Deems Davis
Posted: Mon Aug 07, 2006 10:02 am Post subject: EFIS - BMA or GRT? Op Tech |
You should look (at) Op Technologies
http://www.optechnologies.com/products.html
They are more pricey than GRT but they have all of the functionality of
a Chelton at lower cost with bigger screens + a certified EIS included
you can also load & display your charts.
Deems Davis # 406
Fuse
http://deemsrv10.com/
Dan Beadle wrote:
[quote] If I were going to fly VFR only, I certainly would go with this
system. (Maybe couple with a G496 to get weather and moving map) It is
cheap and should be far more reliable, over the long run, than vacuum.
They have huge market share due to price, giving them plenty of
resources to offer a solid product.
The trouble I am having is I want solid IFR with moving map and XM –
not Dynon features.
*From:* owner-aeroelectric-list-server(at)matronics.com
[mailto:owner-aeroelectric-list-server(at)matronics.com] *On Behalf Of
*Reginald E. DeLoach
*Sent:* Monday, August 07, 2006 6:57 AM
*To:* aeroelectric-list(at)matronics.com
*Subject:* Re: EFIS - BMA or GRT?
What about Dynon? Going to do simple mostly VFR day stuff. Seems like
they have pretty good bang for the bucks. Looking toward the D100. Any
personal experiences either pro or con?
red :}
Peter Pengilly wrote:
> PS Have you considered Advanced Flight Systems? They also seem to
> have a very well engineered product.
> http://www.advanced-control-systems.com/
> Pete
aadamson(at)highrf.com Guest
Posted: Mon Aug 07, 2006 10:48 am Post subject: EFIS - BMA or GRT? Op Tech |
Now, wait just one darn minute....If I may correct a few statements that I
believe are a little mis-stated ...
Chelton is about 10K more pricey than a GRT system, I'll give ya that. But
the screen size thing flew out the window at OSH, when Chelton announced 10"
displays. The costs of the OP, with all the goodies is actually more money
than the Chelton. Also, Op is still using the Xbow 42x AHRS, the one that
is currently recommended for VFR use only. Even the newly fixed ones are
still failing.
As for the charts topic... I can't remember, but I believe that the Chelton
also can display the approach plates if you like.
I know of no component on the OP that is "certified", unlike the Chelton,
which is tested to DO-160e, uses the same code as the certified box,
supports TSO-146, 146a and meets the WAAS GPS as sole navigation
requirements.
BUT, This list certainly isn't the list to "review and critique" the virtues
of either system. For that, I'd invite you to make sure you do adequate
research on the full gamet. From the low end to the high end.
As someone else stated on this or a different forum. For the prospective
buying. Before you do anything, set down with a clean sheet of paper and
write down your goals. List things like Backup requirements, flight
requirements, inflight data requirements (Weather, Lightning, etc), List
your size requirements, and latestly list the level of integration that you
want. The full gamet is possible from 6pack replacement only to fully
integrated FMS systems (with their associated complexities).
Then start the vendor research and figure out what meets your requirements.
Using what I say, or what someone else says is useless if it isn't how you
are going to use the system.
I would offer one other perspective. If you are going to do IFR with a
system. Make sure you don't fall victim of the "light IFR" concept. There
is no such thing. It's sorta like being a "little pregnant". If you are
going to use it in the crud, then make sure you think thru how the system
can fail, how it's been testing, and what the value of your cargo is and
factor that into your equation.
Good luck, and happy hunting.
Alan
Deems Davis
Posted: Mon Aug 07, 2006 11:24 am Post subject: EFIS - BMA or GRT? Op Tech |
Sorry, Alan, but the Op Tech 8.4 " Sport (non-certified) has a larger
screen than the equivalent Chelton Sport (non-certified), it also
displays more information on its screen/s real estate than does the
Chelton, it uncludes a JPI 950 EIS within the price, and regarding the
Crossbow. The Op Tech used the 420 which is the same hardware as the
failing 425, but contains different software. (Crossbow wrote the 425 to
Chelton's specs) There are no reports of the Crossbow failing in Op
installations. And I think if you'll check your figures again, the
OpSport is *definitely* priced below the Chelton Sport, )and then add
on to the cost of the Chelton the EIS of your choice. I'm not trying to
start a pissing match, my response was intended to show that there are
more options than were being discussed. My clean sheet of paper led me
to the OP Tech, others mileage will no doubt vary. Freedom of choice is
indeed a marvelous blessing.
Deems
still failing.
requirements.
Alan
rtitsworth
Posted: Mon Aug 07, 2006 11:42 am Post subject: EFIS - BMA or GRT? Op Tech |
I'm interested to hear from anyone with OPTech EFIS experience.
