dav1111(at)cox.net Guest
Posted: Sun Aug 20, 2006 2:18 am Post subject: Pre-Oiler |
I am using the GP301-12 pre-oiler from Infinity Aerospace ($230.00 plus
shipping).
http://www.infinityaerospace.com/
I obtained the check valve from a local plumbing supply house (don't get the
flapper type) and the hoses were made locally. I mounted the pre-oiler on
the right side firewall down low and ran the inlet line from an extra sump
plug and the outlet line up to the ECI 90 degree adapter drain plug 1/4"
even with the reduced line flow the pre-oiler works great.
Russ Daves
N710RV (Phase II - In Paint Shop)
rvbuilder(at)sausen.net Guest
Posted: Sun Aug 20, 2006 4:22 pm Post subject: Pre-Oiler |
If you want to save yourself about $100 on these, look around online.
These are common Reverso pumps. JD doesn't even change the part numbers
other than dropping the "H" off the end for high volume. He just sells
them at list price. One example is here:
http://www.marine-electronics-unlimited.com/Reverso+Oil+Gear+Pumps.html
Interestingly enough, they only have a temperature rating of 140F.
Michael Sausen
-10 #352 Fuselage
