forward fuse skins
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Rocket-List
kshannon(at)seanet.com
PostPosted: Thu Jan 19, 2006 1:29 pm    Post subject: forward fuse skins Reply with quote
Is anyone dimpling the forward .040 fuse skins instead of countersinking?
The machined countersink is easier and looks better, but dimpling should be
stronger, what did you all do?
Kevin Shannon
HR II
- The Matronics Rocket-List Email Forum -
http://www.matronics.com/Navigator?Rocket-List
blairclan(at)bigpond.com
PostPosted: Fri Jan 20, 2006 2:15 am    Post subject: forward fuse skins Reply with quote
I countersunk, next time I'd probably dimple, finish not so important
when painted.
Cheers
Tony
Jim Anglin
PostPosted: Fri Jan 20, 2006 6:51 am    Post subject: forward fuse skins Reply with quote
I'm probably the minority but i dimpled every skin and component .040" and less. It is stronger and easier. I also did this on my RV6 and didn't have the problem a lot of builders did with rivets loosening up on the belly.
jim HR II 144HR
DO NOT ARCHIVE
Jim Anglin
HR II N144HR
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Rocket-List All times are GMT - 8 Hours