In my research/investigation I discovered (among other things) that it takes
several menu steps/button presses to do a common/simple ATC Com Freq
handoff. While not a big deal itself, it is just extra (unnecessary)
workload.
At FNS06 I was told they were working on that (hinted at a new button/menu
layout/system). At OSH06, nothing new. They did have their "Pegasus"
system on demo which has dedicated Com buttons and were saying that it is
nothing new (several years old). However, Iit is not their web site as an
available product. All seems pretty questionable.
Just looking for independent confirmation and/or enlightenment.
Posted: Mon Aug 07, 2006 11:55 am Post subject: EFIS - BMA or GRT? Op Tech |
Deems,
At least we can have a civil discussion... And I agree...No point in hashing
the full discussion here. A couple of quick points tho.
I have since determined that indeed the Chelton does *not* (at least at this
time), do approach plates, but somewhere in the back of my mind, I've seen
that... Hmmm..
Also, I also agreed with the comment about the screen size, but Chelton
announced at OSH, larger displays also in a "vertical" or portrait mode.
Also just so people don't think this is only a software conversation around
the Xbow AHRS. The 420 and 425 problems are not *only* software problems,
they are *also* hardware problems. The problems seem to be related to RMI,
EMI, GPS, and Lightning, either the 420, nor the 425 have any protections in
their hardware for these (GPS is a different thing, could be software, or
hardware). Also in a brief conversation with the OP guys at OSH, they did
advise that at least one of their customers had seen the problem in the 420
that they used and I believe it was swapped out for the revised version,
don't know if it resolve the problem or not.
Lastly, let's make sure we are talking apples to apples. The OPSport is a
"single screen" system, the Chelton Sport is a dual screen unit with full
redundancy between them. Also, the OPSport may come with the JPI, but the
literature says it requires probes to be purchases separately, last I looked
a prob kit wasn't extremely expensive, but wasn't cheap either. Chelton, at
one time, did offer a single screen unit, but most people opted for the dual
for redundancy and a dedicated MFD.
I believe if you'll take an apples to apples approach, you'll find my
original comments (with the exception of the approach charts, and I'm still
looking for that) were correct.
Isn't it amazing how discussions on EFIS systems are so "threatening"...
Just an observation, thanks for having a civil conversation...Enough of
this...
Alan
rvbuilder(at)sausen.net Guest
Posted: Mon Aug 07, 2006 12:36 pm Post subject: EFIS - BMA or GRT? Op Tech |
One thing you will find about OP Tech is that they are less than quick
about letting you know about what is up and coming. Not really great
for building user excitement. However they are very much alive and
well. As a matter of fact they are seeking certification which is part
of the reason they have been quiet and nothing much is changing. As far
as the X-bow you can upgrade to the certified 500 series if you really
are concerned but as Deems said the problems were with the Chelton
specific version of the 400 series. Also there is no way to view the
charts on the Chelton at this time let alone flying the chart as the OP
does.
I am seriously looking at the OP stuff. Previously I was planning on
the Chelton but the PR fiasco with the changing price a while back and
the x-bow stuff has me a little chilled. Also keep in mind that they
haven't really developed anything new in a long time either. The 10"
screen for Chelton is news to me but I probably don't want to see how
much more that will cost either.
Michael Sausen
RV-10 #352 Buildus Interuptus due to moving
AV8ORJWC
Posted: Mon Aug 07, 2006 1:21 pm Post subject: EFIS - BMA or GRT? Op Tech |
Mike Dennis, owner of Oregon Aero took one of his two Pilatus PC-12s and
made it Experimental to install FLIR in the top of the vertical stab. I
will see if he used Optech and Flir (another Oregon company).
John Cox
Posted: Mon Aug 07, 2006 1:27 pm Post subject: EFIS - BMA or GRT? Op Tech |
Both the Chelton and the OP are single screen or dual screen and both
have the option of adding a second or third screen. You can do a one to
one comparison based on the prices by ignoring the name next to each.
The Chelton does not include the EIS or the probes while the OP only
doesn't include the probes. Neither OP nor Chelton are fully redundant
at the ADHARS level, only the screen/processing level. Also keep in
mind that the new AFS stuff uses x-bow but it may be the 500 series and
I believe GRT also might but I'm not positive. However the GRT is a
fully redundant system.
Michael Sausen
AV8ORJWC
Posted: Mon Aug 07, 2006 1:39 pm Post subject: EFIS - BMA or GRT? Op Tech |
As the guy who derailed Tim Olson's pursuit of GRT towards Chelton
months ago (Jim Hergert's panel in N6XE)... I need to pipe in that my
meeting with Schrameck's guys at Epic LT gave the following support.
