Tablet
greg(at)bandc.biz
PostPosted: Mon Aug 07, 2006 5:36 am    Post subject: Tablet Reply with quote
For those of you who are experiencing trouble booting from a flash drive, you must enable the boot option off a usb or external drive within your BIOS. Usually to get into the BIOS you must press the DEL key, F1 key or another key depending on which motherboard or BIOS you have. Once you turn on your system, look for the message which tells you what key to press to enter into the System Setup or BIOS. Best wishes!
