kitfox(at)bulldog.itgo.co Guest
Posted: Fri Aug 11, 2006 3:12 am Post subject: Door Struts |
My KF III does not have gas struts on the doors. I've
thought of adding them and can see several different
options. I am curious how others have installed
struts on their doors.
On the front or back of the frame ?
Did you weld the attach points on the frame and door
or bolt on ?
How long are your struts ?
Any "gotcha's", caveats, or "I would do this
different"?
Bruce
Lynn Matteson
Posted: Fri Aug 11, 2006 4:53 am Post subject: Door Struts |
My IV came with the attach points welded to the windshield "A" post
(car term), but I had to locate the door frame attach point and rivet
them in place.
The instructions have you close up the lift strut to within an
eight-inch of fully closed, then wire it secure in that almost-closed
position, then use that to locate the door attachment point. This
allows for the "over-center" which happens when the door is nearly
closed, and keeps the door against the fuse just before the door is
latched closed.
Lynn
Kitfox IV...Jabiru 2200
On Friday, August 11, 2006, at 07:11 AM, kitfox wrote:
or bolt on ?
different"?
Bruce
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Float Flyr
Posted: Fri Aug 11, 2006 6:39 am Post subject: Door Struts |
I set mine up so the centre occurred when the door is open about five inches
it gives plenty of push to keep the door closed and more than enough to keep
the door open. If I can find another one of those struts I'll put it on the
passenger side being careful to install it so the open position won't hit
the sump drain on that side.
Noel
| Quote: | My IV came with the attach points welded to the windshield "A" post
them in place.
latched closed.
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Float Flyr
Posted: Fri Aug 11, 2006 6:48 am Post subject: Door Struts |
I made mounting brackets which I attached to the rear of the door frame with
automotive worm type hose clamps. I decided on this approach because it
isn't a structural part of the aircraft. If one of the worm clamps loosens
there is no safety issue. They are easy to use. They are very easy to
inspect.
The strut itself (only one on the left side) is an automotive style with
ball ends so they may be disconnected at either end with a simple screw
driver to facilitate removing the doors.
I was considering replacing the nuts and bolts and zip pins that hold the
doors on with clevis pins just to make the removal of the doors that much
easier. The truth to be known I don't think I'll get into a situation where
I'll ever remove the doors. This part of the world just isn't warm enough
for that.
Noel
[quote] --
Kitfox III-A
Glenn Horne
Posted: Fri Aug 11, 2006 8:46 am Post subject: Door Struts |
Hi Bruce,
Glenn Horne here.
Got mine from Advance Auto. # 4420. They had to order mine.
Put them on the front. One bracket on the edge of the instrument panel
and one on the door with the cylinder extended. Make the brackets
and rivet them on. Need picture let me know.
Works for me.
Glenn Horne
Model II 582
Michel
Posted: Fri Aug 11, 2006 9:29 am Post subject: Door Struts |
On Aug 11, 2006, at 6:45 PM, Glenn Horne wrote:
| Quote: | Got mine from Advance Auto. # 4420. They had to order mine.
Advance Auto is a nice web shop, Glenn. But when the ask you your zip
code and you live in Norway ...
Do you have a direct link?
My left door strut has lost much of its compression and it is about
time to replace it.
Thanks in advance,
Michel
_________________ Kitfox 3 - Jabiru 2200 |
Glenn Horne
Posted: Fri Aug 11, 2006 6:12 pm Post subject: Door Struts |
No Michel I don't.
They don't ship out of the country. Sorry.
If you can't get one in the near feature,maybe we can
work out something to get one to you.
Glenn
smokey_bear_40220(at)yaho Guest
Posted: Fri Aug 11, 2006 8:42 pm Post subject: Door Struts |
The struts are usually installed on the front, but
some have put them in back. This allows for easier
entry and exit, but in back is almost certain to
flutter, if opened in flight. I kept mine in front on
the factory mounts. S-5 model
Kurt S.
--- kitfox <kitfox(at)bulldog.itgo.com> wrote:
| Quote: | My KF III does not have gas struts on the doors.
I've
Michel
Posted: Fri Aug 11, 2006 11:35 pm Post subject: Door Struts |
On Aug 12, 2006, at 4:10 AM, Glenn Horne wrote:
| Quote: | If you can't get one in the near feature,maybe we can
Thank you very much, Glenn, but Lowell has sent me, privately, the
manufacturer of the original struts and it is http://www.suspa-inc.com/
Incidentally, I'll be touring in the US in September and Lowell has
even kindly invited me at his home in Northern California, something I
really look forward to.
