Artificial Horizon
Goto page 1, 2  Next
bicyclop(at)pacbell.net
PostPosted: Thu Jan 19, 2006 11:52 am    Post subject: Artificial Horizon Reply with quote
I did handle the ADI on the bench at Sun'N'Fun. I didn't try a
hammerhead with it, but it did seem to track bank angle as well as any
gyro I've done the same with, regardless of pitch attitude. It did give
me weird indications in pitch and they told me it would because there
was no change in altitude to work with. It initially showed the pitch up
and then returned to level.
They said that is very flyable. Their reasoning, as I understand it, is
that the actual pitch attitude of the aircraft is less important to your
moment to moment control inputs than having an indication of what the
trend is. In other words, if you wish to climb, descend or fly level,
the instrument gives you a clear indication of the effect of your
control inputs on the flight path. If you were to get behind the power
curve, the display might not be so intuitive. They have a flashing
airspeed warning for that condition. I don't know how easy it would be
to figure out what to do if the nose was up and the vertical speed began
to go negative using only the ADI for reference. Definitely not
something I would want to try for the first time in the clouds. Your
other instruments, notably the airspeed indicator and altimeter, would
tell the story.
I asked them what would happen if you got inverted in the clouds. Their
reply was that you'd be in a world of hurt no matter what kind of
attitude indicator you were using, but they felt that the with ADI it
would be at least as easy to prevent such a condition from occurring as
with an AH.
I was impressed with the instrument at the airshow. I would love to hear
from someone who's flying it.
Pax,
Ed Holyoke
Steve Glasgow
PostPosted: Thu Jan 19, 2006 12:48 pm    Post subject: Re: Artificial Horizon Reply with quote
Thanks to all who replied to my orriginal post. Your input has been very helpfull. At present I'm leaning toward the ADI by Trutrack.
Steve Glasgow-Cappy
Cappy's Toy
RV-8 N123SG
hawk(at)digisys.net
PostPosted: Fri Jan 20, 2006 12:37 pm    Post subject: Artificial Horizon Reply with quote
Beating this dead horse one more (and like you, I hope last) time...
My friend Maurie powered up his new TruTrak ADI on the bench this morning,
and the results of extensive testing are:
1. Tilt the ADI 30 degrees to the side on the bench. After a variable
small transient, the display reverted to the level centered position.
2. Tilt the unit on its side (90 deg roll angle). Same result, washed back
to level, centered and stayed there.
3. Rapid pitch to 20 degrees Nose Up and hold. After a slight upward
transient, went to level centered and stayed there.
Summary: No roll angle or pitch angle information is displayed by the unit.
It is NOT an attitude indicator.
Functionally it seems to be a Turn Coordinator with an integrated VSI.*
* There may be some inputs from roll or pitch acceleration cues used to
"quicken" the display, but they seem to go away as soon as the acceleration
is removed and a steady-state roll angle or pitch angle is established.
Hawkeye
Steve Glasgow
PostPosted: Sat Jan 21, 2006 5:14 am    Post subject: Re: Artificial Horizon Reply with quote
Here is another option. Does anyone have any experence with it?
http://www.lightflying.com.au/Stratomaster%20Pages/Artificial%20Horizons%20&%20Compasses.htm
Steve Glasgow-Cappy
Cappy's Toy
RV-8 N123SG
Bruce(at)glasair.org
PostPosted: Sat Jan 21, 2006 6:35 am    Post subject: Artificial Horizon Reply with quote
I really don't understand this rush to go out and bet your life on untested,
uncertified instrumentation.
Bruce
www.glasair.org
ebundy(at)speedyquick.net
PostPosted: Sat Jan 21, 2006 8:05 am    Post subject: Artificial Horizon Reply with quote
I don't know if you're referring to one particular unit, or new instrument
technology in general, but having had a gyro failure in IMC, I understand it
very well. Also, having had to pay for several vacuum gyro/pump rebuilds I
LOVE having an electronic EFIS and digital engine management system.
Anyone want to buy a complete Rapco vacuum system and AH?
