zackrv8
Posted: Fri Aug 18, 2006 5:57 pm Post subject: HTS |
Guys,
Here's what I am doing for the HTS (Hot Tunnel Syndrome). I made two brackets that raise up off the bottom floor by 1 inch. They are simple U-brackets made from .050 2024. The existing cradle brackets are then riveted on and three holes on each flange are then riveted to the Tunnel side walls.
I have a"KoolMat" insulation layer laying on the floor followed by 1 inch of closed cell foam I bought from Wicks. The fuel lines will be firesleeved when I finish making them.
SO much easier working in the Tunnel without the side skins on!
Zack
47.93 KB |
418 Time(s) |
32.09 KB |
370 Time(s) |
20.41 KB |
366 Time(s) |
46.7 KB |
390 Time(s) |
_________________ RV8 #80125
RV10 # 40512 |
