Hole Punch
asknickp(at)yahoo.com
PostPosted: Wed Jan 18, 2006 7:32 am    Post subject: Hole Punch Reply with quote
Just curios,why cant you use an aircraft hole punch to
make the rivit holes.It seems like it would eliminate
de-burring.Forgive me if this topic has been covered
in the past.
"THIS is the golden age of aviation"
A Fellow Aviator
Nick Pace
Harpers Ferry WV
Building a 601XL #5607
Corvair Powered
{Rudder almost done}
cgalley(at)qcbc.org
PostPosted: Wed Jan 18, 2006 8:05 am    Post subject: Hole Punch Reply with quote
Whitney-Roper makes one but you are limited to mainly edges.
Cy Galley - Chair,
AirVenture Emergency Aircraft Repair
A Service Project of Chapter 75
EAA Safety Programs Editor - TC
EAA Sport Pilot
frank.hinde(at)hp.com
PostPosted: Wed Jan 18, 2006 8:24 am    Post subject: Hole Punch Reply with quote
And you still need to match drill the hole to the sructure underneath
which still has to be deburred.
You really will cost yourself more time than you will save I suspect.
Frank
dredmoody(at)cox.net
PostPosted: Wed Jan 18, 2006 10:48 am    Post subject: Hole Punch Reply with quote
Punches leave burs too but they vcan be used in place of drilling as long as you debur.
Ed Moody II
Date: 2006/01/18 Wed AM 10:26:28 EST
Subject: Hole Punch
in the past.
A Fellow Aviator
Nick Pace
Harpers Ferry WV
Corvair Powered
Kevin Bonds
PostPosted: Wed Jan 18, 2006 2:36 pm    Post subject: Hole Punch Reply with quote
I have had one for a while. I have yet to use it. It will not allow me to
punch over a flange. Therefore it has limited uses.
Kevin Bonds
Nashville TN
601XL Corvair powered; Plans building.
Empennage done; working on wings and engine.
http://home.comcast.net/~kevinbonds
do not archive DO NOT ARCHIVE
KevinBonds
Nashville, TN
Plans-building Zenith CH601XL w/Corvair Power
bretttdc(at)yahoo.com
PostPosted: Thu Jan 19, 2006 4:19 am    Post subject: Hole punch Reply with quote
I have the Grizzly version. Works great! Save the
twenty dollars and go to a pawn shop to buy a cheap,
light Skill or Black and Decker 3/8 non reversing
drill instead. Get two and you will rarely have to
change the bit.
in the past.
