kmamjones(at)comcast.net Guest
Posted: Fri Aug 04, 2006 9:38 pm Post subject: Motorcycle grip Throttle |
Cut Schrader's comment about a motorcycle grip throttle caught my attention.
I'm building an S7 taildragger. I have a bad left leg from polio as a
child - not enough strength for left rudder. I used to fly an RV-4. Sold it
to build the Kitfox - no need for speed anymore. I had left rudder and left
brake hand controls on the RV-4. On landings I cut the power to idle when
the field was made. I needed the left hand for rudder (particularly on
crosswinds) and right for the stick. I never did wheel landings - a bit
too cautious I guess. I don't know much about motorcycles. Could a
motorcycle grip throttle be installed on the S7 stick, but still have a
regular throttle for others would might fly the plane? I'm using a Rotax
912S, which, of course, has two carbs. Sure, I could probably fly the S7
like the RV-4, but I would much rather have use of the throttle on the
landing and roll-out - more options, you know. I hadn't thought about the
motorcycle grip before. Is it even feasible to run two throttle cables to
two carbs? How could the motorcycle throttle be locked to maintain cruise
RPM? Any ideas would be appreciated. If this sounds a little dumb, have some
compassion - I'm a good accountant - not an engineer.
Ken Jones
JeffFowler(at)aol.com Guest
Posted: Sat Aug 05, 2006 2:35 am Post subject: Motorcycle grip Throttle |
In a message dated 8/5/2006 4:28:35 AM Eastern Daylight Time,0 kmamjones(at)comcast.net writes:
Cut0 Schrader's comment about a motorcycle grip throttle caught my attention.0
I'm building an S7 taildragger. I have a bad left leg from polio as a0
child - not enough strength for left rudder. I used to fly an RV-4.0 Sold it
to build the Kitfox - no need for speed anymore. I had left rudder0 and left
brake hand controls on the RV-4. On landings I cut the0 power to idle when
the field was made. I needed the left hand for0 rudder (particularly on
crosswinds) and right for the stick. I0 never did wheel landings - a bit
too cautious I guess. I don't know much0 about motorcycles. Could a
motorcycle grip throttle be installed on0 the S7 stick, but still have a
regular throttle for others would might fly0 the plane? I'm using a Rotax
912S, which, of course, has two carbs.0 Sure, I could probably fly the S7
like the RV-4, but I would much rather0 have use of the throttle on the
landing and roll-out - more options, you0 know. I hadn't thought about the
motorcycle grip before. Is it even0 feasible to run two throttle cables to
two carbs? How0 could the motorcycle throttle be locked to maintain cruise
RPM? Any0 ideas would be appreciated. If this sounds a little dumb, have some0
Ken Jones0
[/quote]
Hello Ken and list,
How you would rig the cables is unclear to me, but,0my0 1985 H-D FLT has a throttle that has a thumb screw that holds the throttle by0 tension at what ever setting you leave it at. It's a common feature on most0 bikes above 400 cc today. the diameter of your stick is needed to make a0 decision on what type to use if you try it though.
Till Next Time,
Jeff Fowler
Ceashman(at)aol.com Guest
Posted: Sat Aug 05, 2006 3:17 am Post subject: Motorcycle grip Throttle |
All this talk about a motorcycle throttle has me worried!
If John Denver were here he would say "keep things standard" "I can't live with controls and switches and valves being anywhere but correct and in0the right place". That's what he would say.
What would happen with a twist throttle (motorcycle style) at the end of your stick when moving the stick around, yanking it back for take off, pushing it forward for level flight and what about those quick lefts and rights at landing (little breezes).
I can imagine, if I had another control on my stick, I would be adjusting the RPM the same time as I make flight control inputs.
But then again, I am thinking of installing a foot controlled throttle. Do you think it should be to the right of the rudder peddles or in between? (Kidding!!)
With all the discussions on the topic, safety?
rjdaugh(at)rapidnet.com Guest
Posted: Sat Aug 05, 2006 5:28 am Post subject: Motorcycle grip Throttle |
Ken,
I think this could be done. It would take some research, but there are lots
of different kinds of hardware out there.
