wingsdown(at)comcast.net Guest
Posted: Sun Aug 13, 2006 8:21 am Post subject: KITFOX PARTS AND OTHER AIRCRAFT PARTS FOR SALE UPDATE: |
KITFOX PARTS AND OTHER AIRCRAFT PARTS FOR SALE UPDATE: 081306
Just listed on Ebay wings and such under kitfox.................starting
bid is $1.00 (SOLD)
Also just listed on Ebay flight gear bag and accessories under flight
bag............. (SOLD)
Custom air oil separators as seen on sportflight pic post $150.00
each......................both for 250
CAP 140 complete hub assembly for NSI redrive, may fit others, no blades
$1,500 OBO.............
E.I digital EGT instrument, no probe $180 each or both for
$300.00....................
Hand held radio Yaesu VXA-200. This was there top of the line model and
should be compared to same now, has altitude,density altitude,pressure
alt. Temp, VOR heading plus extra Nmhi battery and programming software
and cable, list was over $600.00 sell for $350.00....................
COM/nav antenna model VHF5-1 by AAE thin flat composite style list $125
sell for $85.00..................
Intercom by PS Engineering model PM1000II with digital cockpit record
option $300.00..................
Electric clock model MD-90 $60.00.....................
Turtle deck with smoke grey lexan, has scratch in glass 150.00 if you do
a pick up I have material for replacement......sold
Electric servo/ jack screw assembly $500.00 OBO..................
Wheel pant left side only painted ready to mount or repaint
$50.00............
Rudder $300.00..............sold
Elevator $225.00..............sold
VDO gages:
2 1/8 tack , water temp,oil pressure, boost, large RPM 3 1/8 maybe 1/4,
EGT make offer..............
Cargo bay bag with aluminum custom fit bottom, no sagging. $95.00
Left long wing, moderate damage pick up only,
$1,500.00....................sold
Right long wing major tip damage , $750.00................sold
Lift struts, pair, faired $600.00 pick up only................sold
Horizontal Stabilator faired strut braces pair $100.00.................
Custom super trapp exhaust system. Will require the welding of a 3 bolt
flange to exhaust down pipe. $300.00 Pics on request....................
EA-81 turbo engine parts, blocks, engine mounts left and right, cranks,
rods, push rods, heads, cams, open price to be set, accepting
offers................
NSI alternator pulley New $60.00.......................
SS flight controls all factory parts available in excellent
condition....................
Strut end farings. These go at the top of the strus for less drag.
$60.00 for the complete set never installed.....SOLD
Carbon monoxide by coguardian. Plugs into lighter socket audible plus
digital level indicator. They have a web site. $99.00 ...............
Bendix/King fin type transponder antenna with ground plane plate
$50.00.....................
Airborne vacuum regulator valve model 2H3-23 #9AK FAA PMA list $728.00
in ACS catalog make offer..................
Airborne filter mount with filter best offer.............
Wood pistol grips modified one short on passenger PIC side regularl
length with PTTs $50.00 both..................
Mr. Funnel large for water seperation funnel filling of fuel
$20.00...............
Remote PTT $5.00 with other purchse..............
Cessna dual vacuume gage with pop up no vac indicators can be used on
single system PN C668519-0101 $35.00............
Tire or tyre front Aero classic 11X4.00-5 8ply with new tube
$40.00......................
Cockpit light with flood or spot adjustment (model S1990) with red or
white light adjustment, with dim bright adjustment manufactured by
soderberg $55.00.......................
Landing light pulse unit. This is a CODE 3 unit model 700 which will
pulse or run steady, switch able $30.00. Beats the heck out of STC
units...........
Thanks so much
Rick
