luckymacy(at)comcast.net Guest
Posted: Sun Jul 30, 2006 9:13 am Post subject: Air Oil Separators |
Any make/model preference on these things? I was surprised to see such a wide range of options in the ACS catalogue. I don't know anyone who is actally using one so this one goes out to the list.
Anyone using the "experimental" $45 round one? I found none on ebay for airplanes. I thought this would be an easy salvage item to find.
For those that are routing the oil back into the engine, are you modifying the dip stick housing to accept a return hose?
thx,
lucky
Posted: Sun Jul 30, 2006 9:25 am Post subject: Air Oil Separators |
lucky wrote:
| Quote: | Any make/model preference on these things? I was surprised to see
thx,
lucky
Lucky, IMHO the oil separators cover up a more pressing problem .....
blowby. From what I've heard, almost all separators work ..... kinda.
They'll keep the belly cleaner if that's your goal. However, instead
of returning the crud back to your engine, you can drain it into some
kind of removeable cup ...... or even a long loop of clear hose that you
can see and drain at your convenience. One look at the stuff that's
been siphoned off will make you glad you didn't route it back to the engine.
The problem is that the acid that is produced naturally by combustion
doesn't get vented overboard as well as it should.
Linn
Check the archives.
jhstarn(at)verizon.net Guest
Posted: Sun Jul 30, 2006 10:02 am Post subject: Air Oil Separators |
I'll keep this short. There are lots of suggestions in the Archives. We tried four different type/styles/sizes, bottom line: DONT.
IF you collect ANYTHING,` IF you install one, the very last thing you want is to dump the "goop" back into the engine.
ANYTHING that restricts the vents air flow causes "backpressure" inside the case & that causes leaks at covers, cylinders, case joints etc etc. Run the line FULL size to an area where anything that MIGHT drip hits the exhaust pipe. IO-540 J4A5 HRII almost 300 hrs
KABONG Do Not Archive (its in there)
Vanremog(at)aol.com Guest
Posted: Sun Jul 30, 2006 3:31 pm Post subject: Air Oil Separators |
In a message dated 7/30/2006 10:14:53 A.M. Pacific Daylight Time, luckymacy(at)comcast.net writes:
| Quote: | | Any make/model preference on these things? I was surprised to see such a wide range of options in the ACS catalogue. I don't know anyone who is actually using one so this one goes out to the list. |
Get the 3/4" dia port one from Wicks (P/N OIL-BS3/4) for around $50 and do the pot scrubber mod defined in the archives. It's a no brainer.
GV (RV-6A N1GV O-360-A1A, C/S, Flying 801hrs, Silicon Valley, CA)
Posted: Sun Jul 30, 2006 3:45 pm Post subject: Air Oil Separators |
Thanks, it's more like $87.50 now and looks suspiciously like the $50 one in ACS!
lucky
| Quote: | -------------- Original message --------------
Posted: Sun Jul 30, 2006 4:11 pm Post subject: Air Oil Separators |
In a message dated 7/30/2006 4:47:28 P.M. Pacific Daylight Time, luckymacy(at)comcast.net writes:
| Quote: | Thanks, it's more like $87.50 now and looks suspiciously like the $50 one in ACS!
lucky
Ask ACS why they don't sell the 3/4" port version. They are made by the same company.
Mark Phillips in TN
Joined: 10 Jan 2006 Posts: 431 Location: Columbia, TN
Posted: Sun Jul 30, 2006 6:17 pm Post subject: Air Oil Separators |
In a message dated 07/30/2006 12:14:53 PM Central Daylight Time, luckymacy(at)comcast.net writes:
| Quote: | | Anyone using the "experimental" $45 round one? I found none on ebay for airplanes. I thought this would be an easy salvage item to find. |
See: http://websites.expercraft.com/n51pw/index.php?q=log_entry&log_id=5172
and click >>Next Entry>> at top of page for more info on my prosecution of this "problem". Also, do NOT dump crap from separators back into your expen$ive engine- if the engine wanted this crap in there in the first place, it wouldn't have puked it out!
From The PossumWorks in TN
Mark Phillips do not archive
_________________ From The PossumWorks... |
pbesing(at)yahoo.com Guest
Posted: Sun Jul 30, 2006 7:58 pm Post subject: Air Oil Separators |
I'm not convinced on these things...not sure if the one on my purchased RV-4 is clogged or what, but the belly get's just as dirty in 4 flights than it would without one. I've got a return going into the crank case, and and exit going out by the exaust, and am getting ALOT of oil on the belly after 8-10 hours if I don't clean it regularly.