Ed Bundy
on untested,
Bruce
PostPosted: Sat Jan 21, 2006 8:50 am    Post subject: Artificial Horizon Reply with quote
While a transistor or computer chip might have a greater MTBF than
mechanical gyros, The software that drives these new wonders remains, for
the most part, untested. Sure the companies make some rudimentary tests but
nothing like the full DO178 compliant tests required of certificated
electro-whizzys.
Bruce
www.glasair.org
rv8ch
PostPosted: Sat Jan 21, 2006 9:38 am    Post subject: Artificial Horizon Reply with quote
I agree that the software is the weak point in any computer
system. Always has been, probably always will be. There
are many things, however, that are higher risk than these
devices, including the electric system. I've read of
forced landings due to electric system failure, but
I can't recall a single crash due to an uncertified
electronic AI failing. Not saying it has not happened,
but I have not seen any reports.
I think a well-designed and implemented electric system,
a la Bob N., and two independent AIs from different
manufacturers will be *a lot* more reliable than a
certified vacuum pump and certified gyro AIs.
electro-whizzys.
Bruce
www.glasair.org
Mickey Coggins
http://www.rv8.ch/
khorton01(at)rogers.com
PostPosted: Sat Jan 21, 2006 10:26 am    Post subject: Artificial Horizon Reply with quote
remains, for
tests but
electro-whizzys.
DO-178 compliance only "ensures" that the software code has correctly
implemented the specification that describes how it should function.
DO-178 compliance does not ensure that the specification is correct
and complete (it attempts to do this, but it fails). I have done
quite a bit of flight testing on aircraft with new systems with
DO-178 compliant code. Most of the problems that we find are due to
problems with the functional specification - i.e. the coder did a
perfect job incorporating a flawed specification. There are often
particular scenarios that the functional specification did not
envision, and this leads to anomalous behaviour.
DO-178 compliant or not, the only way to determine if the system
works correctly is to to a lot of testing, over the full range of
conditions that the system will see in service.
Kevin Horton RV-8 (finishing kit)
Ottawa, Canada
http://www.kilohotel.com/rv8
PostPosted: Sat Jan 21, 2006 10:39 am    Post subject: Artificial Horizon Reply with quote
That's because no one is left alive to tell us.
Bruce
www.glasair.org
Steve Glasgow
PostPosted: Sat Jan 21, 2006 10:40 am    Post subject: Re: Artificial Horizon Reply with quote
Bruce
www.glasair.org
There is no rush. Some of us have trashed our gyros doing acro and would like to find a solid state replacement that fits in the hole in our panels.
Steve Glasgow-Cappy
Cappy's Toy
RV-8 N123SG
PostPosted: Sat Jan 21, 2006 10:43 am    Post subject: Artificial Horizon Reply with quote
DO178 compliance, faults included, at least insures a known level of
functionality, otherwise, as I've said before, everyone is a beta tester.
Bruce
www.glasair.org
PostPosted: Sat Jan 21, 2006 11:01 am    Post subject: Artificial Horizon Reply with quote
If you use your airplane for acro why do you need gyros?
Bruce
www.glasair.org
rv6n6r(at)comcast.net
PostPosted: Sat Jan 21, 2006 11:50 am    Post subject: Artificial Horizon Reply with quote
untested, uncertified instrumentation.
Bruce
www.glasair.org
We are in a rush to get away from betting our lives on antiquated technology that has a proven track record of marginal reliability (truckload of FAA certification paperwork notwithstanding.) Besides, no one's advocating doing away with the concept of independent backup instruments.
Bruce
www.glasair.org
Okay, I get it now. You're on this list just to heckle us, right? Okay I'll humor ya.. Wink Here's the deal -- few RVers can resist the occasional or even not so occasional loop, aileron roll, cuban-8, etc., whether or not some of us also fly IFR in order to get from point A to point B when the clouds are down low. These are versatile machines, why should the instrumentation be less so?
Randall Henderson
RV-6
PostPosted: Sat Jan 21, 2006 12:50 pm    Post subject: Artificial Horizon Reply with quote
No, I'm really not on this list to heckle you guys. My Glasair III has a 75k
panel and no EFIS, I do have an EHSI though. I did some serious research
into this subject (low cost EFIS) when I was making the decisions for my own
airplane. I'm just trying to pass on some of the information I uncovered and
the decision tree that led me to this point.
