Airframe life expectancy
steveg(at)nternet.com
PostPosted: Fri Jan 20, 2006 3:04 pm    Post subject: Airframe life expectancy Reply with quote
I forwarded Jim's earlier email to my partner and his response is below. I
have not had time to review and research as Michael has. Seems crazy to me
that Oz sees winglets as capable of cutting a Commanders life in half. My
last AC500 had winglets and other than watching for corrosion at the
connection points and overall body I see no threat. Just another part of
the aircraft to inspect and maintain. Any knowledgeable comments
pertaining to Oz. Is Michael misreading something here??
Steve G
BobsV35B(at)aol.com
PostPosted: Fri Jan 20, 2006 3:36 pm    Post subject: Airframe life expectancy Reply with quote
Good Evening Steve,
I certainly do not understand why the folks down under want to extract such
a penalty from those who attempt to improve their flying machines, but may I
make a comment?
Adding winglets should make the outer portion of the wing more efficient.
Something like a tip plate. Getting a little more lift out there means that the
center of pressure (lift) moves outboard a bit. Moving the lifting point
outboard causes a greater bending moment at whatever point the bending moment is
calculated.
It appears to me that the people in charge down there are making those
onerous noises in an effort to force someone to develop data that will show the
increased bending moment is not great enough to demand cutting the useful life
in half.
Has anyone developed such data?
One the other hand:
Why not maintain the airplane as a US registered aircraft? Are we not
allowed to fly our US registered airplanes in Australia and then use US standards?
Just in case it matters, I do not own a Commander, but I did fly them quite
a bit forty to fifty years ago. I enjoy your list, but will leave if asked.
Happy Skies,
Old Bob
AKA
Bob Siegfried
Ancient Aviator
Stearman N3977A
Brookeridge Air Park LL22
Downers Grove, IL 60516
630 985-8503
In a message dated 1/20/2006 5:04:51 P.M. Central Standard Time,
steveg(at)nternet.com writes:
Steve G
PostPosted: Fri Jan 20, 2006 3:56 pm    Post subject: Airframe life expectancy Reply with quote
Bob,
Your input and knowledge are invaluable. I was part owner of AC500 N6291B
with Rob. Now only own Bonanza E35 N52DF and participate on both lists.
Dream of owning another AC500 and may wind up doing so with my Australian
business associate or may not. Either way, both lists are full of talented,
knowledgeable people that feed my thirst for aviation knowledge,
particularly involving specific types of aircraft. You even got me looking
at the new Xerion for my Bonanza the other day. Might do it!!
Steve G
BertBerry1(at)aol.com
PostPosted: Fri Jan 20, 2006 4:37 pm    Post subject: Airframe life expectancy Reply with quote
I must have missed the whole winglets conversation. Is that an article
posted somewhere?
Bert
wjrhamilton(at)optusnet.c
PostPosted: Sat Jan 21, 2006 6:50 am    Post subject: Airframe life expectancy Reply with quote
Folks,
In Australia, a large variety of aircraft are subject to locally
imposed fatigue life limits, they vary from reasonable ( based on the
record) through illogical to unreasonable, and finally downright crazy.
As to the last, take the Piper Seneca --- It was actually tested in a
rig by Piper to Australian designed fatigue criteria, (the test was
very severe, amongst other things zero allowance was made for engine
or fuel weight for bending relief) and the test was finally stopped
at the point where the wing/airframe could be declared "unlimited life" .
Never mind, a severe life was imposed "to be consistent"with other
aircraft. For pressure hull, don't even start me.
Where a wing is re-spared, the rest of the aircraft is limited to two
wing lifes. This leads to the wonderful result that a particular
C-310 fuselage and tail feathers has two lives ( don't quote me on
the figures, but let us say 14 or 28 thousand hours) depending on the
wing it is bolted on to!!
The history is interesting, the following is a highly biased summary.
Some years after the end of WW11, there were lots of P-51D wings
around the place, so about 100 new wings were tested to destruction,
resulting ( surprise, surprise) in a "bell curve" of failures, and
the just slightly contestable claim that Australia has discovered
metal fatigue.
Despite a more or less identical claim by the poms ( English for
those of you who haven't done a Crocodile Dundee refresher recently)
as a result of the loss of the "Square window" Comets, and;
Despite some fascinating stuff even then on the public record about
Boeing experience with the original 338, and the fact that
engineering text books put it 100 years or so earlier, in the early
days of railways, and some bridge collapses.
