CardinalNSB(at)aol.com Guest
Posted: Fri Aug 04, 2006 12:35 am Post subject: use of toggle switch breakers |
My certified aircraft uses little square cheap type breakers, and rocker0 switches for certain items. I plan to replace the breaker and rocker0 switch with a Potter and Brumfield "toggle switch/breaker combination". I0 plan to use the same amp toggle switch breaker as the circuit breaker I am0 replacing. I plan to do this for the landing light, taxi light, nav0 lights, beacon, pitot heat, and fuel pump. My ap is ok with this as a0 minor modification.
Does anyone recommend against this plan, and why? Thank you, Skip0 Simpson
FLYaDIVE(at)aol.com Guest
Posted: Fri Aug 04, 2006 1:59 am Post subject: use of toggle switch breakers |
In a message dated 8/4/06 4:39:00 AM Eastern Daylight Time,
CardinalNSB(at)aol.com writes:
| Quote: | My certified aircraft uses little square cheap type breakers, and rocker
plan to
| Quote: | use the same amp toggle switch breaker as the circuit breaker I am
replacing.
| Quote: | I plan to do this for the landing light, taxi light, nav lights, beacon,
pitot heat, and fuel pump. My ap is ok with this as a minor modification.
Does anyone recommend against this plan, and why? Thank you, Skip Simpson
Skip:
Not at all. It is a good way to kill two birds with one stone. Maybe even
three birds:
1 - You replace old switches with new.
2 - You eliminate an old style fuse/breaker and replace with new
3 - And you also eliminate an additional failure point.
As far as it being Minor Modification ... I don't think so. but, the
important part is your A&P does thin it is. You will find out about that when you
submit the 337. I would write it up as a Minor and let the FAA sort it out.
REMEMBER! You will have to change the wiring at the Old CB / Fuse You will have
to bypass the old and remove the Old and also add placards for the switches
showing CB Amperage.
Barry
"Chop'd Liver"
"Show them the first time, correct them the second time, kick them the third
time."
Yamashiada
oldbob(at)beechowners.com Guest
Posted: Fri Aug 04, 2006 4:13 am Post subject: use of toggle switch breakers |
Good Morning Barry,
If you don't mind, may I make a small comment?
I will not attempt to make a determination as to
whether or not the proposed alteration is minor or
major, but will add that no 337 needs to be filed for
a minor alteration.
The determination can be made by the appropriately
certificated technician making the change.
He or she is required to state what has been done by
making an entry in the appropriate ship's papers.
There is always the possibility that some authorized
person such as an A&P holding an IA may later decide
that the installation is not minor and refuse to
declare the aircraft as airworthy. I would, therefor,
suggest that whoever is going to annual the airplane
be consulted. If the A&P who is going to authorize the
change is also the IA who is going to perform the
annual inspection, forget the 337!
Happy Skies,
Old bob
--- FLYaDIVE(at)aol.com wrote:
FLYaDIVE(at)aol.com
Daylight Time,
plan to
replacing.
Skip:
three birds:
replace with new
point.
think so. but, the
Barry
"Chop'd Liver"
time."
Yamashiada
browse
Subscriptions page,
FAQ,
Admin.
Kellym
Posted: Fri Aug 04, 2006 7:44 am Post subject: use of toggle switch breakers |
P&B's were used for years in Mooney's. They do become weak and trip
early, after, oh say 30+ years. Otherwise, much easier to use. Be
certain of physical dimension fit, both front to back and side to side.
Read Part 43 Appendix A carefully as to minor vs major mod. Consult
with the IA you plan to use for your next annual. He is the person
that you need to buy into the project. Or at a minimum, have your A&P
discuss it with him.
Minor modifications are not written up on 337s. If you have doubt, at
least in your FSDO area, have your A&P write it up as a 337 field
approval and submit to FSDO for signature before any work starts. That
way you get approval or told not needed from your FSDO.
Quoting FLYaDIVE(at)aol.com:
| Quote: | Skip:
three birds:
that when you
You will have
Barry
"Chop'd Liver"
time."
Yamashiada
KCHD |
Bill Denton
Joined: 10 Jan 2006 Posts: 97 Location: Chicago, IL USA
Posted: Fri Aug 04, 2006 8:26 am Post subject: use of toggle switch breakers |
RE: "...also add placards for the switches showing CB Amperage."
The P&B W31 Toggle Switch/Breakers have the amp rating engraved on the end
of the toggle...
Posted: Fri Aug 04, 2006 4:17 pm Post subject: use of toggle switch breakers |
In a message dated 8/4/06 12:31:26 PM Eastern Daylight Time,
bdenton(at)bdenton.com writes:
| Quote: | RE: "...also add placards for the switches showing CB Amperage."
of the toggle...
True, there is an engraving but it is not very visible ... Not to these old
eyes and very difficult to see at night.
I just redid all the placards on the RV-6A with a brother P-Touch and black
tape. WOW looks very nice. Maybe not OSH 1st place quality but very nice.
Barry
"Chop'd Liver"
time."
