echristley(at)nc.rr.com Guest
Posted: Wed Aug 02, 2006 12:32 pm Post subject: MPJA speed control |
I read of the MPJA DC motor speed controller kit being used as a light
dimmer, so I ordered me one. Had it together in an afternoon and
breadboarded up some LEDs to give it a test. I have access to a scope
to check what it's doing, but haven't had time to go by Mark's shop
yet. So far, I find the light flickers visibly, and there is only a
very small change in the brightness as the adjustment knob is turned.
Has anyone else attempted to use this device to control the brightness
of LEDs, and if so, how successful were you?
,|"|"|, Ernest Christley |
----===<{{(oQo)}}>===---- Dyke Delta Builder |
o| d |o http://ernest.isa-geek.org |
Mark Phillips in TN
Joined: 10 Jan 2006 Posts: 431 Location: Columbia, TN
Posted: Thu Aug 03, 2006 3:57 am Post subject: MPJA speed control |
In a message dated 08/02/2006 3:34:49 PM Central Daylight Time, echristley(at)nc.rr.com writes:
Quote: | Has anyone else attempted to use this device to control the brightness
of LEDs, and if so, how successful were you? |
I'm using one to drive over 60 red superbrights plus the incandescents0on my Van's fuel gauges. Works well with the exception of an occasional random flicker which I suspect is a AMP connector that needs some attention. I removed the variable resistor from the board and remote-located a 100Kohm, 2 watt from Digikey (# RV4N104C-ND) to the panel alongside the other lighting switches. Very linear control of all LEDs and fuel gauge bulbs, from full bright to almost completely off. Schematic on ACAD if interested...
Mark Phillips
_________________ From The PossumWorks... |
sam.marlow
Posted: Thu Aug 03, 2006 5:41 am Post subject: MPJA speed control |
Where do I purchase one of these, and what is ACAD?
Fiveonepw(at)aol.com (Fiveonepw(at)aol.com) wrote:
Quote: | In a message dated 08/02/2006 3:34:49 PM Central Daylight Time, echristley(at)nc.rr.com (echristley(at)nc.rr.com) writes:
I'm using one to drive over 60 red superbrights plus the incandescents on my Van's fuel gauges. Works well with the exception of an occasional random flicker which I suspect is a AMP connector that needs some attention. I removed the variable resistor from the board and remote-located a 100Kohm, 2 watt from Digikey (# RV4N104C-ND) to the panel alongside the other lighting switches. Very linear control of all LEDs and fuel gauge bulbs, from full bright to almost completely off. Schematic on ACAD if interested...
Mark Phillips
mark.steitle(at)austin.ut Guest
Posted: Thu Aug 03, 2006 8:15 am Post subject: MPJA speed control |
Hi Ernest,
Yes, I'm using the MPJA pwm speed controller for dimming LED's. In the
attached jpg. you can see the string of led's across the top of my panel
which are controlled by a single MPJA speed controller. I too
repositioned the potentiometer with a remote unit of higher quality. All
of my circuits were configured from the manufacturer to operate on 12v
as the MPJA pwm speed controller is designed to operate a 12v motor.
Works great with no noticeable flicker.
Mark S.
Description: |
Filesize: |
140.05 KB |
Viewed: |
187 Time(s) |
Mark Phillips in TN