Compared to any other light twin, the Aero Commander "fatigue AD"
limits are not generally a big issue, they are 3 or 4 times the "average".
Best regards,
Bill Hamilton
At 10:35 21/01/2006, you wrote:
Good Evening Steve,
make a comment?
means that the
bending moment is
calculated.
will show the
useful life
in half.
One the other hand:
US standards?
Happy Skies,
Old Bob
AKA
Bob Siegfried
Ancient Aviator
Stearman N3977A
630 985-8503
Steve G
CONFIDENTIALITY & PRIVILEGE NOTICE
W.J.R.Hamilton,Glenalmond Group Companies,Fighter Flights Internet
Services and Warbirds.Net. & <wjrhamilton(at)optusnet.com.au>.
This message is intended for and should only be used by the
addressee. It is confidential and may contain legally privileged
information.If you are not the intended recipient any use
distribution,disclosure or copying of this message is strictly
prohibited.Confidentiality and legal privilege attached to this
communication are not waived or lost by reason of the mistaken
delivery to you.If you have received this message in error, please
notify us immediately to Australia 61 (0)408 876 526
Dolores capitis non fero. Eos do.
deneals
PostPosted: Sat Jan 21, 2006 7:03 am    Post subject: Airframe life expectancy Reply with quote
Thanks, Bill.
As former Chief Pilot for Nomad Distributors in the US, reading your post
about aircraft certifications in Australia makes me wonder....
How the heck did the NOMADS ever get certification!!??
___________________________
Deneal Schilmeister
St. Louis - Cincinnati
1997 SL500
http://homepage.mac.com/deneals/SL500.htm
http://homepage.mac.com/deneals/Sites/My_Commanders.htm
kamala(at)msn.com
PostPosted: Sat Jan 21, 2006 7:30 am    Post subject: Airframe life expectancy Reply with quote
suggest that for the technical info on winglets that you go to the source.
call john bosh at commander aero 888-881-5580. dick wartinger at commander
aero developed these winglets, they hold the stc. also the air force
engineneers at the air force facility used there wind tunnels and all
available u s government equipment and computing power to arive at the right
design for the commander wing. mason ps there are a lot of illegal
winglets out there!
[quote]From: "steve" <steveg(at)nternet.com>
Reply-To: commander-list(at)matronics.com
To: <commander-list(at)matronics.com>
Subject: RE: FW: Airframe life expectancy
Date: Fri, 20 Jan 2006 17:55:48 -0600
Bob,
talented,
Steve G
britmonk(at)adelphia.net
PostPosted: Sat Jan 21, 2006 2:21 pm    Post subject: Airframe life expectancy Reply with quote
I understand that the winglets are purely cosmetic and make no change in
the aerodynamic characteristics. Thus the BM should not be changed.
However it only takes about a 10% change in load to half the fatigue
life of a structure. Perhaps the Ozzies are just playing it safe.
Derek Monk
BobsV35B(at)aol.com wrote:
Good Evening Steve,
make a comment?
calculated.
in half.
One the other hand:
Happy Skies,
Old Bob
AKA
Bob Siegfried
Ancient Aviator
Stearman N3977A
630 985-8503
Steve G
nico(at)cybersuperstore.c
PostPosted: Sat Jan 21, 2006 4:07 pm    Post subject: Airframe life expectancy Reply with quote
Didn't they just feed them kangeroos?
My understanding is that winglets inhibit the development of wingtip
vortices, one of the major players in drag. Am I right?
BillLeff1(at)aol.com
PostPosted: Sun Jan 22, 2006 10:20 pm    Post subject: Airframe life expectancy Reply with quote
The Commander Aero Winglet, for the 500S was a copy of the factory tip for
the 695 series. It was first put on AvFuel's Shrike. It does help low speed
roll control bit does nothing for the high end.
It was certified as "no change in performance" to save having to prove the
numbers. Flutter test were done but no high speed computer modeling was done to
my knowledge. The engineers at Wright Patterson did look at them but again,
to my knowledge, they only gave an opinion. They did think that they were
about as good as you could get without a major re design.
