		jjessen
				 Posted: Mon Jul 31, 2006 1:33 pm    Post subject: F-1073 hole too large |
				Say someone made their static hole too large on one of the F-1073 side
 skins.  Say someone wanted to devise a fix for said hole so that the
 Cleveland static port would still reside in the same place.  Would someone
 make a backing plate that had riveted to it a piece of aluminum the same
 thickness as the side skin onto which the aforementioned static port was
 attached so that the backing plate and the new piece of aluminum/static port
 was flush with the original skin?
 Or, would one simply go buy another F-1073 and ream out the holes, deburr
 everything, and call it a learning experience?  Wise thoughts, please.
 John J
		Tdawson(at)avidyne.com Guest
				 Posted: Mon Jul 31, 2006 1:44 pm    Post subject: F-1073 hole too large |
				I think one would stop talking about themselves in the third person!  :
 TDT
		Rick S.
				 Posted: Mon Jul 31, 2006 1:57 pm    Post subject: F-1073 hole too large |
				John,
 For me it would be...How much too big? Your scab patch on the inside my look sorta OK, but as I understand it the Cleavland ports need to be installed so the flat portion that extends out through the skin by a certain degree of thousands of an inch, I don't recall the exact measurment to insure the ports don't siphon air like a venturi, the small amount of protrusion makes the air "burble" around the port so you get a true static pressure. You would not get this by patching from behind then installing through the patch.
 So I would imagine you would have to mount that port in another hole then patch your skins, which if you scab on a patch behind the existing hole you could build up with epoxy filler and make a flush repair. Your call.....but deep down it's more of a cosmetic thing....and if you want to buy new skins.
 Rick S.
 40185
  _________________ Rick S.
RV-10
40185 |
		zackrv8
				 Posted: Mon Jul 31, 2006 1:57 pm    Post subject: Re: F-1073 hole too large |
				John,
   Contact Dave at rvsilverbullet(at)verizon.net  .  He can make you up a custom static port to any size you want.
 Zack
  _________________ RV8 #80125
RV10 # 40512 |
		jjessen
				 Posted: Mon Jul 31, 2006 2:03 pm    Post subject: F-1073 hole too large |
				Wise thought, this is not.  Embarrassed, I may be.
		KiloPapa
  Joined: 24 May 2006 Posts: 142 Location: Pearblossom, CA
				 Posted: Mon Jul 31, 2006 6:26 pm    Post subject: F-1073 hole too large |
				FYI - I ordered static ports and the trim cable mounts from Dave and found
 him to do excellent work and he was a pleasure to deal with.
 Kevin
 40494
  _________________ Kevin
40494
do not archive |
		bob.kaufmann(at)cox.net Guest
				 Posted: Wed Aug 02, 2006 5:12 am    Post subject: F-1073 hole too large |
				If it was me, I would take the static port to a machinist, and have him make
 a new one, to fit the new hole.  It may cost you, but a good machinist like
 my neighbor can make it to fit any hole and still have the exact pressure,
 static source.  Actually, it would not take that good a machinist, just
 someone with a lathe.
 Bob K
 Back from OSH and finally cooling down here in Nevada.
 At least here it's a dry heat.  LOL