They are 68 units back-ordered in production over in Bend, OR. They
have decided to standardize on the OpTech panel for all production. No
GRT, No Dynon, No BMA, and no Chelton. They are in pursuit of a twin jet
version and bringing the company into Certification (Part 23) just like
Lancair/Columbia.
That is no small commitment for a multi-million dollar aircraft
manufacturer.
I want to thank Deems for his insight, his post and his confidence in
their equipment, cause all of this discussion is invaluable to the
learning process. Data comes quick in a turbojet and they are not
usually VFR only. No horse in the race.
John Cox
Posted: Mon Aug 07, 2006 2:27 pm Post subject: EFIS - BMA or GRT? Op Tech |
Uh, don't think that's true.... Maybe I got my inches wrong, but D2AV had a
handout of the "large display" (could it have been 8.4", I don't
remember")... Coming soon to an Avionics Shop near your. Not just for the
Certified guys, but also for the EX guys...plus new digital radios.
Alan
Posted: Mon Aug 07, 2006 3:25 pm Post subject: EFIS - BMA or GRT? Op Tech |
Just talked to Josh and you are correct. They look very nice! About
the same price as a G900. Just like the OP though, I don't see the
point of an integrated radios. Lot more money for not much added
functionality. Personal preference I guess. One thing I thought was
funny was the number of digits on the radio display at OSH. Only one
digit past the decimal point. Hmmmm.
Michael Sausen
cberland(at)systems3.net Guest
Posted: Mon Aug 07, 2006 3:53 pm Post subject: EFIS - BMA or GRT? Op Tech |
Alan, you are correct. The large display is approx. 10.25 total height
with approx. 8.25 screen height. I have two on order for experimental.
Craig Berland
--> <aadamson(at)highrf.com>
had a handout of the "large display" (could it have been 8.4", I don't
the Certified guys, but also for the EX guys...plus new digital radios.
Alan
Posted: Mon Aug 07, 2006 4:04 pm Post subject: EFIS - BMA or GRT? Op Tech |
Um, who said anything about "integrated" as OP does. I'll rephrase that to
"faceless". The Cheltons are standalone radios/Transponder that can be
integrated into the FMS. I have no idea of price but I understand they will
be available in standalone with the funky screws and standalone with regular
mounting (for us normal folks). They may also come with a removable face
that would let you mount the bulk of the hardware elsewhere.
Also, not sure what you are talking about on the radios. The card that I
saw looked normal, and here is the webpage, the displays are 2 digits past
the decimal, just like everyone else. The unit on top is a transponder.
http://www.d2av.com/Radios/
Alan
Posted: Mon Aug 07, 2006 4:39 pm Post subject: EFIS - BMA or GRT? Op Tech |
Also for those following the bouncing ball.
The chelton large display price comparison to the G900 that Micheal is
making is for a combo system with radios and in the Chelton Pro line (not
the certified line, but the Pro experimental line). All the conversation
that I've had to date has been around the pricing of the "sport" line...
Ok, I'm done with this topic...and have wasted enough bandwidth. If you are
looking and you are going to spend these kinds of dollars, for heavens sake,
go fly behind any of them before you buy!
Alan
JohnT(at)comp-sol.com Guest
Posted: Tue Aug 08, 2006 6:50 am Post subject: EFIS - BMA or GRT? Op Tech |
Mike,
The Chelton does have 2 AHRS inputs....pin 7&49 on the HD62 connector is
AHRS2. One can switch via software on the IDU.
One can also wire the units separately - or using AHRS1 input, a switch
can select which AHRS is 'active'.
I have not checked on the air data portion -
John
Time: 02:27:43 PM PST US
Subject: RE: EFIS - BMA or GRT? Op Tech
From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net>
Michael Sausen
Posted: Tue Aug 08, 2006 7:51 am Post subject: EFIS - BMA or GRT? Op Tech |
Yep, I'm aware that it has the capability. What I was referring to was
what is standard. This thread went a little sideways because of some
peoples passion with what they purchased. I have no problem with that
and I think everyone should be that confident in what they bought. As
Alan said do some due diligence before you plop down any amount of money
on experimental EFIS's. I haven't made a decision yet personally and I
am very anxious to see what comes out from OP & Chelton over the next 6
months or so. They both have some improvements coming.
Michael Sausen
Tim(at)MyRV10.com Guest
Posted: Tue Aug 08, 2006 9:58 pm Post subject: EFIS - BMA or GRT? Op Tech |
I have just a couple things to add about EFIS Choices.
