endspeed(at)yahoo.com Guest
Posted: Fri Aug 04, 2006 8:56 am Post subject: Alternator seizure engine failure |
Hi Brian, I have meant to throw cudos your way on the
predicted bearing failure/seizure's catastrophic
effect on an engine. I thought this was a very remote
failure possibility when you postulated about it.
Then, sure enough it goes and happens to one of our
posters. Good forethought on your part. Bob
Sultzbach
brian
Joined: 02 Jan 2006 Posts: 643 Location: Sacramento, California, USA
Posted: Fri Aug 04, 2006 12:48 pm Post subject: Alternator seizure engine failure |
On Aug 4, 2006, at 12:52 PM, Robert Sultzbach wrote:
Quote: |
<endspeed(at)yahoo.com>
Sultzbach
Thanks. I certainly didn't want to be proved right in the way that it
happened.
On to the details, you probably want a belt that will fail and allow
the engine to keep running rather than kill the engine.
A 50A 14V alternator is producing 700W at full output. If the
alternator is 90% efficient it needs 770W of mechanical input. One HP
is 760W. So you need a belt that will handle 1HP. That is not a very
big belt. You sure don't need dual belts. If the alternator seizes
the smaller belt will fail and your engine keeps running to carry you
to a safe landing.
Now someone who knows belts should jump in here with belt sizing
information to cover the transmission of 1HP.
Brian Lloyd 361 Catterline Way
brian-yak AT lloyd DOT com Folsom, CA 95630
— Antoine de Saint-Exupéry
_________________ Brian Lloyd
brian-yak at lloyd dot com
- Antoine de Saint-Exupery |
paulm(at)olypen.com Guest
Posted: Fri Aug 04, 2006 2:45 pm Post subject: Alternator seizure engine failure |
First 90% efficiency (for a 1970 alternator design) is in your dreams, try
in the mid 70's but the main point is with "V" belts the belt tension needs
to be high with an engine rpm of 6,000 and a single "V" based on the design
of belts available 15-20 years ago. The subject engine is an EA81 that needs
a light belt tension to prevent water pump bearing failure from too high but
common belt tension. The tension must be high enough so there is no slippage
under any expected load condition. Also remember the water pump is part of
the belt load and finally you must consider the pulley to belt contact arc
to transmit the load from the crank to the pump and alternator in a 3 pulley
setup.
Thus the manufacturer of the conversion decided on dual belts with light
tension as friction did the rest. This was to prevent a common failure at
the time of water pump bearing wear and loss of coolant.
Its not easy to design a "V" belt that will slip on the one hand and not
require high belt tension for its friction drive. Also consider in this
application the crank to alternator pulley ratio is around 1-1.4 . Further
throttled back it does not take much and with a "Sprague" clutch driving the
prop (no inertial help here) and a very light flywheel there is little
inertia to help. The specific belts are narrow with machined sides not the
cloth covered ones of the era. There is no way the belt will snap if its in
good condition until its been heated and burned thru. Again there was no
chance of this here as the engine stopped immediately.
In addition there are around 700+ such dual belt conversions with over
100,000 flight hours (some with over 4,000 hours) and this is the first
known failure of its type. Hardly a bad design based on actual performance.
I have the specific dual belt system on my own engine so I do know the
actual situation.
Good luck in finding a belt that acts like a fuse and instantly self
destructs at 200% of design load but lasts 1,000 hours at 100% of design
load.
The very common cogged timing belt widely used in modern auto engines can
fail and if it does the engine stops. If the idler fails the belt slips the
cogs and the engine fails. On an aircraft engine if an accessory case driven
unit fails and locks up the engine likely will fail fast from major metal
parts internal to the accessory case.
I believe the "result of the failure" is being addressed by your comment and
you are missing the "real likely cause" which is a bad bearing from the use
of a rebuilt alternator. 80 hours was the total time on the engine and also
the alternator since rebuild where is not common to replace the bearings.
Paul
brian
Posted: Fri Aug 04, 2006 4:28 pm Post subject: Alternator seizure engine failure |
Paul Messinger wrote:
Quote: |
<paulm(at)olypen.com>
try in the mid 70's but the main point is with "V" belts the belt
tension needs to be high with an engine rpm of 6,000 and a single "V"
based on the design of belts available 15-20 years ago. The subject
engine is an EA81 that needs a light belt tension to prevent water pump
bearing failure from too high but common belt tension. The tension must
be high enough so there is no slippage under any expected load
condition. Also remember the water pump is part of the belt load and
finally you must consider the pulley to belt contact arc to transmit the
load from the crank to the pump and alternator in a 3 pulley setup.
