Tom O'Hara
Posted: Mon Apr 23, 2007 9:25 am Post subject: Help-- High Voltage? |
First, let me say that I am a buyer/flyer not a builder/flyer. Purchased a MKIII a year and a half ago and have been having a ball. I believe it is the first one out of the TN plant.
Saturday I went out for a flight and had an EIS warning light come on--- voltage. Currently the EIS is set for 11.2 to 14.6 volts acceptable range. I was running 16.2 to 17.4.
Are the set points correct?
Where should I start trouble shooting?
What are the consequences of the high voltage?
by0ung(at)brigham.net Guest
Posted: Mon Apr 23, 2007 9:59 am Post subject: Help-- High Voltage? |
I think I would set the lower range to 11.8V the 14.6 seems ok. Lead acid
batteries are considered discharged at 11.8 V
If you are running 16.2 to 17.4 the first thing I would do is compare it to
another volt meter, if it is still that high I would check the battery, or
the voltage regulator/ rectifier. I would compare the voltage without
starting up the engine... no need of having the last test be the one to let
the smoke out.
You do know about the smoke don't you,,,,, the factory fills all
electronics with smoke before they sell them.... if you let the smoke out
they quit working.
the consequences of the high voltage could include smoking the eis, that
would be an expensive puff of smoke,,, it could also damage radios, gps,
etc, if they are using onboard power. It could even destroy the battery by
over charging it and boiling out the electrolyte.
Mine has always read 13.8 while running.
[Boyd]
Roger Lee
Posted: Mon Apr 23, 2007 11:16 am Post subject: Re: Help-- High Voltage? |
You ought to check your regulator/rectifier. High voltage is what happens when it goes out. Easy to replace. High voltage can damage instruments,
radios and batteries. They are not expensive and it stands a high probability for the cause. I wouldn't fly it or run it any more than you have to until it's fixed.
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
Richard Pike
Posted: Mon Apr 23, 2007 11:19 am Post subject: Help-- High Voltage? |
11.2 to 14.6 would be a good normal.
As far as trouble shooting, what engine are you running? What
regulator/rectifier? Can't second guess the unknown, at least from this
end...
As far as the consequences - probably something like fried avionics, battery
with water boiled away (check it first), stuff like that.
Richard Pike
MKIII N420P (420ldPoops)
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
JetPilot
Posted: Mon Apr 23, 2007 9:22 pm Post subject: Re: Help-- High Voltage? |
16.2 volts is way to high, you should never see it that high. You will fry something in short order with a voltage that high. I would not fly the plane until the voltage problem is fixed.
Kolb MK-III Xtra, 912-S |
captainron1(at)cox.net Guest
Posted: Tue Apr 24, 2007 8:25 am Post subject: Help-- High Voltage? |
First thing I would do is hook up a voltage regulator and make sure the two instruments agree, if not, then I would find out where is the voltage regulator and swap it out. Other than that can't think of anything else off hand.
Ron (arizona)
---- Tom O'Hara <tohara(at)alphagraphics.com> wrote:
--> Kolb-List message posted by: "Tom O'Hara" <tohara(at)alphagraphics.com>
http://forums.matronics.com/viewtopic.php?p=108679#108679
kugelair.com
Posted: Tue Apr 24, 2007 8:31 am Post subject: Help-- High Voltage? |
First thing I would do is hook up a voltage meter and make sure the two instruments agree, if not, then I would find out where is the voltage regulator and swap it out. Other than that can't think of anything else off hand.
Ron (Arizona)
kugelair.com
Posted: Tue Apr 24, 2007 8:49 am Post subject: Help-- High Voltage? |
Gang:
Didn't say what engine he was running, but constant hight voltage on a
two or four stroke Rotax is time to change out regulator/rectifier.
Only takes a minute to have the battery boiling. Been there and done
that. As an immediate expedient, turn on everything in the aircraft
that consumes 12VDC power. This will lessen the problem until you can
land and shut down the engine.
_________________ John Hauck
Titus, Alabama |