Let me give you the LONG story. The FAA has determined that in order for an
EFIS to be considered/certified in an aircraft as a PRIMARY attitude display
and means of navigation, it must meet several criteria. The main one's are
that there be dual independent systems with an electronic comparator/alerter
and a backup third tie breaker attitude gyro. I'm sure you all have seen the
certified Garmin G1000, Avidyne and Chelton certified single systems now
coming out without duel redundant systems. How did they do that? It's
simple, all these EFIS systems in certified airplanes are certified as
SECONDARY flight display systems, not PRIMARY. The old fashioned backup
steam gages are the primary flight instruments for the airplane.
What's the big deal? It has to do with human factors engineering
(man/machine interface). Data point - A recent FAA study showed that it took
the average GA pilot 4 seconds to respond (lower the nose) to an engine out
takeoff emergency. 4 seconds! That's a long time. Now, we've all looked at
these new displays, very pretty and HYPNOTIC. If they fail and don't alert
or go dark the average GA IFR pilot will take a long time to revert to
needle, ball, and airspeed. If you're at 400 AGL on the ILS looking for the
runway on an approach to minimums and the AHRS hits a bad line of code,
giving you an erroneous 10 degree nose down pitch command, you're toast. The
dual system/alerter/third gyro are there to try and give you a chance to
survive when time is of the essence.
Oh, you're a super pilot on partial panel and don't need all this redundant
stuff, good you make your choices and go. But just be aware of the pitfalls
of your decisions. Safer? I don't know. Time will tell. I just don't want
any of you guys to be among the statistics.
Bruce
www.glasair.org
mkellems(at)bellsouth.net
PostPosted: Sat Jan 21, 2006 12:58 pm    Post subject: Artificial Horizon Reply with quote
Am I out of line by asking. Isn't the testing and trying of new ideas the
core of Experimental Aviation? Isn't that what it's all about?
Where would we be today in this "hobby" of ours without new untested ideas?
One that comes to mind is the complete building of a fiberglass aircraft.
Oh, and Do Not Archive. Mike
Steve Glasgow
PostPosted: Sat Jan 21, 2006 2:20 pm    Post subject: Re: Artificial Horizon Reply with quote
Okay, I get it now. You're on this list just to heckle us, right? Okay I'll humor ya.. Here's the deal -- few RVers can resist the occasional or even not so occasional loop, aileron roll, cuban-8, etc., whether or not some of us also fly IFR in order to get from point A to point B when the clouds are down low. These are versatile machines, why should the instrumentation be less so?
Randall Henderson
[/quote]
Thanks Randall, I agree totally. What is a Glasair anyway?
Can they go over the top and round and round?
Steve Glasgow-Cappy
Cappy's Toy
RV-8 N123SG
dbris200(at)sbcglobal.net
PostPosted: Sat Jan 21, 2006 5:38 pm    Post subject: Artificial Horizon Reply with quote
Now come on guys, these transistors and ic's are mostly - yes - plastic!
So Bruce might have a point, after all he knows plastic.
Dave
Randall Henderson
Steve Glasgow-Cappy
Cappy's Toy
RV-8 N123SG
http://forums.matronics.com/viewtopic.php?p=5752#5752
[/quote]
nyman(at)bellsouth.net
PostPosted: Sun Jan 22, 2006 7:40 am    Post subject: Artificial Horizon Reply with quote
<<From: "Bruce Gray" <Bruce(at)glasair.org>
electro-whizzys.>>
Chelton did. They use the same hardware and software in systems they sell
to the experimental market.
Steve
N174AS
MEM
PostPosted: Sun Jan 22, 2006 8:42 am    Post subject: Artificial Horizon Reply with quote
No, they don't. The software is the same, the hardware is not. Take for
example the AHRS, the certified units use the Crossbow 500 series or better,
the non-certified units use the Crossbow 400 series. The 400 series has just
been flagged by a Crossbow SB as VFR use only. They found a few software
bugs they have to iron out. The 400 series AHRS are not certified.
FMI: http://www.xbow.com/Support/Support_pdf_files/Service_Letter_NAV425.pdf
Bruce
www.glasair.org
Goto page 1, 2  Next
Page 1 of 2
