JohnBanes(at)adelphia.net Guest
Posted: Sun Aug 06, 2006 9:52 am Post subject: 912ULS - Oil in Exhaust |
The engine had not been operated for 5 weeks. Temperatures in the hangar during this period were in excess of 100 deg F. It was hand propped, several revolutions, until the oil level in the external reservoir was more than half way up the dipstick. Since the battery was low the initial start was attempted with the choke full on. The engine went through a couple of revolutions and stopped when it tried to fire. The next attempt ended with a single backfire after two of three revolutions. So the choke was closed and the starter was engaged and the engine rotated several times, just enough for the oil pressure to register 70psig, but it did not start. The started was disengaged. Then the starter was engaged with the choke on and the engine fired and ran smoothly at 2000 RPM. There was just a trace of smoke. It did not seem to persist so it was attributed to excess fuel from the previous attempts to start the engine. The engine idled and responded to throttle inputs normally and taxiing was begun. Two to three minutes later there was a large amount of smoke coming out of the exhaust and oil started to collect on the left landing gear and lift strut. The engine was operated for another couple of minutes during the return to the hangar. Most of the mosquitoes had left the area by this time. After a total of 5 minutes of operation the smoke stopped. The inspection after shutdown revealed the oil level in the tank to be at the full mark and the interior of the exhaust pipe was coated with oil. Subsequently the engine has been operated for more than two hours with no trace of smoke or oil.
Does anyone know of a similar experience?
Thanks in advance!
John Banes
S6 912S 225TT Pennzoil Motorcycle Oil 10W40
dafox(at)ckt.net Guest
Posted: Sun Aug 06, 2006 6:40 pm Post subject: 912ULS - Oil in Exhaust |
John, I had experienced the0 same thing at two different times from long periods of the engine not0 running.
however0 there was no backfiring after it was started. I would say your backfiring was0 caused from a
low battery and a flooded engine.
I wouldn't0 worry about it. I've flown my kitfox 40 hours sense0 then, and I just got back0 from Oshkosh
flying another 12 hours, and the 912 UL purred like0 a kitten all the way.
0 0 0 0 David0 Yeamans
0 0 0 0 Kitfox IV 1200 0 912 ULS
smokey_bear_40220(at)yaho Guest
Posted: Mon Aug 07, 2006 3:54 pm Post subject: 912ULS - Oil in Exhaust |
John,
Sounds like a good time for a compression check....
Stuck ring? Valve guide?
Some might give it a good hard run and see if this
brings it back to normal. Just sitting is hard on
planes.
Kurt S.
--- John Banes <JohnBanes(at)Adelphia.net> wrote:
| Quote: | The engine had not been operated for 5 weeks.
was hand propped,
several times, just
smoke or oil.
Thanks in advance!
John Banes
Jim Shumaker
Posted: Mon Aug 07, 2006 4:26 pm Post subject: 912ULS - Oil in Exhaust |
John
The oil reservoir in the kitfox is above the engine. The oil siphons into the crankcase while sitting. Some oil also leaks past the rings and into the cylinder. Pulling the prop through by hand before starting prevented hydraulic lock but some oil made it to the exhaust manifold where it sputtered out the exhaust during start up. The oil turned to smoke as the engine warmed up. No smoke after that is a good sign. As Kurt said, a compression check is in order.
Jim Shumaker
[quote] The engine had not been operated for 5 weeks.
was hand propped,
several times, just
_________________ Jim Shumaker |
Posted: Mon Aug 14, 2006 6:57 pm Post subject: 912ULS - Oil in Exhaust |
Thanks Jim, Kurt and David!
John
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of James Shumaker
Sent: Monday, August 07, 2006 7:26 PM
Subject: Re: 912ULS - Oil in Exhaust
John
Jim Shumaker
> was hand propped,
> several times, just