I am not in a hurry to replace my door strut, I have only the left one
that is getting worn, lifting the door about half way, only. Of course,
it is the most used door, it makes sense. The original struts are from
1992 and since then, the plane has been flying about 500 times (not all
by me) so it can be considered as normal wear.
Michel
Float Flyr
Posted: Sat Aug 12, 2006 4:29 am Post subject: Door Struts |
My strut (1) is mounted on the back. It doesn't flutter at all in flight.
Airspeed may be a factor... The asi reads around 85mph in still air. The
gps says closer to 105.
Photography with the door open is exceptional. There is nothing to vibrate
the lens of the camera and of course nothing to diffuse the image. I tend
to use wider angle lenses and point and press then crop the image on the
ground. If you use a digital camera ( usually I do ) try to get one with
the most pixels possible and don't use the digital zoom. For 35MM I stick
with the slowest film to do the job and a 1A(very light salmon colour)
filter on a UV filter. The 2 1/4 Sq allows more flexibility with film but I
use the same filter pac. Leave the lenses at infinity and set the exposure
before leaving the ground.
I use the neck strap until the door is closed and the camera is stowed.
Noel
[quote] --
Kitfox III-A
dave(at)cfisher.com Guest
Posted: Sat Aug 12, 2006 6:52 am Post subject: Door Struts |
Hi Noel,
I don't have gas strut on doors and my doors will stay open without a
problem.
Also I saw your picture the other day and you have a nice looking Kitfox.
What are your true airspeeds on floats in MPH ? you must be joking about
the 105 comment ?
582 Kitfox 3 is likely to be close to low 80s at very best.
Dave
MichaelGibbs(at)cox.net Guest
Posted: Sat Aug 12, 2006 9:50 am Post subject: Door Struts |
Kurt sez:
| Quote: | This allows for easier entry and exit, but in back is almost certain
to flutter, if opened in flight.
I installed mine on the back of the door to keep them out of the way
and never had any trouble with flutter. I flew with them open quite
often.
Mike G.
N728KF
Posted: Sat Aug 12, 2006 8:47 pm Post subject: Door Struts |
Noel and Mike,
Guess I am wrong then if it works for you 2. I
thought about moving mine there while building because
it makes entry and exit easier, but figured SS only
put them in the front for a reason. Usually you need
the support on the forward end or things go divergent.
Now I wish I tried it on the back too.
Kurt S.
--- Noel Loveys <noelloveys(at)yahoo.ca> wrote:
| Quote: | My strut (1) is mounted on the back. It doesn't
85mph in still air. The gps says closer to 105.
Float Flyr
Posted: Sun Aug 13, 2006 6:55 am Post subject: Door Struts |
No joke. In some ways I wish it were.
My ASI usually reads below 80. Just what I'd expect. The gps was reading
around 100-105 in dead calm air with the Aerocets slung underneath. I did a
double check to make sure that I didn't have the GPS set to Km as I also use
the unit in the car and we have to use metric on the highways here. I
usually reset it to MPH when I put it in my flight bag and to metric after I
download my flight to the computer.
There is an island 19.8 miles distance from my house on the day I took the
GPS readings I flew from the island over my house in just under 12 minutes.
The reason I timed the trip has to do with all the locals here who rate
their boats on how long it takes to get to Exploits Island and how much fuel
they use in doing the trip. I always grin an tell them 12 minutes and less
than a gallon of gas ( Imperial gallon ) That makes my speed out to be 99
mph. Right around that time they mention that I won't drop in because of
the salt water...
A couple of long time pilots of Merlins and Avids have commented to me on
how fast my plane seems to be. That is probably the most subjective
assessment that can be made. But at least it makes me feel pretty good.
Like your self I'm sceptical of that amount of speed. My GPS is relatively
new but they have been known to have errors ... More the further north you
go. On that day I flew 246 miles according to the track on the GPS. My
total air time from the time I turned the unit on was almost exactly 3
hours. Considering that I did a 7 minute engine warm up/taxi and 4 practice
circuits as well as the taxi back to the beach (much shorter) my airspeed
must have been close to the 100 point... go figure.
The greatest thrill of flying this plane is its ability to get in and out of
some pretty small ponds.
Noel
[quote] --
Kitfox III-A
Lynn Matteson
Posted: Tue Aug 15, 2006 3:29 pm Post subject: Door Struts |
Michel-
Does this mean that you'll be flying your 'fox over here?
Lynn
On Saturday, August 12, 2006, at 03:33 AM, Michel Verheughe wrote:
manufacturer of the original struts and it is > http://www.suspa-inc.com/
course, it is the most used door, it makes sense. The original struts
are from 1992 and since then, the plane has been flying about 500
times (not all by me) so it can be considered as normal wear.
Michel
N369LM |
