john(at)leptron.com Guest
Posted: Tue Aug 22, 2006 9:58 am Post subject: : Kitfox-Fuel Flow |
Bob,
We had several planes go down with full tanks. They were down do to fuel
starvation. At the time we (the list and the factory and I believe the faa
were in also) decided no cross drains were necessary, they were of no use.
We also decided that a vent from the header tank was bad as it would allow
the header to drain with out sucking from a wing tank. The wing tanks could
un-port in turns because of the loop needed to fold the wings. The factory
also quit using the wing tank shut offs under the rear deck, but , I have
never agreed with that. Many of us at the time installed the header vent
lines to a drain fitting under the fuse. But I find once vented it is now
necessary to re-vent air from header. Once a year, seems to be plenty. Many
of us installed a 12 volt booster pump under the seat. Now when sucking fuel
at the engine, or at the booster pump, fuel has to come from one wing or the
other.
-> Kitfox-List message posted by: "Bob Unternaehrer" <shilocom(at)mcmsys.com>
I haven't been on the list long so excuse. I really can't see how a vent
cross tube at the top of each tank could cause porting,,,which I assume you
mean what I'd call "unporting" or getting no fuel flow from the supply line,
at the bottom of each tank, to the header tank behind the seat. BUT if
you've been there and done that,,,,that's good enough for me. Bob U.
Posted: Tue Aug 22, 2006 10:25 am Post subject: : Kitfox-Fuel Flow |
I forgot to mention the planes that went down doe to fuel starvation, were
full of fuel.
John