Again, it may be clogged or something, but unfortunately there is no way to take it apart and see.
Paul Besing
lucky <luckymacy(at)comcast.net> wrote:
| Quote: | Any make/model preference on these things? I was surprised to see such a wide range of options in the ACS catalogue. I don't know anyone who is actally using one so this one goes out to the list.
thx,
lucky
rveighta(at)earthlink.net Guest
Posted: Mon Jul 31, 2006 6:19 am Post subject: Air Oil Separators |
I'm sure I'm far from being the most knowledgeble builder on the list,
but it seems to me that automotive mfgrs recycle oil back through their
engines without detriment and without puddles of oil on the garage
floor.
My own experience with seperators has been with the cheapest one I
could find initially (ACS P/N 10570) on my RV-8A. I didn't stuff it with
brillo pads or anything like that, and man, did oil cover the belly!
Eventually, I began looking at other seperators and sucumbed to the
claims of the M-20 & RMJ, both of which recycle oil back to the engine.
The M-20, I believe, is certified and used on lots of different production
aircraft. Being cheap, however, I bought the RMJ and after about ten
hours of operation the belly is still relatively clean and my oil loss is down.
I'm not sure how much improvement I'm seeing because I haven't kept
exact records, but my best guess is that I'm loosing about a quart every
ten hours now versus a quart every 4-5 hours previously.
Walt Shipley RV-8A flying, RV-8 Canopy (argh)
[quote]--
dbris200(at)sbcglobal.net Guest
Posted: Mon Jul 31, 2006 7:02 am Post subject: Air Oil Separators |
The oil might not be coming from the vent. It doesn't take a very big leak to make a real mess.
Dave
Paul Besing wrote: | Quote: | I'm not convinced on these things...not sure if the one on my purchased RV-4 is clogged or what, but the belly get's just as dirty in 4 flights than it would without one. I've got a return going into the crank case, and and exit going out by the exaust, and am getting ALOT of oil on the belly after 8-10 hours if I don't clean it regularly.
Paul Besing
thx,
lucky
Posted: Mon Jul 31, 2006 6:47 pm Post subject: Air Oil Separators |
OK, I'll add a little to our story. We installed three separators (one at a0 time), put in reducers to make them fit, 3/4" ID down to the sizes on the0 separator, looped in a high point, put a relief hole in the top of the loop and0 tried everything anyone could recommend to make them work & not soil the0 belly. Blow-by did not seem to be a problem (newly rebuilt) BUT too much oil in0 the sump and ANY restriction of the vent line resulted in oil leaks. Two of the0 case/cover leaks disappeared & have stayed gone as soon as we ran the0 vent full line size without restriction. Two other leaks area were lessened but0 we loosened the bolts holding them, added RTV & retorked them.0
If we overfill by a cup, we get a cup of oil on the belly. We did reinstall0 the full sized rubber line with a high loop and that solved our problem. Your0 invited out & can stick your finger up in the vent line and you'll get it0 dirty but not enough oil to form a single drop.
I realize that this is anecdotal and your mileage may differ BUT you0 would have to talk long & loud to get us to put any separator back on0 N561FS. HRII IO-540 J4A5 Do Not Archive. KABONG (GBA &0 GWB)
Dale Ensing
Joined: 11 Jan 2006 Posts: 571 Location: Aero Plantation Weddington NC
Posted: Tue Aug 01, 2006 6:59 am Post subject: Air Oil Separators |
What level (how many quarts) do you consider full0 oil ? and which engine ?
Dale Ensing
do not archieve
| Quote: | Blow-by did not seem to be a problem0 (newly rebuilt) BUT too much oil in the sump and ANY restriction of the vent0 line resulted in oil leaks. If we overfill by a cup, we get a cup of oil0 on the belly. We did reinstall the full sized rubber line with a high loop and0 that solved our problem. Your invited out & can stick your finger up in0 the vent line and you'll get it dirty but not enough oil to form a single0 drop.
I realize that this is anecdotal and your mileage may differ BUT you0 would have to talk long & loud to get us to put any separator back on0 N561FS. HRII IO-540 J4A5 Do Not Archive. KABONG (GBA & GWB)
_________________ Dale Ensing
RV-6A
Aero Plantation
Weddington NC |
Posted: Tue Aug 01, 2006 5:05 pm Post subject: Air Oil Separators |
HR II, IO-540 J4A5, 8 1/2 in the dipstick. HRII is taildragger so anything0 with a nose gear might change the reading. "Your" engine will tell you when it0 has too much and throws out the excess until it's happy.
