harleyrider.57(at)juno.co Guest
Posted: Fri Jan 20, 2006 5:49 am Post subject: Xm Satellite to intercom |
Hi All,
I'm new to the list and this is my 1st question. I'm building a Bearhawk and getting ready to start on the panel and electrical connections.
I am planning an Audiovox XM satellite connected to my PS Engineering PM2000 intercom. The audiovox is designed to transmit to your car's FM radio but it does have an output for headphones. My question is, if I hook up the headphone output to the intercom, will I need to amplify the signal somehow or will a direct connection work? If amplification is needed, where can I get it?
Eric Newton - Long Beach, MS
BH #682
http://mybearhawk.com
flyeyes(at)mac.com Guest
Posted: Fri Jan 20, 2006 6:37 am Post subject: Xm Satellite to intercom |
On Jan 20, 2006, at 7:42 AM, Eric Newton wrote:
57(at)juno.com>
Hi All,
connections.
Eric, the PS Engineering intercoms have "music input" pins that are
what you want. I don't remember the pin numbers off the top of my
head, but the diagrams are available online. I ordered my radios
from John Stark, and he sent them pre-wired, with each wire labeled.
I soldered the labeled wires to a female headphone jack (a buck or to
from Radio Shack) that I put in a convenient place, and now I can
listen to my XM, or ipod, or whatever, in flight. Very easy to do.
lists(at)stevet.net Guest
Posted: Fri Jan 20, 2006 9:33 am Post subject: Xm Satellite to intercom |
Eric,
Please make sure that you can turn the FM transmitter off! You don't
want that FM transmitter broadcasting while you have it in your
panel. There are other units out there that have aux. outputs for
this purpose and where you can turn the FM off. The unit that I'm
using is the SkyFi2 and it has all these features.
On Jan 20, 2006, at 5:42 AM, Eric Newton wrote:
57(at)juno.com>
Hi All,
connections.
BH #682
Best Regards,
Steve Thomas
SteveT.Net
steve(at)stevet.net
805-569-0336 Office
