gregcampbellusa(at)gmail. Guest
Posted: Thu Aug 10, 2006 6:46 am Post subject: GPS Antenna Cable... |
Does anybody know a source for a GPS antenna cable?
Preferrably near the Washington DC area.
SMA connector on one end, TNC on the other?
Greg
nuckollsr(at)cox.net Guest
Posted: Thu Aug 10, 2006 7:19 am Post subject: GPS Antenna Cable... |
At 10:45 AM 8/10/2006 -0400, you wrote:
| Quote: | Does anybody know a source for a GPS antenna cable?
RG400 is a suitable material. Connectors are easy
to install with a bit of practice and access to
inexpensive tools.
It sounds like you're looking for a turn-key custom
cable source. You might check with http://steinair.com
and see if they can assemble a cable to your specifications.
< with experiment. >
< --Lawrence M. Krauss >
Posted: Thu Aug 10, 2006 1:46 pm Post subject: GPS Antenna Cable... |
Bob,
Thanks for the link to www.SteinAir.com
I called and they didn't have SMA or TNC connectors.
(But they will have a great deal on eyeball air vents!)
That reason I need this cable is that after a year of waiting,
I'm finally replacing my faulty Crossbow NAV425 AHRS
with the new GADAHRS from www.PinpointInertial.com .
At Oshkosh, it finally changed from "vaporware" to "hardware" status.
The "replacement kit" INCLUDES:
+ Pinpoint Inertial AHRS
+ Magnetic Sense Unit (MSU) (remote mount, make your own bracket)
+ OAT Probe, cable, and plug
+ Comant active GPS antenna
+ Canon plugs, sockets, strain relief clamps
The following parts are NOT INCLUDED:
- GPS Antenna cable with SMA fitting (for the AHRS) and TNC (for the Comant Antenna)
- Shielded 3 conductor wire for two new runs from the AHRS
- Plumbing tees and connectors needed to tap into your pitot & static lines
(the new AHRS has -4 size AN flare fittings, the Crossbow didn't have pitot static inputs)
I took care of the last two items, but the GPS antenna cable left me stuck.
The local avionics shop has the parts and will make one in time for my flight tomorrow - for $240.
www.HyperTechLink.com had great prices, about $5 each for the SMA and TNC connectors.
Unfortunately they sell them 10 to the bag, so for $120 I can have 10 times more than I need overnight.
www.GPSgeek.com probably has the best deal. I can order a generic active GPS antenna for $40 or $60
depending on the gain I want. It comes with my choice of 9' or 16' antenna cable with SMA connector already attached.
So... if you're eagerly awaiting your Pinpoint Inertial AHRS, you might want to start lining up
the SMA and TNC connectors and other bits and pieces you'll need to complete the installation.
Give me another week and I might be able to report how well the new Pinpoint Inertial AHRS works.
Greg
rvbuilder(at)sausen.net Guest
Posted: Thu Aug 10, 2006 4:20 pm Post subject: GPS Antenna Cable... |
These types of connectors are extremely common in the wireless networking area. Google around for wireless or wifi antennas and you will get sources. HyperlinkTech used to be a good place for small orders but they went to minimum orders a couple years ago and jacked up the prices to get rid of small orders. A couple you can check are:
http://www.antennasystems.com/connectors.html
http://www.wifi-link.com/index.php
http://www.wirelessnetworkproducts.com/
Michael Sausen
-10 #352 Fuselage
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Greg Campbell
Sent: Thursday, August 10, 2006 4:45 PM
To: AeroElectric-List(at)matronics.com
Subject: Re: GPS Antenna Cable...
Bob,
Greg
brian
Joined: 02 Jan 2006 Posts: 643 Location: Sacramento, California, USA
Posted: Thu Aug 10, 2006 4:52 pm Post subject: GPS Antenna Cable... |
On Aug 10, 2006, at 8:17 PM, RV Builder (Michael Sausen) wrote:
| Quote: | These types of connectors are extremely common in the wireless
check are:
Check Fleeman, Anderson, and Bird.
http://www.fab-corp.com/
I use them to supply my WiFi needs. The LMR-195 coax is nice low-loss
stuff.
Brian Lloyd 361 Catterline Way
brian-yak AT lloyd DOT com Folsom, CA 95630
— Antoine de Saint-Exupéry
_________________ Brian Lloyd
brian-yak at lloyd dot com
- Antoine de Saint-Exupery |
Tim(at)MyRV10.com Guest
Posted: Thu Aug 10, 2006 8:57 pm Post subject: GPS Antenna Cable... |
http://www.rfmicrowavecable.com/smamaletotncmale.html#RG-223/U
$29.95 for RG-223 3' (available in qualtities for less)
HD Communications
Ask for craig - 888-588-3800
Greg
rv8iator
Posted: Fri Aug 11, 2006 5:28 am Post subject: GPS Antenna Cable... |
Cable and connectors of the RF variety:
http://www.pasternack.com/
Chris Stone
A pair O' eights
[quote]--
_________________ C. Stone (RV8iator) |