Yamashiada
brian
Joined: 02 Jan 2006 Posts: 643 Location: Sacramento, California, USA
Posted: Sat Aug 05, 2006 5:26 am Post subject: use of toggle switch breakers |
On Aug 4, 2006, at 8:16 PM, FLYaDIVE(at)aol.com wrote:
> on the end
> of the toggle...
these old
Why would it be important to read the trip value of a breaker in
flight? You would want to be able to read it to be sure you installed
the correct breaker on the correct circuit but after that, what does
it matter?
Now labeling the circuit is another matter.
Brian Lloyd 361 Catterline Way
brian-yak AT lloyd DOT com Folsom, CA 95630
— Antoine de Saint-Exupéry
_________________ Brian Lloyd
brian-yak at lloyd dot com
- Antoine de Saint-Exupery |
Posted: Wed Aug 09, 2006 8:48 am Post subject: use of toggle switch breakers |
In a message dated 8/4/06 8:18:13 AM Eastern Daylight Time,
oldbob(at)beechowners.com writes:
| Quote: | Good Morning Barry,
a minor alteration.
Happy Skies,
Old bob
Hello Old Bob:
If it is a GA aircraft it would be a MAJOR alteration. Since you are
changing the wiring configuration. It would not match the submitted drawing for the
plane.
As for 337's, I don't see why people are scared of them. There is a simple
16 question outline that must be followed. And there are provisions where if
you think there may be a problem getting a 337 approved you submit a request.
I really like 337's and use them all the time. They are a GREAT way to keep
track of a plane by showing what was done and it adds to the value when selling.
Just because one A&P/I may accept a 'gray area' alteration does not mean the
next guy will. A simple 337 eliminates the 'gray area'.
Barry
"Chop'd Liver"
time."
Yamashiada
oldbob(at)BeechOwners.com Guest
Posted: Wed Aug 09, 2006 9:51 am Post subject: use of toggle switch breakers |
Good Afternoon Barry,
Once Again, I am not making any decision as to whether
or not the modification in question is major or minor.
That is totally a decision to be made by the
authorized person making the decision.
I gladly defer to his or her judgment.
However, I strongly disagree with the following
statement:
"Just because one A&P/I may accept a 'gray area'
alteration does not mean the next guy will. A simple
337 eliminates the 'gray area'."
Filing a 337 does not change the legality or the
potential for discussion.
There is no 16 step set of directions needed to file a
337. The 16 point guide is for the "Instructions for
Continued Airworthiness" that is to be filed if a
local approval is requested.
A routine 337 is to be filed for many reasons, but the
ICA requirement only applies if a local approval or
multiple time STC is being applied for.
Filing a 337 for a minor alteration is asking the FAA
to make a decision that should be made by the
responsible technician. If you don't know what your
authority is, maybe you should not be making such
decisions?
I do agree with you that applying for a local approval
is a relatively simple procedure, though getting the
approval has become more difficult than it was in the
past. I also agree that if you do intend to ask for a
local approval, it is best to supply a proposed
solution before any "metal is cut".
Happy Skies,
Old "Successful at several local approvals" Bob
FLYaDIVE(at)aol.com
Daylight Time,
> Good Morning Barry,
or
for
> a minor alteration.
appropriately
by
authorized
decide
therefor,
airplane
authorize the
> Happy Skies,
> Old bob
Hello Old Bob:
plane.
area'.
Barry
"Chop'd Liver"
time."
Yamashiada
browse
Subscriptions page,
FAQ,
(was 2MB)
Web Forums!
Admin.
Kellym
Posted: Wed Aug 09, 2006 10:35 am Post subject: use of toggle switch breakers |
What you say is nice in theory. However, I have yet to work on a TC
aircraft that has 337s with circuit diagrams available, nor does
changing the actual circuitry necessarily constitute a major
alteration unless it fits the definition in Part 43 Appendix A. If the
change is transparent to the pilot and doesn't affect how the plane is
operated, it isn't necessarily major. Will also depend a lot on the
local FSDO. Some would want a 337 if you changed brands of circuit
breaker, while others don't want to even talk to you unless the change
is meaningful in the Appendix A context.
In fact I have worked on a lot of wiring done by FAA certified
avionics repair stations that doesn't come close to meeting the
guidance in 43-13-1B and 2A, with 337s filed, that I would still
reject as unairworthy if I were doing the inspection.
KM
A&P/IA
| Quote: | Hello Old Bob:
drawing for the
plane.
when selling.
Barry
"Chop'd Liver"
time."
Yamashiada
KCHD |
Posted: Wed Aug 09, 2006 12:16 pm Post subject: use of toggle switch breakers |
In a message dated 8/9/06 2:39:27 PM Eastern Daylight Time,
kellym(at)aviating.com writes:
| Quote: | In fact I have worked on a lot of wiring done by FAA certified
KM
A&P/IA
Kelly:
Good for you ... I have also. How about 4 crimp on splices in a 2 ft run!
Barry
"Chop'd Liver"
time."
Yamashiada
