binx nuts
paul(at)pstewart.f2s.com
PostPosted: Thu Aug 17, 2006 8:37 pm    Post subject: binx nuts Reply with quote
We have just re fitted our engine having removed it for fuselage
painting. The M10 binx nuts don't seem to feel as 'stiff' on
tightening as they did. Are they by any chance one use only - and we
are using them the correct way round with the flat against the engine
frame?????
Paul
G-GIDY
europa flugzeug fabrik
PostPosted: Mon Aug 21, 2006 6:32 am    Post subject: Re: binx nuts Reply with quote
paul(at)pstewart.f2s.com wrote:
We have just re fitted our engine having removed it for fuselage painting. The M10 binx nuts don't seem to feel as 'stiff' on tightening as they did. Are they by any chance one use only - ?????
I found it easy to drill holes in both the bolt head and nut, and safety wire them together. Used a high-quality drill bit and variable speed drill, probably 1/16".
Fred F.