Well I was thinking in terms of a Lycoming engine wherein the belt
drives the alternator and only the alternator.
But, I am glad you chimed in here because, frankly, I don't know squat
about belt drives beyond the obvious and would not pretend otherwise.
brian-yak at lloyd dot com Folsom, CA 95630
N6030X(at)DaveMorris.com Guest
Posted: Fri Aug 04, 2006 4:42 pm Post subject: Alternator seizure engine failure |
Sounds like a more reliable approach for vehicles
that can't "pull over to the side of the road" in
case of failure would be to mount 2 alternators
with 1/2 the current capacity each, driven by 2
separate belts neither of which require the kind
of tension that would seize the engine or burn out the bearings.
Dave Morris
design) is in your dreams, try in the mid 70's
6,000 and a single "V" based on the design of
slippage under any expected load condition. Also
contact arc to transmit the load from the crank
on dual belts with light tension as friction did
at the time of water pump bearing wear and loss of coolant.
on the one hand and not require high belt
this application the crank to alternator pulley
ratio is around 1-1.4 . Further throttled back
clutch driving the prop (no inertial help here)
with machined sides not the cloth covered ones
if its in good condition until its been heated
and burned thru. Again there was no chance of
conversions with over 100,000 flight hours (some
engine so I do know the actual situation.
fuse and instantly self destructs at 200% of
design load but lasts 1,000 hours at 100% of design load.
in modern auto engines can fail and if it does
slips the cogs and the engine fails. On an
aircraft engine if an accessory case driven unit
fast from major metal parts internal to the accessory case.
addressed by your comment and you are missing
from the use of a rebuilt alternator. 80 hours
was the total time on the engine and also the
Paul
chaztuna(at)adelphia.net Guest
Posted: Fri Aug 04, 2006 6:53 pm Post subject: Alternator seizure engine failure |
Dave,
This is one of those, "it looked good on paper" ideas. The reality is that if both alternators are driven off the front of the engine, losing the belt on one, generally takes out the other alternator. When a belt fails, it often gets tangled up in any near by pulleys and belts. This will derail or destroy the belt for the second alternator.
Bob N's recommendation of a rear drive (Lycoming engine) secondary alternator (like the B&C units) is a safer bet.
Charlie Kuss
[quote]--> AeroElectric-List message posted by: Dave N6030X <N6030X(at)DaveMorris.com>
Sounds like a more reliable approach for vehicles that can't "pull over to the side of the road" in case of failure would be to mount 2 alternators with 1/2 the current capacity each, driven by 2 separate belts neither of which require the kind of tension that would seize the engine or burn out the bearings.
Dave Morris
[quote]--> AeroElectric-List message posted by: "Paul Messinger" <paulm(at)olypen.com>
First 90% efficiency (for a 1970 alternator design) is in your dreams, try in the mid 70's but the main point is with "V" belts the belt tension needs to be high with an engine rpm of 6,000 and a single "V" based on the design of belts available 15-20 years ago. The subject engine is an EA81 that needs a light belt tension to prevent water pump bearing failure from too high but common belt tension. The tension must be high enough so there is no slippage under any expected load condition. Also remember the water pump is part of the belt load and finally you must consider the pulley to belt contact arc to transmit the load from the crank to the pump and alternator in a 3 pulley setup.
Thus the manufacturer of the conversion decided on dual belts with light tension as friction did the rest. This was to prevent a common failure at the time of water pump bearing wear and loss of coolant.
Its not easy to design a "V" belt that will slip on the one hand and not require high belt tension for its friction drive. Also consider in this application the crank to alternator pulley ratio is around 1-1.4 . Further throttled back it does not take much and with a "Sprague" clutch driving the prop (no inertial help here) and a very light flywheel there is little inertia to help. The specific belts are narrow with machined sides not the cloth covered ones of the era. There is no way the belt will snap if its in good condition until its been heated and burned thru. Again there was no chance of this here as the engine stopped immediately.
In addition there are around 700+ such dual belt conversions with over 100,000 flight hours (some with over 4,000 hours) and this is the first known failure of its type. Hardly a bad design based on actual performance.
