capacitor sizing
kesleyelectric(at)chooseb
PostPosted: Mon Aug 07, 2006 6:55 am    Post subject: capacitor sizing Reply with quote
A friend of mine0 asked if I could come up with a variable voltage source to check the trip rating0 on his homegrown voltage regulator/OV protector. I have an autotransformer0 that would work well, but the output is AC. Running through a bridge0 rectifier would be no problem, but I would like to add a capacitor to smooth the0 output waveform. I do not have an o-scope available, so I am looking for0 suggestions as to capacitor size needed. Any help0 appreciated.
Tom0 Barter
Kesley,0 IA
klehman(at)albedo.net
PostPosted: Mon Aug 07, 2006 10:18 am    Post subject: capacitor sizing Reply with quote
Hi Tom
I'd suggest the largest electrolytic capacitor that you have sitting
around. Pretty much anything should work since the gate draws little
current. You might need a load resistor to help bleed the capacitor
voltage off when reducing the voltage.
Another way might be to just to add a couple of 1.5 volt flashlight
batteries in series with the main battery. Or for more precision you
could also use a variable resistor across one or more of the extra
batteries to tap off a variable voltage.
Ken
kesleyelectric wrote:
A friend of mine asked if I could come up with a variable voltage
source to check the trip rating on his homegrown voltage regulator/OV
protector. I have an autotransformer that would work well, but the
output is AC. Running through a bridge rectifier would be no problem,
but I would like to add a capacitor to smooth the output waveform. I
do not have an o-scope available, so I am looking for suggestions as
to capacitor size needed. Any help appreciated.
Tom Barter
Kesley, IA
brian
PostPosted: Mon Aug 07, 2006 12:02 pm    Post subject: capacitor sizing Reply with quote
OV protector. I have an autotransformer that would work well, but
the output is AC. Running through a bridge rectifier would be no
problem, but I would like to add a capacitor to smooth the output
suggestions as to capacitor size needed. Any help appreciated.
Why don't you just borrow a variable voltage DC power supply from
someone?
Brian Lloyd 361 Catterline Way
brian-yak AT lloyd DOT com Folsom, CA 95630
— Antoine de Saint-Exupéry
Brian Lloyd
brian-yak at lloyd dot com
- Antoine de Saint-Exupery
nuckollsr(at)cox.net
PostPosted: Tue Aug 08, 2006 6:22 am    Post subject: capacitor sizing Reply with quote
>source to check the trip rating on his homegrown voltage regulator/ OV
someone?
Good idea. Everyone should have a small, metered bench
supply for such tasks. They're very handy. I've got probably
a half dozen supplies of various capacities. A particularly
good value right now is offered by Marlin P. Jones at:
http://mpja.com/productview.asp?product=14600+PS
They're out of stock on this one right now but should
have more shortly.
< What is so wonderful about scientific truth...is that >
< the authority which determines whether there can be >
< debate or not does not reside in some fraternity of >
< scientists; nor is it divine. The authority rests >
< with experiment. >
< --Lawrence M. Krauss >
brian
PostPosted: Tue Aug 08, 2006 9:48 am    Post subject: capacitor sizing Reply with quote
> someone?
have more shortly.
Here is a 25A lightweight switcher that should be able to run most of
your aircraft electrical system for testing. Wire it to your
alternator's B-lead so you can test everything.
http://www.mfjenterprises.com/products.php?prodid=MFJ-4225MV
Brian Lloyd
sportav8r(at)gmail.com
PostPosted: Tue Aug 08, 2006 10:34 am    Post subject: capacitor sizing Reply with quote
Jumping in a little late here on this concept; I am going to put an SD-8 into my flying RV later on for Z-13/8-style redundancy. I caught some discussion about the little dynamo not being self-exciting without the added Z-25 circuitry. I'm trying to understand what failure mode would cause the SD-8 not to be connected to the battery and getting its excitation from that source. Wired as per Z-13/8, it seems the battery is always available to the alternator via the S-704-1 relay. Are we addressing a scenario where the battery itself is taken all the way down so that it cannot close the relay? That just seems really remote to me.
Thanks for clearing this up for me, as I know you will Wink
-Bill B
On 8/8/06, Robert L. Nuckolls, III <nuckollsr(at)cox.net (nuckollsr(at)cox.net)> wrote:
--> AeroElectric-List message posted by: "Robert L. Nuckolls, III" < nuckollsr(at)cox.net (nuckollsr(at)cox.net)>
--> AeroElectric-List message posted by: Brian Lloyd <brian-yak(at)lloyd.com (brian-yak(at)lloyd.com)>
>protector. I have an autotransformer that would 8work well, but
someone?
have more shortly.
