bertrv6(at)highstream.net Guest
Posted: Sat Aug 19, 2006 2:12 pm Post subject: NAV AID QUESTION |
HI; I FINALLY CONNECTED MY NAV AID.. THAST IS BRACKET TO CONTROL STICK
AND PLUG, AND WIRE..ALL FINISHED.
BUT NOW....I SHOULD BE ABLE TO MOVE ALERONS, BY TURNING THE KNOB ON THE
AID UNIT... IT DOES NOT... NOTHING HAPPENS...I KNOW POWER IS GOING TO THE
SERVO, BECAUSE I SAW THE CRANK MOVING WHEN I WAS CENTERED IT,...
IT IS FRUSTRATING, I KNOW I AM DOING OR DID SOMETHING WRONG, CHANCES ARE
THE UNIT IS OK...
WHAT IS THE SUGGESTIONS OF THOSE, WITH THE NAV WING LEVELER UNIT/
ANY ONE HAD SAME TROUBLE/
THANKS
BERT
RV6A
Hopperdhh(at)aol.com Guest
Posted: Sat Aug 19, 2006 3:17 pm Post subject: NAV AID QUESTION |
Bert,
Do you have the switch in the right hand position -- Wing Leveler? Center is off -- servo out of gear.
Dan Hopper
RV-7A
In a message dated 8/19/2006 6:13:42 P.M. Eastern Daylight Time, bertrv6(at)highstream.net writes:
| Quote: | --> RV-List message posted by: bertrv6(at)highstream.net
THE UNIT IS OK...
THANKS
BERT
RV6A
do not es Day --> - NEW MATRONICS WEB FORUMS -
bsp; --> nbsp; - NEW MATRONICS LIST WIKI -
_-= ; p; - List Contribution Web Site ; =========================
Albert Gardner
Posted: Mon Aug 21, 2006 6:31 am Post subject: NAV AID QUESTION |
Have you gone through the setup procedure? Make sure the servo is turning
the proper way, centered, etc. Once it is properly installed, putting the
switch in the wl (right) position, the right hand knob will command a turn,
and the trim knob is used just like aileron trim but it will also cause
servo movement if you're just checking things out.
Albert Gardner
Yuma, AZ
_________________ RV-9A N872RV
RV-10 N991RV |
