Glenn Horne
Posted: Fri Aug 25, 2006 5:24 pm Post subject: Type of Aircraft |
Model II 582 Gray head
taildragger
Glenn Horne Suffolk, VA
dosmythe(at)cox.net Guest
Posted: Fri Aug 25, 2006 6:06 pm Post subject: Type of Aircraft |
Classic IV w/ 582 Gray Head. Tail Dragger
Don Smythe
iworonko(at)cox.net Guest
Posted: Fri Aug 25, 2006 6:28 pm Post subject: Type of Aircraft |
Mod. IV Speedster 912UL, tail dragger being converted to nose dragger
Eric
rliebmann(at)comcast.net Guest
Posted: Fri Aug 25, 2006 6:33 pm Post subject: Type of Aircraft |
Sent: Friday, August 25, 2006 9:29 PM
Subject: Type of Aircraft
taildragger
Ron Liebmann Near Chicago
kirkhull(at)sbcglobal.net Guest
Posted: Fri Aug 25, 2006 6:40 pm Post subject: Type of Aircraft |
How about adding your location as well?
Kirk with a classic VI powered by a stratus Subaru and located in Kansas city Missouri / 0N0
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Don Smythe
Sent: Friday, August 25, 2006 9:05 PM
Don Smythe
01234567890123
morid(at)northland.lib.mi Guest
Posted: Sat Aug 26, 2006 3:17 am Post subject: Type of Aircraft |
Deke Morisse
Series 5
NSI 100hp
CAP prop
Taildragger
Mikado Michigan
| Quote: | How about adding your location as well?
city Missouri / 0N0
_____
Don Smythe
This message was sent using IMP, the Internet Messaging Program.
Flybradair(at)cs.com Guest
Posted: Sat Aug 26, 2006 7:01 am Post subject: Type of Aircraft |
Brad Martin
Series 5 Outback
Lycoming O-235L2C 118hp
Sensenich prop
Taildragger
Wichita Kansas
46 yrs old [quote][b]
Float Flyr
Posted: Sat Aug 26, 2006 10:20 am Post subject: Type of Aircraft |
Noel Loveys
Model III-A
Tail dragger on wheels and skis..... spends most of the time on Aerocet Floats
R582 Grey head, "B" box three blade Ivo UL in flight adj
Campbellton, Newfoundland, Canada.
Noel [quote]
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
mike Guest
Posted: Sat Aug 26, 2006 10:56 am Post subject: Re: Type of Aircraft |
I have one that flies
c210rg(at)comcast.net Guest
Posted: Sun Aug 27, 2006 8:19 am Post subject: Type of Aircraft |
Jud and Clarissa Parker
Series 5
912UL Xtra
Cap 140 prop
Taildragger
Santa Clarita, California
Michael Logan
Posted: Wed Aug 30, 2006 4:05 pm Post subject: Type of Aircraft |
Series 5
EA81 140hp (RAM Performance) NSI CAP
Dogwood Airpark VA42 Fredericksburg, VA
Mike Logan
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of kirkhull
Sent: Friday, August 25, 2006 10:37 PM
Subject: RE: Type of Aircraft
Don Smythe
0123456789012
3 [quote][b]
_________________ Mike Logan
Fredericksburg, VA |
mike Guest
Posted: Thu Aug 31, 2006 6:26 am Post subject: Re: Type of Aircraft |
model IV 1200
speedster
912ul
tri gear running backwards
spokane, washington
starlaker
Posted: Thu Aug 31, 2006 10:12 am Post subject: Re: Type of Aircraft |
Classic 4
912UL
2-blade warp drive
Jefferson County, Washington
_________________ Dick D'Archangel
Classic 4 6061D |
lcfitt(at)sbcglobal.net Guest
Posted: Mon Sep 04, 2006 9:30 am Post subject: Type of Aircraft |
Did a quick count of those that posted onto the list. Results are as
follows, given present status. I will try to keep this up if the list is
interested. I may have missed some. If you think you are not listed try
again, I have the list by name on a spreadsheet.
Lowell
TD--34
NW--5
582----------11
912UL--------9
912ULX------2
912ULS------7
912A---------1
NSI-----------3
NSI-T--------1
STR-SUB----1
EA81-RAM--1
J2200--------1
L-0-235------2
C-0200-------1
KFM---------1
Lowell
Posted: Mon Sep 04, 2006 11:02 am Post subject: Type of Aircraft |
Keeping it up is a Good idea. I do believe you missed one stratus sub. I
have one and somebody ( I lost their name when my HD crashed ) was asking
questions about my problems because they have one also.
Michel
On Sep 4, 2006, at 7:29 PM, Lowell Fitt wrote:
| Quote: | Did a quick count of those that posted onto the list.
Thank you, Lowell. It looks like my poll on the Matronics forum was
more confusion than anything else. Anyway, I can report that, on the
forum, there are:
3 Rotax 582
2 Rotax 912
2 Subaru
2 Jabiru
Of course, some may have "voted" in both places so we can't just add
the two but since I didn't vote on the list, you can add a Jabiru 2200
on your list for me, please.
Michel
_________________ Kitfox 3 - Jabiru 2200 |
Posted: Mon Sep 04, 2006 11:49 am Post subject: Type of Aircraft |
Thanks Kirk, I am posting in the spreadsheet with the names to avoid dups.
If you remember his name or if he is lurking drop a note. I know of lots of
others, but will wait a while for more posts before I try the tedious task
of researching the archives.
Lowell
Guy Buchanan
Posted: Mon Sep 04, 2006 11:53 am Post subject: Type of Aircraft |
At 10:29 AM 9/4/2006, you wrote:
| Quote: | If you think you are not listed try
Lowell,
You must have missed me. K-IV 1200 with Walter M601E gas turbine.
It really goes, but unfortunately only for about 20 minutes. Then I have to
refuel.
Guy Buchanan
_________________ Guy Buchanan
Deceased K-IV 1200
A glider pilot too. |
Lynn Matteson
Lowell-
You may not have me (or Michel, or Gary) but I'm Jabiru 2200-powered,
Speedster IV, and tailwheel. I say this because of only one (1) J2200
showing, and there's probably more out there. If you already have me, I
don't want to "vote" again. : )
On second thought, maybe I listed myself on Michel's Jabiru engine list
on Yahoo (bleeah!), and not here.
Lynn
Kitfox IV Speedster...Jabiru 2200
On Monday, September 4, 2006, at 01:29 PM, Lowell Fitt wrote:
is interested. I may have missed some. If you think you are not
listed try again, I have the list by name on a spreadsheet.
Lowell
TD--34
NW--5
582----------11
912UL--------9
912ULX------2
912ULS------7
912A---------1
NSI-----------3
NSI-T--------1
STR-SUB----1
EA81-RAM--1
J2200--------1
L-0-235------2
C-0200-------1
KFM---------1
Lowell
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
ofd725(at)yahoo.com Guest
Posted: Mon Sep 04, 2006 12:15 pm Post subject: Type of Aircraft |
I would like to add my info to this interesting poll please:
KF S7
VW 2276
Tri-gear
0 TTAE
Expect airworthiness inspection around the end of Sept.
Gary
Lowell Fitt <lcfitt(at)sbcglobal.net> wrote:
[quote]--> Kitfox-List message posted by: "Lowell Fitt"
again, I have the list by name on a [url=http://us.rd.yahoo.com/evt=43256/*http://advision.webevents.yahoo.com/mailbeta] All-new Yahoo! Mail [/url]- Fire up a more powerful email and get things done faster. [quote][b]