A lot of bikes (especially dirt bikes) have two cables - one to pull the
throttle open and one to pull it shut. It seems to me that this could be
interfaced with the standard throttle control for the 912S. But it may be
better to just have a custom cable made to go directly to the carbs. There
are a number of places that will do this.
There are twist throttle controls where the cable comes out parallel to the
bar (stick?) and there are twist throttle controls where the cable comes out
90 degrees to the bar/stick. I kinda like the 90 degree approach for
mounting on the stick. These cables are designed to handle lots of movement
because the handle bars move to steer the motorcycle. Attention would be
needed in selecting the routing of the cables to avoid interference with
legs, frame, etc.
Another approach is the ATV thumb throttle. I don't know that these have a
position lock as someone else pointed out is available on a lot of bikes.
You could make the stick a couple of inches longer and mount this thumb
throttle above the hand grip to be well positioned for the thumb. You might
even be able to hook up a cruise control to handle cruise flight.
Interesting problem. Lots of options. Good luck and I would like a report
of your progress.
Randy 912S series 5/7
bmwebb(at)cox.net Guest
Posted: Sat Aug 05, 2006 5:35 am Post subject: Motorcycle grip Throttle |
There is a lever actuated friction lock, called “cruise control”, for bike throttles that help hold the twist grip for you when cruising down the highway. I think there are several makes, but try JC Whitney, or any local motorcycle shop. You can adjust them for tension, so you can still move the throttle if you have to. Has a little lever to engage and disengage it.
One thing to think about is a trigger throttle, like that on early ATVs and most watercraft. One or two finger trigger style at the stick grip might get you what you want. Not sure how you’d “lock” it, but you might be able to figure something out.
Bradley
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of JeffFowler(at)aol.com
Sent: Saturday, August 05, 2006 6:32 AM
Subject: Re: Kitfox-List: Motorcycle grip Throttle
In a message dated 8/5/2006 4:28:35 AM Eastern Daylight Time, kmamjones(at)comcast.net writes:
Ken Jones |
Hello Ken and list,
How you would rig the cables is unclear to me, but, my 1985 H-D FLT has a throttle that has a thumb screw that holds the throttle by tension at what ever setting you leave it at. It's a common feature on most bikes above 400 cc today. the diameter of your stick is needed to make a decision on what type to use if you try it though.
Till Next Time,
Jeff Fowler
Posted: Sat Aug 05, 2006 10:24 am Post subject: Motorcycle grip Throttle |
Actually what I was suggesting is the standard for
helos, but not on the stick you are thinking of. It
is on the other stick called the "collective" beside
the seat, which controls lift and power, not
direction.
Our flap handle could be used the same way, to a
degree. But it must be noted that the helo's throttle
works backwards from a motorcycle and that can be
dangerous, if you mix the two.
The benefit of this arrangement on a plane is that you
can much more precisely control lift with flaps and
with more rapid responce than by changing pitch. But
for it to work well, you need to constantly have your
hand on the flap lever and that is why you put the
throttle there. Also it would need instant pitch trim
to match the flap pitch inputs to keep the angle of
attack you select with the stick, or you will have the
nose ducking and pitching with every flap change.
Done well, you could hold a constant pitch attitude
and AOA on final, but vary the flaps with every gust
and downdraft to precisely keep your glideslope
without pitch changes. No ballooning or floating
either. It really is much more precise and quicker
control than we are used to in airplanes.
Kurt S.
--- Ceashman(at)aol.com wrote:
| Quote: | All this talk about a motorcycle throttle has me
worried!
but correct and in the
lefts and rights at
(Kidding!!)
janderson412(at)hotmail.c Guest
Posted: Sat Aug 05, 2006 11:51 am Post subject: Motorcycle grip Throttle |
Recip helos have motorcycle type throttles on the collective. How about on the flap lever??
| Quote: | All this talk about a motorcycle throttle has me worried!
If John Denver were here he would say "keep things standard" "I can't live with controls and switches and valves being anywhere but correct and in the right place". That's what he would say.
Need more speed? Get Xtra Broadband!
Posted: Sat Aug 05, 2006 5:27 pm Post subject: Motorcycle grip Throttle |
Hi Ken,
I've seen a few adaptations in the past for
disabilities. Most were invented by the individual,
but I bet the EAA has a few ideas available for you.