Your mileage may differ. KABONG Do Not Archive.
khorton01(at)rogers.com Guest
Posted: Tue Aug 01, 2006 5:55 pm Post subject: Air Oil Separators |
On 31 Jul 2006, at 10:19, rveighta wrote:
their
floor.
Autos are burning fuel without lead, in liquid-cooled engines with
smaller bores that can have much tighter clearances. I'm betting
there is less blow by in an auto engine, and the blow by will contain
different stuff. Plus automotive and aviation oil have different
additive packages. Current automotive engines were designed to
accept the blow by gasses, but I believe it goes into the induction
air, rather than back into the oil as some have proposed for our
aircraft engines.
The auto engine experience may not be relevant. Given the cost of
engine overhauls, I'm not too keen to put something different inside
my engine (crud from the air-oil separator), unless there is a huge
wealth of service experience behind it.
Kevin Horton
Ottawa, Canada
Charles Heathco
Posted: Wed Aug 02, 2006 5:33 am Post subject: Air Oil Separators |
Enough may have been said about this, but my 3200 will throw out anything over 7 qt, and I let it go down to 6 1/2 qt where I keep0 it and I get very little oil on the belly at that reading. As for the0 separators, from what I have heard from a few who had them, they are a waste of0 money. Charlie Heathco
Morocketman(at)aol.com Guest
Posted: Wed Aug 02, 2006 11:27 am Post subject: Air Oil Separators |
Roger on the info regarding Air/Oil Separators! I had too much oil on the belly of my IO-540 powered Harmon Rocket II. Tried everything I could think of regarding the vent line size, loop up and over, aimed at the exhaust, etc. The Separator did no good at all.
I let the oil quanity go down to 9 1/2 (per someone's suggestion)0and vola! I have never seen below 8 1/2. And yes, I do find myself adding one pint sometimes. But easier than Washing the Belly. My Lycoming manual says 12 qt system, with minimum (bet you cannot believe this) of 2 qts. Yes! Two quarts minimum. I can't remember my IO-360 minimum, but recall that it was equally scary. Give it a try-------you'll like it.
Les Featherston HRII "Airgasm" has 277 hours.
rv8a2001(at)yahoo.com Guest
Posted: Wed Aug 02, 2006 2:04 pm Post subject: Air Oil Separators |
I had a bunch of oil on the belly, the fix, cheap ACS round air oil seperator with 2 stainless pot scrubbers stuffed inside. Now, no oil on the belly, just a slight mist about 1~2 feet back from the tube which is not on the exhaust. I have made a few for others but dont know if they monitor the list here to comment.
Morocketman(at)aol.com wrote: | Quote: | Roger on the info regarding Air/Oil Separators! I had too much oil on the belly of my IO-540 powered Harmon Rocket II. Tried everything I could think of regarding the vent line size, loop up and over, aimed at the exhaust, etc. The Separator did no good at all.
I let the oil quanity go down to 9 1/2 (per someone's suggestion) and vola! I have never seen below 8 1/2. And yes, I do find myself adding one pint sometimes. But easier than Washing the Belly. My Lycoming manual says 12 qt system, with minimum (bet you cannot believe this) of 2 qts. Yes! Two quarts minimum. I can't remember my IO-360 minimum, but recall that it was equally scary. Give it a try-------you'll like it.
How low will we go? Check out Yahoo! Messenger’s low PC-to-Phone call rates.
Posted: Wed Aug 02, 2006 2:36 pm Post subject: Air Oil Separators |
Both figures were for HRII N561FS, 90 1/2 to 10 at the oil change. 8 1/2 on the dip stick is "normal" cold0 operating range +/- half a quart. KABONG Do Not Archive (GBA &0 GWB)
Gary.A.Sobek
Posted: Wed Aug 02, 2006 4:56 pm Post subject: Air Oil Separators |
Have tried with and without oil separator and with modified oil separator.
There is less blow by with the oil separator and even less with the Scott
Billinski modified oil separator. After the number of hour on the airplane,
there is still oil on the belly but some of it is from the SMOKE system. The
smoke system makes the belly easier to clean as it softens the exhaust gas
deposits.
The drain from the oil separator goes back into the engine and has always
done so. Note the numbers of hours in the past almost 9 years of flying.
Gary A. Sobek
1,921+ Flying Hours So. CA, USA
http://SoCAL_WVAF.rvproject.com
