mstewart(at)iss.net Guest
Posted: Fri Aug 11, 2006 3:20 am Post subject: Max Altitude in an RV |
I found this George in the archives. | Quote: | | “Note of interest alt champ according |
to Van's specs is a 180HP RV-4 at 28,600 feet”
Where does one find this information?
I think I can beat this # above and plan a run at it tomorrow.
Whats the best way to log the data? What makes it an official reading?
My goal is to log the highest stock airframe RV altitude.
I ran the low 20’s altitude last week and was running 190KTAS so Im sure I got a lot of vertical umph left. Don’t know how much but I plan on finding out tomorrow.
Mike
FLYaDIVE(at)aol.com Guest
Posted: Fri Aug 11, 2006 4:12 am Post subject: Max Altitude in an RV |
In a message dated 8/11/06 7:22:19 AM Eastern Daylight Time, mstewart(at)iss.net
writes:
| Quote: | My goal is to log the highest stock airframe RV altitude.
I ran the low 20's altitude last week and was running 190KTAS so Im sure
I got a lot of vertical umph left. Don't know how much but I plan on
Mike
Mike:
Why would the airframe be the controlling factor in this altitude quest?
I can understand the drag factor and the lift factor of the wings but isn't
it the engine that determines the altitude?
Barry
"Chop'd Liver"
"Show them the first time, correct them the second time, kick them the third
time."
Yamashiada
khorton01(at)rogers.com Guest
Posted: Fri Aug 11, 2006 4:27 am Post subject: Max Altitude in an RV |
On 11 Aug 2006, at 07:18, Stewart, Michael (ISS Atlanta) wrote:
Mike
Talk to the soaring guys. They have altitude logging devices that are used when they hope to qualify for one of their Diamond Badges. If you want an official record, maybe there is a US altitude record for aircraft powered with a normally-aspirated engine in your weight class. Terry Jantzi set the Canadian record at over 26,000 ft in a 180 hp RV-6. That RV-4 number is almost certainly an extrapolation of his record, assuming a bit less weight.
http://home.hiwaay.net/~sbuc/journal/high.html
Stock airframe? I'm amazed that you would put that heavy engine on without making any airframe mods.
Kevin Horton RV-8 (finishing kit)
Ottawa, Canada
http://www.kilohotel.com/rv8
Posted: Fri Aug 11, 2006 5:20 am Post subject: Max Altitude in an RV |
I don’t know a soaring guy. Guess I’ll have to find one.
“I'm amazed that you would put that heavy engine on without making any airframe mods.”
Yeah nuts aint itJ
Thanks for the great idea.
Mike
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Kevin Horton
Sent: Friday, August 11, 2006 8:27 AM
To: rv-list(at)matronics.com
Subject: Re: Max Altitude in an RV
Mike
Ottawa, Canada
Posted: Fri Aug 11, 2006 5:40 am Post subject: Max Altitude in an RV |
Oh Kevin,
I forgot to ask, where does one find these classes of records. I have scoured the internet with no luck.
Mike
Mike
Ottawa, Canada
n5lp(at)warpdriveonline.c Guest
Posted: Fri Aug 11, 2006 6:16 am Post subject: Max Altitude in an RV |
On Aug 11, 2006, at 7:38 AM, Stewart, Michael (ISS Atlanta) wrote:
| Quote: | Oh Kevin,
Mike
http://www.fai.org/
Larry Pardue
Carlsbad, NM
RV-6 N441LP Flying
Previous glider world record holder http://records.fai.org/gliding/
history.asp?id1=DW&id2=1&id3=19
rv8(at)lazy8.net Guest
Posted: Fri Aug 11, 2006 6:42 am Post subject: Max Altitude in an RV |
For a 540 powered RV, try Bruce Bohannon's Flying Tiger...49,000 + ft.
John
Stewart, Michael (ISS Atlanta) wrote: | Quote: | v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} <![endif]--> st1\:*{behavior:url(#default#ieooui) } <![endif]-->
Oh Kevin,
Mike
From: owner-rv-list-server(at)matronics.com (owner-rv-list-server(at)matronics.com) [mailto:owner-rv-list-server(at)matronics.com (owner-rv-list-server(at)matronics.com)] On Behalf Of Kevin Horton
To: rv-list(at)matronics.com (rv-list(at)matronics.com)
Subject: Re: RV-List: Max Altitude in an RV
Mike
Ottawa, Canada
jclarkmail(at)gmail.com Guest
Posted: Fri Aug 11, 2006 6:44 am Post subject: Max Altitude in an RV |
Yup ... That's what I was trying to remember Mike.
Also see: http://www.naa.aero/ for US only I think.
James
On 8/11/06, Larry Pardue <n5lp(at)warpdriveonline.com (n5lp(at)warpdriveonline.com)> wrote:[quote] --> RV-List message posted by: Larry Pardue <n5lp(at)warpdriveonline.com (n5lp(at)warpdriveonline.com)>
| Quote: | Oh Kevin,
Mike
http://www.fai.org/
Larry Pardue
Carlsbad, NM
RV-6 N441LP Flying
history.asp?id1=DW&id2=1&id3=19 james(at)nextupventures.com (james(at)nextupventures.com) .
jlane(at)cei.net Guest
Posted: Sun Aug 20, 2006 9:45 am Post subject: Max Altitude in an RV |
So what is the max altitude of an RV? Did you fly too near the sun?
Posted: Mon Aug 21, 2006 2:39 am Post subject: Max Altitude in an RV |
Got to 24k with passenger. Had plenty left but got run into a holding pattern with Hartsfield runways closed due to storms. Had planes all over the place. Not fun!
Anyway now that I have had a good systems check, Im ready to climb to the sun, +/- a few thousand feet.
Mike
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of jim lane
Sent: Sunday, August 20, 2006 1:44 PM
