Fuel Sending Units
rice737(at)msn.com
PostPosted: Mon Jan 02, 2006 11:24 am    Post subject: Fuel Sending Units Reply with quote
Hi All,
I've just started working on my fuel sending units and tested both outside
the tank, attached to a fuel gauge. They are the stock Stewart Warner and
Vans gauge. One has a drop out, to empty, at about 3 gallons on the gauge,
the other at 12 gallons, then comes back. Should I send them back or is
normal for all at some point or does it really matter.
Paul
RV8QB
ronlee(at)pcisys.net
PostPosted: Mon Jan 02, 2006 1:02 pm    Post subject: Fuel Sending Units Reply with quote
I assume that my sender units are Vans and the original fuel gauges were
empty at around 1/8 and 1/4 from empty. Not ideal. I replaced the fuel gauges
with newer Vans units and they are fine where it counts (below ten gallons
and probably under 15). Despite having a fuel totalizer I consider accurate
gauges at the lower end to be important.
Ron Lee
dreel(at)cox.net
PostPosted: Tue Jan 03, 2006 5:27 am    Post subject: Fuel Sending Units Reply with quote
I just tested my Van's gauges with the SW sending units. At 2.5gal they read 2.5 gal. At 5 gal the left gauge read 4.5gal, the right read 6 gal. In my opinion, an erratic reading is unacceptable & probably indicates a faulty sending unit. An erroneous but consistent reading can be corrected by a placard.
Dave Reel - RV8A
Hi All,
