, 2006 3:33 pm Post subject: electrical system for review and critique |
Hi Erich,
I see your point, but I think the archived post is applicable, because if
you read the thread that comes up if you type "MAX60" into the archive
search window, it is all about using Z-22, which is one of the modifications
I have made to Z-13/8. You're right, the MAXI fuses are not the same as ANL
current limiters; I haven't been able to find anything other than the post
cited to indicate the proper size for the protection device, whether MAXI or
ANL. I think the point of using a MAXI fuse & holder was that they're
cheaper than an ANL current limiter. I've already bought the ANL so that's
of no consequence to me. Z-22 just says the device should be "sized to the
alternator." Usually circuit protection devices are sized to protect the
wire they're attached to, unless the wire is unusually large for the gadget
attached, so I'm lost here. However, this excerpt from a January 11, 2002
post from Bob might give a clue:
The alternator is NOT the source of current that opens
this fuse . . . Alternators are physically incapable of
putting out much more than their design limit with respect
to current (not so for voltage . . . you can get 100V+
from a runaway alternator).
The current source that might antagonize the alternator
b-lead is the BATTERY . . . good for 700-1500 amps
in a fault condition through fat wires. Hence, the
alternator b-lead protection goes at the end of the
wire opposite the alternator connection.
Incidentally, I haven't ruled out buying a B&C series-wound starter, but I
will wait until well into the test flight phase before deciding. My A&P
says a Sky-Tec Fly Weight is a perfectly good starter; but to avoid possible
problems with the electronic ignitions at start-up, the B&C option might be
appealing.
Thanks again.
John
Posted: Tue Aug 01, 2006 5:47 pm Post subject: electrical system for review and critique |
Actually you are on the right track. ANL fuses are slow acting and a 40
amp alternator is quite unlikely to ever blow a ANL40 as I see it. So
that would be sufficient and would be my first choice if ordering a new
part. I'd also be happy with a ANL60 as long as the wire is at least
AWG8. You want the ANL or fuse to open before the wire gets dangerously
hot in the rare event of a short at or in the alternator. Even AWG8
might warm up a fair bit before the battery opened an ANL60 but I
wouldn't expect it to be much of a real risk.. I can see that some
folks might be more comfortable with AWG6 wire on an ANL60.
I have a MAX50 and AWG8 wire on my 40 amp alternator but a MAX60 would
also be a good choice IMO as these are fast acting fuses.
Ken
John Swartout wrote:
Hi Erich,
appealing.
Thanks again.
John
paulm(at)olypen.com Guest
Posted: Tue Aug 01, 2006 6:39 pm Post subject: electrical system for review and critique |
I have a new 55 amp ND alternator and its rated for a max of 70 amps at 13.0
V output.
Not sure about a 40 amp alternator but as you can see 70 amps is more than
25% greater than the "so called" 55 amp rating.
I would never consider a fuse rated at less than 70 amps for my 55 amp rated
alternator.
70 amps for vary long may overheat the alternator but that is another issue.
55 amps is the rated continuous output (with proper cooling); 70 amps is the
max output with an output and field voltage of 13.0 v. Its not specified
what the max output is where the output voltage drops below 14.3V
(internally regulated).
Paul
Posted: Tue Aug 01, 2006 7:17 pm Post subject: electrical system for review and critique |
I'm showing that ANL current limiter on 4 ga. Welding cable, substituting
that for 4 AWG in Fig. Z-13/8. That should be plenty big for the maximum
continuous load contemplated (25 amps). Battery will be on the firewall so
all fat wire runs will be pretty short.
John