I have the specific dual belt system on my own engine so I do know the actual situation.
Good luck in finding a belt that acts like a fuse and instantly self destructs at 200% of design load but lasts 1,000 hours at 100% of design load.
The very common cogged timing belt widely used in modern auto engines can fail and if it does the engine stops. If the idler fails the belt slips the cogs and the engine fails. On an aircraft engine if an accessory case driven unit fails and locks up the engine likely will fail fast from major metal parts internal to the accessory case.
I believe the "result of the failure" is being addressed by your comment and you are missing the "real likely cause" which is a bad bearing from the use of a rebuilt alternator. 80 hours was the total time on the engine and also the alternator since rebuild where is not common to replace the bearings.
Paul
Posted: Fri Aug 04, 2006 7:22 pm Post subject: Alternator seizure engine failure |
So, what happens in the case of a gear-driven
alternator when it seizes up? Does it shred the
whole back end of the Lycoming?
Dave
At 09:45 PM 8/4/2006, you wrote:
[quote]Dave,
Charlie Kuss
>Dave Morris
>>Paul
oldbob(at)BeechOwners.com Guest
Posted: Fri Aug 04, 2006 7:42 pm Post subject: Alternator seizure engine failure |
Good Evening Dave,
I do not remember for sure, but I think B&C uses a
shear coupling on their alternator that is designed to
be driven off of an accessory pad on the Lycoming
which otherwise generally drives a vacuum pump.
Anyone know for sure?
Happy Skies,
Old Bob
Dave
>Dave,
>Charlie Kuss
>>Dave Morris
a 3 pulley setup.
design load.
accessory case.
>>>Paul
Posted: Fri Aug 04, 2006 7:48 pm Post subject: Alternator seizure engine failure |
Good Evening Once Again Dave,
Just checked and the B&C does include a shear drive
unit.
Happy Skies,
Old Bob
Dave
>Dave,
>Charlie Kuss
>>Dave Morris
a 3 pulley setup.
design load.
accessory case.
>>>Paul
Posted: Fri Aug 04, 2006 7:55 pm Post subject: Alternator seizure engine failure |
I agree that a LYC belt drive is a different issue and not likely to be a
problem with a frozen bearing.
My point is the specific subject auto engine conversion is very different.
Lots of trades to consider and no perfect solution.
But as you pointed out some time ago bearing failure in a locked failure
mode can happen however rare it might be.
I might point out the Subaru engine has demonstrated the ability to run for
as long as 30 min with No coolant so if the engine can be kept running its
possible to land safely. The key is using the prop inertia of a non clutch
drive and / or a reasonable sized flywheel to force the belt to start
slipping. In this case the manufacturer chose to assume the bearing lock up
was less likely than a belt failure and or the pump leaking from belt side
load.
Since the original design the use of dual belts has been questionable in
auto engine conversions including the belt reduction designs. Stratus for
example has had several dual belt failures where one belt failed and then
took out the other belt and went to a single wider belt. Eggenfelner
recently had a multi belt reduction unit fail all the belts from a single
FOD starting with a single belt that progressed to the rest of the belts and
dropped the design.
Perhaps a single belt under slightly more tension is a better way to go and
risk water pump leakage on this specific application. I have considered this
and am considering a single belt as its simple to do and pump shaft leakage
is a slow failure and thus simple to detect the loss of coolant before its a
serious risk to the engine. In any event its better than a locked engine and
becoming a glider where I live. Lets see; 95% of the time its a stump farm,
high trees, rough mountain sides, or cold seas for landing sites.
The trades in an auto engine conversion are many. Here the Sprague clutch
allowed a saving of 20 pounds of flywheel to reduce the torsional loads from
a 4 cyl engine. Much the same as the flywheel on Lyc vs no flywheel on the
Cont where the torsionals are different due to basic engine design. Or the
Cont trade of accessory gear drive for the alternator vs the Lyc belt drive.
Different solutions from different designers.
No criticism of your comments just a clarification of the exact
configuration of the failure and its effects. I would not expect that 99% of
this list members know the specific design of the subject system.
Just as we would not consider using a used crank with out magniflux etc, we
should not use a repaired alternator without new HI quality bearings.
