		PGLong
				 Posted: Sun Aug 27, 2006 1:41 pm    Post subject: Weight & Balance |
				After removing the vacuum system, pump and instruments, and adding an  autopilot, I want to re-weigh and do a weight & balance on my RV-4. Is it  feasable to top off the fuel tanks, assume a 32 gallon load and then  reverse the fuel arm and weight to arrive at the gross aircraft weight? Part of  my brain says that won't work correctly. Any thoughts?
  Pat  Long
 PGLong(at)aol.com
 N120PL
 RV4
 Bay City, Michigan
 3CM
 Do  Not Archive
  |  | - The Matronics RV-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  _________________ Pat Long
RV-4, N120PL
Bay City, MI |
		gyoung
  Joined: 09 Jan 2006 Posts: 211 Location: Republic of Texas
				 Posted: Sun Aug 27, 2006 2:07 pm    Post subject: Weight & Balance |
				Sure, it will work. The  fuel weight should be obvious but be careful the fuel moment is backed out the  correct way. Do a sanity check afterwards to see if adding fuel back in on a  pre-flight W&B using your new empty weight and CG gets you back to what  showed on the scales.
  Greg  Young
    Pat    Long
 PGLong(at)aol.com
 N120PL
 RV4
 Bay City, Michigan
 3CM
 Do    Not Archive
		ronlee(at)pcisys.net Guest
				 Posted: Sun Aug 27, 2006 2:20 pm    Post subject: Weight & Balance |
				At 03:41 PM 8/27/2006, you wrote:
   	  | Quote: | 	 		  After removing the vacuum system, pump and instruments, and adding an autopilot, I want to re-weigh and do a weight & balance on my RV-4. Is it feasable to top off the fuel tanks, assume a 32 gallon load and then reverse the fuel arm and weight to arrive at the gross aircraft weight? Part of my brain says that won't work correctly. Any thoughts?
  If you can weigh it empty then add the weight of 32 gallons at its arm, why not?
  Ron Lee
		khorton01(at)rogers.com Guest
				 Posted: Sun Aug 27, 2006 2:40 pm    Post subject: Weight & Balance |
  Pat Long
 N120PL
 RV4
 Bay City, Michigan
 3CM
 This will work, if you have already confirmed that you have 32 USG usable fuel load.  The number from Van's is only the nominal value.  Every aircraft is slightly different.
 But, if you subtract the fuel, you'll get an empty weight, not the gross weight, right?
  Kevin Horton         RV-8 (finishing kit)
 Ottawa, Canada
 http://www.kilohotel.com/rv8
		PGLong
				 Posted: Sun Aug 27, 2006 2:55 pm    Post subject: Re: Weight & Balance |
				Right, empty weight. There is just enough grey area, guess I'll wait till I'm light enough on fuel to have storage for the balance. Didn't want to do that, but it is the correct and safer way.
 Pat
RV-4, N120PL
Bay City, MI |
		dreel(at)cox.net Guest
				 Posted: Mon Aug 28, 2006 5:47 am    Post subject: Weight & Balance |
				When I reweighed my 8A, I drained the fuel tanks by pumping fuel into cans
 through a hose connected in place of the carb fuel inlet using the auxiliary
 electric fuel pump.  This insured the correct amount of unusable fuel
 remained in the tanks and eliminated the uncertainty over exactly how much
 fuel was in the tanks.  If I was off by 1 gallon, 6lb, that would translate
 into a moment of 480 for a CG position error of +/- 6 tenths of a percent in
 CG location given the empty moment of my airplane, 84575.  Not a very big
 error as errors go.  Still, it made me uncomfortable enough that I took the
 slightly harder route of emptying the tanks.
 There were two additional benefits to this approach:  I could calibrate a
 dip stick for measuring usable fuel by refilling the empty tanks in two
 gallon increments, and, by raising the gas can above the fuel tank level, I
 could look at my see through fuel filter during the pump out operation to
 see if the fuel system was sucking any air.
 Dave Reel - RV8A
		denis.walsh(at)comcast.ne Guest
				 Posted: Mon Aug 28, 2006 6:03 am    Post subject: Weight & Balance |
				An excellent tip.  Thank you.
 Such sharing of good building tips is becoming very rare on this
 list, so forgive me for further clogging it.
 No not archive.
 Denis Walsh
 On Aug 28, 2006, at 07:49 281700008, DAVID REEL wrote:
  into cans
  auxiliary
  how much
  translate
  percent in
  very big
  took the
  calibrate a
  two
  level, I
  operation to
  Dave Reel - RV8A
