		Thom Riddle
				 Posted: Sat Jan 21, 2006 8:43 am    Post subject: Jabiru 2 cyl. |
				Here is the response I got from Jabiru USA on the subject.
 Jabiru plans to introduce a 1100cc 45 hp, 85lb 4 stroke engine soon,
 perhaps
 at Sun N Fun.  I expect a spec sheet soon.  It will be very similar to
 the 4
 cyl jab with same alternator, starter, and ign system - just two fewer
 cylinders.
 It is running in ground tests on the test stand and Jabiru reports that
 they
 are generally pleased.
 One of the questions we have, though, is whether there is a market for
 an
 engine with those specs priced at $7,500 - $8,000.  Unfortunately
 removing
 half the cylinders from the 2200 engine does not remove half the cost.
 Pete Krotje
 Jabiru USA Sport Aircraft, LLC
 Since fuel consumption in most modern 4-stroke engines is almost a
 linear function of horsepower, one could expect a 45 hp engine to burn
 roughly  2 1/4 US gallons per hour at 75% power. I know my 912(80hp) at
 75% power burns 4 gph. 80 x .75 = 60 hp or 15 hp/gph. 45 x .75 = 33 3/4
 hp ==> 2 1/4 gph (33.75 / 15).
 Thom in Buffalo
  |  | - The Matronics Kolb-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  _________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
		firebug
  Joined: 22 Jan 2006 Posts: 36 Location: Montgomery Alabama
				 Posted: Sun Jan 22, 2006 7:44 am    Post subject: Re: Jabiru 2 cyl. |
				For that price they will not sell that well. The engine market has gotten out of hand with its pricing. With the Jabiru it develops it's horsepower at 3300 rpm which is too high for most of the ultralight applications. You cannot swing a long enough prop to generate enough thrust to benefit our "Drag Queens". Kolbs, Skyraiders, Quicksilvers and the like have a lot of drag and fly slow they need a longer prop than planes like the Sonex.
		JetPilot
				 Posted: Sun Jan 22, 2006 9:11 am    Post subject: Re: Jabiru 2 cyl. |
				 	  | firebug wrote: | 	 		  | For that price they will not sell that well. The engine market has gotten out of hand with its pricing. With the Jabiru it develops it's horsepower at 3300 rpm which is too high for most of the ultralight applications.  |
 Yep, I never liked the Jabiru anyways, they look like they were machined in someones garage.  Very primitive in design.
 I would buy an HKS over a 2 cylinder Jabiru any day, the price is about the same and the prop speed is much slower.
 I bought a Rotax 912s over the 4 cylinder Jabiru, didnt care how much more it cost, I just wanted the best engine I could get.  The Rotax is also a much more advanced design    ....
  _________________ "NO FEAR" -  If you have no fear you did not go as fast as you could have !!!
Kolb MK-III Xtra, 912-S |
				 Posted: Sun Jan 22, 2006 9:37 am    Post subject: Jabiru 2 cyl. |
				Hi Mike B:
 I don't have any experience with Jab or HKS, only what I have seen at
 the flyins, and flying with John W when his Kolbra was Jabiru powered.
 Since John's Jab, they have gone to hydraulic valve lifters and upped
 the power some.  This was a good improvement.  However, they are still
 direct drive and direct drives do not perform well on Kolbs.  Kiwi Mik
 may want to defend his position on how well they perform, but I have
 my own "actual" flight comparison (that most of you all told me was
 worthless) between my 912ULS powered MKIII and John W's Jab powered
 direct drive Kolbra.  Very quickly, cruise was about the same, but
 acceleration, take off, and climb, there was no comparison between the
 two power plants.  I was pleasantly shocked first time John W and I
 flew together after installation of the 912ULS on his Kolbra.  He and
 I take off and climb about the same, maybe the MKIII is a little
 quicker, but after that, it is all over.  The Kolbra climbs and walks
 away from the MKIII.  I think one of the first things a person sees
 when they look at the Jab is the beautiful CNC machine work on the
 engines.  I do think they are a piece of art.  However, if the newer
 versions still have the dual distributors for ignition, they haven't
 made any progress in the ignition area.  One of the problems John W
 encountered on our 2003 Kittyhawk flight was a Jab that would not
 start after sitting out at night in very damp weather.  The 912's and
 582 fired right up the next morning.
 The Rotax is also a much more advanced design.
 Mike B, I don't know that the 912 is so much more advance design or
 not.  It is basically a flat 4 opposed that uses a basic design.
 However, the Ducati ignition, integral reduction drive, water/oil
 cooling the heads, and the nikaseal (sp) aluminum cylinders, plus dry
 sump lube system do a great job in making the 912 a good reliable,
 endurable, very low maintenance engine.
 Our little Kolb aircraft thrive on power plants with reduction drives,
 and don't seem to do so well with direct drives.
 MKIII
  _________________ John Hauck
Titus, Alabama |
