Initial filling of hydraulic brakes with fluid
hgmckay
PostPosted: Tue Aug 01, 2006 5:31 pm    Post subject: Initial filling of hydraulic brakes with fluid Reply with quote
Allegro 2000 Team:
<![if !supportEmptyParas]> <![endif]>
Since I have received no instructions from the manufacturer as to the proper method of initial filling the hydraulic brake system and bleeding the lines, I am again coming to you guys for help. Can anyone walk me through the correct procedure?
Hugh Mckay
Thom Riddle
PostPosted: Wed Aug 02, 2006 3:21 am    Post subject: Initial filling of hydraulic brakes with fluid Reply with quote
Hugh,
Buy a brake bleeding kit from an auto parts store and follow the
instructions that should come with it. If no instructions, check out
any of the following links for tips on how to do this.
http://en.wikipedia.org/wiki/Brake_bleeding
http://www.carcentral.net/content/guides/HowToBleedABrakeSystem.php
http://www.webbikeworld.com/Motorcycle-technical-articles/bleeding-
motorcycle-brakes/bleeding-motorcycle-brakes.htm
http://www.scooterhelp.com/genmaintain/brake.bleed.html
None of these are specifically for an Allegro brake system, but all
hydraulic brakes work the same way.
Thom in Buffalo
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
