jason(at)trek-tech.com Guest
Posted: Tue Aug 15, 2006 8:27 am Post subject: Alternate engine possibility for Firestar or Firefly |
Hello all,
I ran across this today on the web. I don't know anything about it, but I thought I would pass it along.
http://www.rotary-xr40.com/
Jason
MKIIIC BMW R100 (finished and FAA approved, just trying to find the best place to test fly it)
Portland, OR
Ralph Hoover
Joined: 09 Jan 2006 Posts: 206 Location: Central Ohio
Posted: Tue Aug 15, 2006 12:34 pm Post subject: Re: Alternate engine possibility for Firestar or Firefly |
Interesting. Single cylinder with reduced vibration, rotary. Single carb. I do however wonder the fairness of the 'efciency rating against the 503 DIDC (which I have of my firestar), as being 4 GPH. Appears to be a very inifficient RPM and speed for the test aircraft with the 503. Dont know.
Radiator and electric start at 55 #. Pretty impresive.
"Phantom X-1, 260 lb pilot and 30 lbs of fuel". Thats a heavey duty pilot, even from my standards (220#). Guess with all that it might be close to 4 gph. If the pilot is the same one in the picture on your opening page, he has too have a huge butt, caues he is about average in build.
I do have a question. How do you "derate an engine from 52 hp to 40 hp? If its based on rpm, then I understand, even though I could rev engine past the rated RPM.
Soyfused (verses Cornfused, which I would probably be dead by now), in Ohio Ralph!
a58r(at)verizon.net Guest
Posted: Tue Aug 15, 2006 2:00 pm Post subject: Alternate engine possibility for Firestar or Firefly |
The classic method of sqeezing more hp outa rotaries is higher rpm.
In some of my very early Wankels, before I discovered they were so
fragile, I could get them to 10K, but they didn't last too long! Very
smooth engine. Had first ones in '66...single rotor with a type of CDI.
regards,
Bob N.
Steve Boetto
Posted: Wed Aug 16, 2006 5:43 pm Post subject: Alternate engine possibility for Firestar or Firefly |
Bryan and I saw this at SnF the last two years in a row. It really has a potential for the Firefly.
I would love to put one on the Firefly Floatplane, BUT, It's exhaust configuration does not lend itself to a pusher application. You can probably work around it but have been waiting to see how the engine works for a while. It has a really nice alternator and starter at less weight than a 447. Maybe the importer will come up with a pusher configuration.
Steve
Firefly 007 on floats
