wsknettl(at)centurytel.ne Guest
Posted: Tue Aug 08, 2006 5:08 am Post subject: DC generators |
Hello,
Can someone from yesteryear confirm that a Cessna with a 50 amp
generator, 35 amp regulator and 35 amp main generator CB will not self
destruct.
Wes K
Hopperdhh(at)aol.com Guest
Posted: Tue Aug 08, 2006 9:06 am Post subject: DC generators |
Wes,
I guess I qualify. It seems like the 50 amp generator should be very0 safe with a 35 amp regulator.
Of course, this assumes that the regulator is adjusted right. I would0 think that the 35 amp CB would trip is this is not the case.
I could make wise cracks here, but I'll leave that for someone0 else!
Dan Hopper
Automotive Electrical Engineer, Ret.
In a message dated 8/8/2006 9:12:19 A.M. Eastern Daylight Time,0 wsknettl(at)centurytel.net writes:
-->0 AeroElectric-List message posted by: Wes K0 <wsknettl(at)centurytel.net>
Hello,
Can someone from yesteryear0 confirm that a Cessna with a 50 amp
generator, 35 amp regulator and 35 amp0 main generator CB will not self
destruct.
Wes0 ========================== Use0 lities0 Day0 0 0
-->0 ================================================== - NEW MATRONICS LIST WIKI -
_-=0 sp;0 0 ->0 =========================p;0 - List Contribution Web Site0 0 0 ==================================================
[/quote]
nuckollsr(at)cox.net Guest
Posted: Tue Aug 08, 2006 9:15 am Post subject: DC generators |
At 08:04 AM 8/8/2006 -0500, you wrote:
Hello,
Can someone from yesteryear confirm that a Cessna with a 50 amp generator,
35 amp regulator and 35 amp main generator CB will not self destruct.
The breaker seems undersized. There's no risk of "destruction" but
a slight risk for nuisance tripping along with an inability to utilize
the generator's full output capability due to the overly protective
regulator.
But if the present setup has been working "okay", there's probably
no pressing reason to mess with it.
< What is so wonderful about scientific truth...is that >
< the authority which determines whether there can be >
< debate or not does not reside in some fraternity of >
< scientists; nor is it divine. The authority rests >
< with experiment. >
< --Lawrence M. Krauss >
brian
Joined: 02 Jan 2006 Posts: 643 Location: Sacramento, California, USA
Posted: Tue Aug 08, 2006 9:44 am Post subject: DC generators |
On Aug 8, 2006, at 9:04 AM, Wes K wrote:
Hello,
self destruct.
It will not self destruct. The over-current relay in the regulator
will open at 35A and reduce the field current, reducing output. All
you will see is the generator switch from constant voltage to
constant current and the bus voltage will then drop.
The breaker sounds a bit undersized to me. You might get nuisance
trips but if it is working, who am I to fight with success.
Brian Lloyd 361 Catterline Way
brian-yak AT lloyd DOT com Folsom, CA 95630
— Antoine de Saint-Exupéry
_________________ Brian Lloyd
brian-yak at lloyd dot com
- Antoine de Saint-Exupery |
Posted: Wed Aug 09, 2006 6:31 am Post subject: DC Generators |
Hello,
Thanks for the quick replies. I assumed as much but wanted to be sure I
wasn't overlooking anything. In this case someone in the past installed
the wrong generator. I was sure the 35 amp generator would not work with
50 amp periphials safely but was not 100 percent sure on the 50 amp
generator with 35 amp peripheals.
Thanks agian,
Wes K