They do look good and in my judgment really help low speed activities like
take off, low speed roll control, maybe even single engine climb. But there is
nothing to prove it.
Oh Yeah, I did the flight test for Dick.
There are some great reports on wing life expectancy floating around, I use
to have a copy but I cant find it. It showed the fatigue life calculations for
the different models based on hours and flight profile cycles. It was really
neat. Low altitude aerial survey significantly reduced the life of the
wing. I also saw the test facility at Norman, OK where they did the cycle life
test on the 1000. As I remember they bent the wings 33 inches at the tip and
pressurized the cabin to 21 psi before the cabin door blew off! It was cool!
When I saw it, they had reached 21K hours and were still testing.
Bill Leff
PostPosted: Mon Jan 23, 2006 7:02 am    Post subject: Airframe life expectancy Reply with quote
Deneal,
Given some of the more endearing characteristics of the Nomad ( not
to be confused with the North American NA-260 Nomad, the civil
certified T-28, one R. Hoover, Esq, not entirely unknown to Aero
Commander or P-51 aficionados, project test pilot) perhaps a better
question is "Why was the Nomad certified at all". One characteristic
it shared with its North American namesake was all the performance of
a polished crowbar when it all went quiet.
You probably visited the Government Aircraft Factory at Avalon,
Victoria, the way that place worked, it was quite amazing that the
aeroplane ever got out the factory door.
Bear in mind that many of the staff , particularly design staff, at
the GAF, were refugees from the collapse of the British aircraft
industry, to say the least there was a certain prejudice against
anything from US, many of the professional engineers in (those days)
the Department of Civil Aviation were also from the same bulk store.
The fact that "a good solid aeroplane" like the DH Chipmunk has
severe aircraft life limits, (starting at 5500 hours) and for good
reasons, never dented the prejudice against spam cans , anything made
by Piper, Beech or Cessna, despite some C-172 racking up 20,000 plus
on the original structure. Note, spam here is not what you get every
time you download your email, but a particularly nasty tinned "meat"
more properly called Imperial Camp Pie, if my memory serves me
correctly. My recollection of the 'orrible stuff is very clear, even
if the name isn't.
The same prejudice was and is displayed against airline aircraft,
despite the fact that we lost a number of Vickers Viscounts from
in-flight breakups for various reasons, DH 104 Dove's didn't like
Australian air at all, all the later Tridents were withdrawn from
service due fatigue problems,and the story goes on --- but there has
been no such parallel with DC-3/4/6,
L-049/749/1049/1049G/L-177/DC-9/B707-138/338/B-747-238/338/438/SP/B-767-238/338
--- get the drift.
I worked for Qantas for many years, Qantas started international
services with a dreadful four engine bi-plane, the DH-86A. There are
none in museums, every single one crashed. The very first Qantas
aircraft was nearly lost near Cairo on the delivery, flown by a
Qantas crew. The second delivery, flown by an Imperial Airways crew,
was lost with all aboard, at Longreach, Queensland. Our major
competition, KLM, was flying Lockheed14 , DC-2 and DC-3, but the
operation of US aircraft over "Imperial Routes was banned. This did
not change until after WW11.
Folks, I hope you are not bored with all this, its not much to do
with Commanders, but you see what happens when somebody gets me
started, but at least Bob Hoover rated a mention.'
Bill Hamilton
At 02:03 22/01/2006, you wrote:
(Portege)" <deneals(at)sbcglobal.net>
Thanks, Bill.
Deneal Schilmeister
1997 SL500
PostPosted: Tue Jan 24, 2006 10:04 pm    Post subject: Airframe life expectancy Reply with quote
Nico,
The wingtip vortex causes a downflow on the wing tip which reduces lift.
To maintain the necessary lift the wing AOA has to be increased thus
increasing the wing drag. The properly designed (and tested) winglet
will minimize the downflow thus increasing the lift at the outer wing.
Thus less AOA is needed, hence lower drag. Some people look at it as an
effective increase in wing span, i.e. wing efficiency.
n395v
PostPosted: Wed Jan 25, 2006 5:46 am    Post subject: Re: Airframe life expectancy Reply with quote
Nico,
That is correct go to the link below and look at page 12 of the PDF file
http://www.commander-aero.com/image/Cat04.pdf
Interestingly it does not increase lift so should not affect fatigue life of the wing.
Milt