Paul
brian
Posted: Sat Aug 05, 2006 5:29 am Post subject: Alternator seizure engine failure |
On Aug 4, 2006, at 11:40 PM, OldBob Siegfried wrote:
Quote: |
<oldbob(at)beechowners.com>
Good Evening Dave,
Yes, they do.
In fact, I have just heard of my first B&C alternator failure because
the shear coupling failed. (It happened on a friend's CJ6A.) Seems
B&C is now using a slightly stronger shear coupling and is providing
a retrofit for older units.
Posted: Sat Aug 05, 2006 5:36 am Post subject: Alternator seizure engine failure |
Paul,
I agree that use of known, high quality parts is the smart thing to do. I have some knowledge of the Subaru engine (professional auto mechanic) but don't claim to be a Subaru expert. Have you considered installation of an "outboard" support bearing (with related shaft) to aid in support of the water pump?
If the water pump pulley was originally fitted with a cooling fan (probably not) a stub axle could be attached to this surface to support an outboard bearing. Failing that, a custom pulley could be machined to facilitate an outboard support bearing.
Charlie Kuss
Quote: | --> AeroElectric-List message posted by: "Paul Messinger" <paulm(at)olypen.com>
I agree that a LYC belt drive is a different issue and not likely to be a problem with a frozen bearing.
My point is the specific subject auto engine conversion is very different. Lots of trades to consider and no perfect solution.
But as you pointed out some time ago bearing failure in a locked failure mode can happen however rare it might be.
I might point out the Subaru engine has demonstrated the ability to run for as long as 30 min with No coolant so if the engine can be kept running its possible to land safely. The key is using the prop inertia of a non clutch drive and / or a reasonable sized flywheel to force the belt to start slipping. In this case the manufacturer chose to assume the bearing lock up was less likely than a belt failure and or the pump leaking from belt side load.
Since the original design the use of dual belts has been questionable in auto engine conversions including the belt reduction designs. Stratus for example has had several dual belt failures where one belt failed and then took out the other belt and went to a single wider belt. Eggenfelner recently had a multi belt reduction unit fail all the belts from a single FOD starting with a single belt that progressed to the rest of the belts and dropped the design.
Perhaps a single belt under slightly more tension is a better way to go and risk water pump leakage on this specific application. I have considered this and am considering a single belt as its simple to do and pump shaft leakage is a slow failure and thus simple to detect the loss of coolant before its a serious risk to the engine. In any event its better than a locked engine and becoming a glider where I live. Lets see; 95% of the time its a stump farm, high trees, rough mountain sides, or cold seas for landing sites.
The trades in an auto engine conversion are many. Here the Sprague clutch allowed a saving of 20 pounds of flywheel to reduce the torsional loads from a 4 cyl engine. Much the same as the flywheel on Lyc vs no flywheel on the Cont where the torsionals are different due to basic engine design. Or the Cont trade of accessory gear drive for the alternator vs the Lyc belt drive. Different solutions from different designers.
No criticism of your comments just a clarification of the exact configuration of the failure and its effects. I would not expect that 99% of this list members know the specific design of the subject system.
Just as we would not consider using a used crank with out magniflux etc, we should not use a repaired alternator without new HI quality bearings.
Paul | snipped
brian
On Aug 4, 2006, at 11:54 PM, Paul Messinger wrote:
Quote: | No criticism of your comments just a clarification of the exact
subject system.
No problem and no criticism perceived on this end. I know a fair bit
about a fair bit and do have a tendency to "think out loud" but I do
try to avoid what my ex-wife used to call "male answer
syndrome" (MAS), i.e. the need to come up with an answer even if you
haven't got one. I find that the phrase, "I don't know but I will
find out," works pretty well, especially with children.
(BTW, after meeting some women with MAS I changed the acronym to be
"must-answer syndrome.")
bearings.
Makes sense to me.
Posted: Sat Aug 05, 2006 6:14 am Post subject: Alternator seizure engine failure |
LOL!!! That's great Brian!
It just hit me!
There are no women on aviation internet forums!!!
We're here to answer each other's questions, even if we don't have
the answer!!!
(slapping head)
Wow.
Dave
At 08:34 AM 8/5/2006, you wrote:
Quote: |
but I do
haven't got one.
Posted: Sat Aug 05, 2006 8:27 am Post subject: Alternator seizure engine failure |
The pulley is deep dished and the belt0 groove is actually slightly inside the span of the shaft bearings.