As someone said, make a list of your requirements on paper before you
go shopping. Read as much as you can so you even KNOW all of the
features you may be looking for. Then pick an EFIS that has as
much as possible that's on your list. Everyone's list will be
different.
Fly behind anything you think you might want to buy. It will
be an incredibly valuable experience. I nearly built an RV-6
at one point...but flew one first and that put me into a holding
pattern. An EFIS is a complex piece of equipment. It's worth
a few hundred bucks to find someone and fly behind one.
One thing that people always forget about with their EFIS is
database updates. A GRT or BMA might be a fine EFIS for you,
but if you're going to rely on them to fly approaches, remember
that you're going to need a current database. Or if you're
controlling the approach with a 430/530/480, you will need
a current one there....or at least a current chart in hand
and the ability to keep in close enough touch during the
approach that you don't let your fancy GPS/Com or EFIS fly
you on a non-current approach. I have a Chelton system, with
a database subscription. If you can't get a database update
on a 28 day cycle for whatever your primary navigation gear is,
you're going to be severely limited. That's my main gripe
about the GRT stuff, by the way. You really need to look at
the whole big picture in this much detail.
As far as the AHRS goes, I think someone needs to set the record
straight on the 420/425/500 stuff being flung around. The 420
and 425 are pretty darn close, and I've been seeing lots of
actual data lately showing there are some GPS issues with the
unit that may be causing some of the failures people are having.
I'd be a bit leery until the company has it solved and wouldn't
assume the 420 isn't affected. I've now heard that numerous
425 owners who have "fixed" units are still having problems.
Then, dig in a bit further and ask someone in the know EXACTLY
what is the difference between the real certified 500 system,
and the "500 based" systems that are being touted around. Lots
of people are saying theirs use the 500, but in at least
some cases, it is not truly the same 500....but a 500 with
some of the specialties removed...turning it into a slightly
less ruggedized and non-certified experimental unit. Do some
serious research into this.
Don't forget cost. Nobody should take offense when someone picks
an EFIS that's not their favorite. I personally thought the GRT
stuff looked pretty good for that budget. Things like the
database updates, and the screen quality knocked them out for me,
but for some buyers, it may be their dream panel. Everyone has
a different mission. It's also nice to see people like Deems
try something a little less common in our EFIS world. The OP
stuff hasn't really been as popular with our "budget" kits, so
it'll be interesting to see how it all goes. It is definitely
different than the other offerings.
As far as screen size, having never flown behind the huge
screen systems, but having flown behind my Cheltons, I personally
can't see why a bigger screen is necessarily better. It would
depend on how flexible the information placement is. Certainly
though, numerous smaller screens can be just as effective as
a pair of larger screen. Since our panels are only so big, we
have limited space, and depending on your personal requirements
for backup systems, you may not have the space you want for
big screens. Just rest assured that big or small, you should
be able to get all the functionality you need into your panel,
and from a practical point of view I really don't see that the
size would matter much, as long as you have something in the
neighborhood of the size of the GRT's.
There's just way too much involved in these decisions, and
making them can be quite trying at times. Just make sure you
don't sell yourself short an make a quick and rash decision.
One minor note: For those who demand dual AHRS systems, I know
the GRT already does this, but now with the Pinpoints for
the Cheltons you have that option as well. Not a requirement
for everyone, but just so you know, there is now the option.
Alan
mlas(at)cox.net Guest
Posted: Wed Aug 09, 2006 3:44 pm Post subject: EFIS - BMA or GRT? Op Tech |
Tim,
Well written! I too fly behind the Chelton system and have worked with
the 420/425 and the problems that continue to plaque the unit. One of
the issue is the influence the GPS has over the gyro output. If you get
a map shift with the 420/425 due to a position error or reception error
you also get a gyro shift at the same time. This is not good in IMC.
The 425 had other problems with gyro initialization with low startup
voltage. This caused the unit to fail on initialization. Another
problem is a P-static ground feed back issue that has not been fully and
technically explained to me. The fixes for the units in question only
fix the later two issues, not the first issue. It is my opinion the
design philosophy to allow the GPS position to have influence over the
GYRO platform on the 420/425 unit is unacceptable and unworkable without
a redesign.
Mike Larkin
Lancair Legacy
TS-11 Iskra
Kitfox IV (All Flying!)
sales(at)6440autoparts.co Guest
Posted: Wed Aug 09, 2006 5:01 pm Post subject: EFIS - BMA or GRT? Op Tech |
I am not technicly minded but that is the reason I decided on
the GRT they claim their gyro system is indipendant of the GPS.
Randy
