ron.mcgann(at)baesystems. Guest
Posted: Tue Aug 15, 2006 6:05 pm Post subject: Lubricating UHMW Blocks |
Question for today . . .
I was finishing off the control activation and flaps last night and noticed a significant amount of friction between the UHMW blocks and flap torque tubes. Given that there are four such tube/block interfaces, the total amount of friction may create significant startup torque on the flap motor. I understand that the UHMW blocks are teflon based and therefore self lubricating, but is there a recommended way of reducing the surface friction with the torques tubes? Is lightly sanding or polishing the paint from the torque tubes or inside of the bushing, or using an additional lubricant preferred??
thanks in advance (yet again)
Ron
#187 [quote][b]
jesse(at)itecusa.org Guest
Posted: Tue Aug 15, 2006 6:40 pm Post subject: Lubricating UHMW Blocks |
They do go in pretty tight, but that doesn’t seem to make any difference on the functionality of the flaps. I am sure, with the torque on the flap motor, it is probably better to have them tight and add a little bit of torque than to have them loose and add the possibility of vibration/movement in the system. I would think that the amount of torque in the plastic blocks would be substantially less than the torque of dropping the flaps from 0 to 15 or 15 to 30 degrees at 100kts/mph, whichever the max flap speed is. We haven’t used any lubrication or modified the parts at all. Anybody else out there with different experiences?
Jesse Saint
I-TEC, Inc.
www.itecusa.org
W: 352-465-4545
C: 352-427-0285
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of McGANN, Ron
Sent: Tuesday, August 15, 2006 10:05 PM
Subject: Lubricating UHMW Blocks
Ron
#187 | Quote: | | http://www.matronics.com/Navigator?RV10-List | 01234567890123
-- No virus found in this incoming message. Release Date: 8/14/2006
8/14/2006
coop85(at)bellsouth.net Guest
Posted: Tue Aug 15, 2006 6:48 pm Post subject: Lubricating UHMW Blocks |
Ron,
I opted for the light sanding and it seemed to help a lot.
Marcus
40286
First flight (attempt) this Saturday!
Ron
acs(at)acspropeller.com.a Guest
Posted: Tue Aug 15, 2006 8:42 pm Post subject: Lubricating UHMW Blocks |
Ron, I used a scotchbrite pad on the tube…..checked the flap motor with a 12V supply….minimum friction.
John 40315
Sent: Wednesday, 16 August 2006 12:05 PM
Ron
#187 | Quote: | | - The RV10-List Email Forum ---> | 01234567890123
flysrv10(at)gmail.com Guest
Posted: Wed Aug 16, 2006 2:37 am Post subject: Lubricating UHMW Blocks |
I believe using white grease on them is OK.
Do not archive.
Ron
#187 | Quote: |
ntribution
| [b]
Tim(at)MyRV10.com Guest
Posted: Wed Aug 16, 2006 3:38 am Post subject: Lubricating UHMW Blocks |
Mine were pretty tight too, but I just left them. Spraying them
with something may attract dust and stuff. 110 hours later
they're still fine. I think the friction is pretty minor
compared to the aerodynamic forces they'll be working against.
McGANN, Ron wrote:
| Quote: | Question for today . . .
Ron
#187