I once met a man driving a BMW motorcycle with a hook
on his left arm. All the controls were moved to the
right side. Clutch, break, throttle, signals....
Would it work for you to put a strap over the right
peddle so that you could push and pull it? You would
need a cable interconnect to make it work the other
side when you pull. Torgier once drew up such an
arrangement for us a while back. He is a wiz for
finding info too.
Maybe widen the top of the peddle so that you could
put a break on either side of the peddle arm. Toe
push left, right or both brakes by moving your foot?
If you don't like the motorcycle throttle, how about a
big "L" shapped bar or second stick extending from or
below the panel? Push and pull for throttle, swing
laterally like your stick, but for rudder? Fly with
both hands?
Lots of ideas available.... No reason not to fly.
Kurt S.
--- Kenneth and Alice Jones <kmamjones(at)comcast.net>
wrote:
| Quote: | Cut Schrader's comment about a motorcycle grip
leg from polio as a
probably fly the S7
the throttle on the
engineer.
Ken Jones
Posted: Sat Aug 05, 2006 7:29 pm Post subject: Motorcycle grip Throttle |
There is a very well known NZ helicopter pilot that had a very bad crash some years back. Very wealthy chap with his own fleet of aircraft including war birds etc. After the serious accident he was left with no movement in his left leg so designed a stirrup system on the right pedal of his Hughes 500 and to see him fly you would know he has a disability. I realize the helicopter is a bit easier than a f/w for pedal input but food for thought. Come to think of it he used to fly his Spitfire this way too, but did have a bad accident in that also.
From: kurt schrader <smokey_bear_40220(at)yahoo.com>
Subject: Re: Motorcycle grip Throttle
Date: Sat, 5 Aug 2006 18:08:07 -0700 (PDT)
--> Kitfox-List message posted by: kurt schrader <smokey_bear_40220(at)yahoo.com>
Hi Ken,
finding info too.
both hands?
Kurt S.
wrote:
[quote] Cut Schrader's comment about a motorcycle grip
leg from polio as a
fultz(at)trip.net Guest
Posted: Sat Aug 05, 2006 10:03 pm Post subject: Motorcycle grip Throttle |
Ken,
What about a throttle set up similar to that on a 4-wheeler with an
adjustable friction control? Just another thought. There's no doubt in my
mind that something, that will work for you, can be had. You might just
well need that throttle when you have both hands busy with other chores.
Andy F.
Posted: Mon Aug 07, 2006 9:46 am Post subject: Motorcycle grip Throttle |
Thanks to those who responded to my request for0 help. While I'm at least a year away from engine installation, I'll start0 now on the research phase. I think I'll start by visiting a few motorcycle0 dealers to see how their systems work.
Ken Jones
Richard Rabbers
Joined: 09 Jan 2006 Posts: 114 Location: Benton Harbor, MI - USA
Posted: Thu Aug 10, 2006 10:07 am Post subject: Re: Motorcycle grip Throttle |
Ken,
August 06 'Sport Aviation' - page 17 Note on - "Disabled Pilot Options.... " offered for those unable to operate rudder peddles.
Sounds like it's worth a look.
www.SkyArrowUSA.com
or
www.HansenAirGroup.com
_________________ Richard in SW Michigan
Model 1 / 618 - full-lotus floats (restoration) |
Posted: Thu Aug 10, 2006 12:52 pm Post subject: Motorcycle grip Throttle |
Richard:
Thanks for the posting. I talked to the Hansen Air Group today. The
gentleman I spoke with told me that for liability reasons they do not sell
their disabled pilot kit for use on aircraft other than the Sky Arrow.
Never-the-less the general idea of a throttle on the hand rudder control
looks promising, and perhaps a better alternative than a throttle on the
stick. I will look into doing something like it with the help of some EAA
friends and motorcycle experts. It shouldn't be too hard. I had a hand
rudder control on my RV-4, so I already have that experience. I already
planned for, and must have, a similar control on my Kitfox S7. So adding a
twist grip throttle may not be that difficult. This still leaves the problem
of running two separate throttle cables to two carbs so I can also have a
standard centered push-pull throttle for others (like my grandsons) who
might fly the plane the normal way.
I must say my question to the "List" has resulted in some very
interesting and I think doable suggestions.
Thanks again
Ken Jones
