Deems Davis
Posted: Wed Aug 02, 2006 9:02 am Post subject: Survey of the day: windshield visors - Zach can you |
Hey how about getting Zack's brother to machine these for us, cutting
the plexi is a no brainer.
Deems Davis # 406
Fuse/Finishing/Panel
http://deemsrv10.com/
Tim Olson wrote:
Replying to both the below messages....
Deems, yes, that's one of the 2 options I was working with Rosen
on. The tube is about .895 diameter, and they don't have any
clamps of that size made yet. The bar is set a couple inches
back from the windshield, so it would need to have a T shape
behind the clamp, with the visors attached forward of the bar,
and when they swing up they'd have to be of the right size to clear
the door and side windows. That's the arrangement I have been
working with them on, but everything halted with their busy
contracts. The 2nd option I gave them was a screw in hinge
that would mount to the canopy top just behind the windshield
on that foam filled ridge. That would work too, but wouldn't
be swing able. FWIW, I don't think it's necessary to have them
swing to the side...if it were just available forward that
would be good.
Wayne, who's the guy you've been talking to? I've been
talking to Mike Fiske, and he's in direct communication
with the engineering team too. He also worked the booth
at SNF and OSH, but that was after I had already tracked
him down that I saw him there. I sure wish they had the
time. They did say though that if we were to come up with
everything, cutting the actual visors wouldn't be a big
problem.
Deems Davis wrote:
> How about a fixture that would clamp to the top of the centerbrace
> support that ties the top of the canopy to the fwd fuse? Should be a
> simple clamp-on device with tabs on either side for mounting the
> visors to.
> Deems Davis # 406
> Fuse
> Wayne Edgerton wrote:
>> I've been in communications with the sales manager from Rosen and he
>> says they are working on visors for the RV10. He told me they are
>> struggling with how to attach them to the canopy. I've sent him off
>> a couple of ideas but he says they have several other projects they
>> are working on so the RV10 isn't getting top priority right now.
>> I've had Rosen in my last two planes and I really liked them. Other
>> than that I may have to fall back on the old stick on the window
>> thingies.
>> Wayne Edgerton # 40336
>> Engine work
http://wiki.matronics.com
