ronlee(at)pcisys.net Guest
Posted: Mon Aug 21, 2006 9:32 am Post subject: Valve Stem Extender |
| Quote: | Re: the PITA of filling tires with wheel pants installed. We have bought a
valve stem extender (about 6" long and thin) this is easy to screw onto to
the wheel valve stem and then you can check the tire pressure and fill if
required from outside the wheel pant.
Chuck Rowbotham
Where did you find this Chuck? I had to make one using shorter valve stem
extenders connected with locktite.
Ron Lee
Dale Ensing
Joined: 11 Jan 2006 Posts: 571 Location: Aero Plantation Weddington NC
Posted: Mon Aug 21, 2006 9:51 am Post subject: Valve Stem Extender |
Cleveland Tools has a 5 inch extender. see
http://www.cleavelandtoolstore.com/searchprods.asp
Or, go to auto parts store and buy a flexible extender that is intended for
inner wheel on a dual wheel arranagement. It's about 7 or 8 inches and
easier to use because it allows for a bit of mis-alignment of wheel to port
in wheel fairing.
Dale Ensing
| Quote: | >Re: the PITA of filling tires with wheel pants installed. We have bought
a
| Quote: | >valve stem extender (about 6" long and thin) this is easy to screw onto
to
| Quote: | >the wheel valve stem and then you can check the tire pressure and fill if
>Chuck Rowbotham
Ron Lee
_________________ Dale Ensing
RV-6A
Aero Plantation
Weddington NC |
