Electonic ignition options
algrajek
PostPosted: Thu Jan 19, 2006 12:48 pm    Post subject: Electonic ignition options Reply with quote
Listers:
At the risk of starting a huge thread: What are the different types of
ignition systems out there for the I/O 360? Mfg and comments good or bad for
each?
Al Grajek
RV8
engine re-build
just rv8in
bniles(at)cfl.rr.com
PostPosted: Thu Jan 19, 2006 4:01 pm    Post subject: Electonic ignition options Reply with quote
Yes, this could start a huge thread. I would suggest googling the various
manufacturers you hear and read about. There is a TON of info out there.
Also, I don't know what you are building, but on Van's website are websites
of builders who have gone to great lengths to document their building
process. You will find months of research there. Good luck. PS I went
with the Aerosance FADEC. It is more money up front but it has fuel savings
advantages, plus it runs each cylinder independently. It times ignitions,
meters fuel based on sensor readings. One moving part in the whole system.
Advantage: because fuel is constantly balanced to engine requirements and
EGT and CHT parameters, you should never have to worry about fouling one
plug while overleaning another cylinder and burning plugs or scorching a
cylinder due to momentary inatention or other factors. FWIW.. Godd luck
again in your reasearch,
tomscherder(at)hotmail.co
PostPosted: Thu Jan 19, 2006 8:28 pm    Post subject: Electonic ignition options Reply with quote
Al,
I really love our lightspeed. If the other mag goes I'm putting another one
on. Quick starts, almost no RPM drop on mag check.
Tom
algrajek
PostPosted: Fri Jan 20, 2006 9:45 am    Post subject: Electonic ignition options Reply with quote
Tom:
How have you been? We need to get together. Where is the best place to get
the lightspeed. and How much?
Al
[quote]From: "Tom Scherder" <tomscherder(at)hotmail.com>
Reply-To: rv8-list(at)matronics.com
To: <rv8-list(at)matronics.com>
Subject: Re: Electonic ignition options
Date: Thu, 19 Jan 2006 23:27:08 -0500
Al,
Tom
just rv8in
PostPosted: Fri Jan 20, 2006 8:21 pm    Post subject: Electonic ignition options Reply with quote
Al,
I got our lightspeed on their website.I had a problem with a wire and they
took care of it. I think I paid about $900.00 for it. A new mag is pretty
close. They claim you can expect a 10 horsepower boost with 1 lightspeed and
even more if you use 2. I can't tell any difference since we put it on in
the beginning. I will say that this little plane can sure scoot. We cruise
at over 190 and I had another pilot tell me that we could get over 200 if we
keep everything against the wall. I had 2500 with full power at 5500ft and
got consistently 194+mph.
Tom