The problem with outer third bearings0 is alignment. This is a major problem with reduction units that have a hard0 coupling to the crank and in theory an outer bearing helps the cog belt side0 load. In fact it usually promotes failure as the TIR of the outer support must0 be less than 0.0005" over all conditions or it will add to the crank bearing0 load.
Frankly I believe there is no real0 concern with the water pump bearing failure but clearly some are worried. I have0 torn down over a dozen subaru engines and none had pump shaft wear that I could0 see. Brand new pumps are available and not expensive so its no big deal to start0 with new parts.
I was only relating the stated reason0 (by the mfgr) for the dual belts as well as the idea of redundancy. The reason I0 chose to put the pulley set with dual belts is the changed pully ratios better0 suited to the higher average rpm of the auto conversion. The original concept of0 dual belts for redundancy has been demonstrated to be false as one belt failure0 usually takes out the other. Not unlike the light twin engined aircraft where0 one engine failure overstresses (in this case) the pilot and the aircraft0 crashes..
Paul
brian
Posted: Sat Aug 05, 2006 10:32 am Post subject: Alternator seizure engine failure |
It just hit me!
Well, there are a few and it is usually worth paying attention when
they speak.
the answer!!!
(slapping head)
Wow.
Yeah, it is funny but it is scary at the same time. There is another
variation of MAS that is addressed by, "just because you can doesn't
mean you should."
Posted: Sat Aug 05, 2006 10:53 am Post subject: Alternator seizure engine failure |
Paul
Is TIR engineer speak for "total included run out"?
Charlie Kuss
---- Paul Messinger <paulm(at)olypen.com> wrote:
[quote] The pulley is deep dished and the belt groove is actually slightly inside
The problem with outer third bearings is alignment. This is a major problem
with reduction units that have a hard coupling to the crank and in theory an
outer bearing helps the cog belt side load. In fact it usually promotes
failure as the TIR of the outer support must be less than 0.0005" over all
conditions or it will add to the crank bearing load.
Frankly I believe there is no real concern with the water pump bearing
failure but clearly some are worried. I have torn down over a dozen subaru
engines and none had pump shaft wear that I could see. Brand new pumps are
available and not expensive so its no big deal to start with new parts.
I was only relating the stated reason (by the mfgr) for the dual belts as
well as the idea of redundancy. The reason I chose to put the pulley set
with dual belts is the changed pully ratios better suited to the higher
average rpm of the auto conversion. The original concept of dual belts for
redundancy has been demonstrated to be false as one belt failure usually
takes out the other. Not unlike the light twin engined aircraft where one
crashes..
Paul
Bob McC
Posted: Sat Aug 05, 2006 11:53 am Post subject: Alternator seizure engine failure |
total indicator runout
Bob McC
_________________ Bob McC
Falco #908
(just starting) |
gmcjetpilot(at)yahoo.com Guest
Posted: Sat Aug 05, 2006 12:13 pm Post subject: Alternator seizure engine failure |
This is semi related.
I had a generator seize once on a light twin, PA-23-160 Apache.
It was a non event and smelled (burned rubber).
Fortunitly it was on the ground. The engine started and
I got a wiff of something burning.
Shut down, investigated and found a smoking belt. Too hot
to touch, it was a very soft pathetic looking belt but still on.
The V-belt pulleys on my Lyc flywheel pulley are deep as
on that generator. The belt is so short I doubt it would come
off a sized alt/gen.
I suppose if the engine continues to run it could burn thru
the belt or possibly start a fire worse case? My guess is
it would just get hot, melt and make more slack and just
rub and wear away. That is what happened to me. It was
just running around the Gen pulley and was very loose.
But who really knows all the possible senerios there are.
On the Apache the metal cowl is wide open and the belt
is cooled. In a homebuilt the belt is shielded from incoming
air and covered in a flammable fiberglass cowl.
George
Get on board. [url=http://us.rd.yahoo.com/evt=40791/*http://advision.webevents.yahoo.com/handraisers]You're invited[/url] to try the new Yahoo! Mail Beta.
Posted: Sat Aug 05, 2006 3:36 pm Post subject: Alternator seizure engine failure |
Please do make general0 statements.
My auto conversion has the alternator0 cooled by direct inlet air and its in a aluminum cowl. I will grant you some of0 the belt is semi shielded but not all.
Paul
