Trim Tab
pdwalter(at)bigpond.net.a
PostPosted: Wed Jan 18, 2006 9:02 pm    Post subject: Trim Tab Reply with quote
Hi Guys,
I was wondering when riveting trim hinge to trim tab if all three items being the skin, hinges and trim tab spar are dimpled or is hinge countersunk ?
Thank you
Paul Walter
dan(at)rvproject.com
PostPosted: Wed Jan 18, 2006 9:49 pm    Post subject: Trim Tab Reply with quote
IIRC, dimple the skin, c-sink the spar, and don't do diddly to the hinge.
Same setup when you rivet the flap hinge to the wing.  Wing skin is dimpled, brace is c-sunk, hinge is left alone.
)_( Dan
RV-7 N714D
http://www.rvproject.com
rv6capt(at)pacificcoast.n
Dimple skins countersink hinge.
Norman
Paul Walter wrote:
Hi Guys,
countersunk ?
Thank you
Paul Walter
PostPosted: Wed Jan 18, 2006 10:29 pm    Post subject: Trim Tab Reply with quote
Thanks Dan,
Also, with rod end bearing for attaching elevator to HS. To get all perfectly in line did you just count the amount of rotations on each as it threads into the plate nut ?.
Regards  - Paul
PostPosted: Wed Jan 18, 2006 11:01 pm    Post subject: Trim Tab Reply with quote
Sort of.  Van's plans call out suggested dimensions for the rod end bearing, distance from the spar or something like that.
My 2 cents is -- don't sweat it until you're ready to mount the rudder on the VS permanently.  Then you just make sure you have (a) alignment of all the rod ends with the hinge brackets, (b) rod ends adjusted to provide full range of rudder travel without any chafing or interference, (c) counterweight arm is aligned with the top of the VS and doesn't interfere.
)_( Dan
PostPosted: Thu Jan 19, 2006 12:11 am    Post subject: Trim Tab Reply with quote
Thank you Dan,
That is how it will be done.
Paul
fvalarm(at)rapidnet.net
PostPosted: Thu Jan 19, 2006 1:56 pm    Post subject: Trim Tab Reply with quote
I'm just now working on mating the elevators to the horizontal stab.  I have initially set the rod end bearings as per the plans.  I'm getting ready to drill the elevator control horns but they are not square to the main center bearing or to each other. I was just about to email Vans (as the plans don't go into much detail here) when I saw this thread.  Are the elevator rod end bearings supposed to be adjusted until the horns are square?  This would mean each rod end bearing will be a different measurement from the spar and the counter-balance arms will not be exactly parallel to the horizontal stab as they are now.  What have others done here?
Bevan
RV7A
From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Paul Walter
Sent: Thursday, January 19, 2006 12:10 AM
To: rv7-list(at)matronics.com
Subject: Re: Trim Tab
Thank you Dan,
Paul
