VOR antenna
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV9-List
wowens(at)darientel.net
PostPosted: Tue Aug 29, 2006 5:17 am    Post subject: VOR antenna Reply with quote
Where are folks installing Vor antennas?
Wayne Owens new builder Georgia coast
- The Matronics RV9-List Email Forum -
http://www.matronics.com/Navigator?RV9-List
rmkeith(at)gwi.net
PostPosted: Sun Sep 03, 2006 4:08 am    Post subject: Vor Antenna Reply with quote
Wayne,
I installed an Omni antenna on the top of the vertical stabilizer. I an still in the building process so I cant comment on how well it works. I got mine from Wag-Aero part number C-173-000. The mounting block is a tapered block of plastic and is tapered to fit the general shape of the fiberglass cap of the VS. I have mine with the antennas pointing forward because of interference with the rudder counterweight. I have some pictures if you like.
Russ Keith
RV9A slow build
rv9a(at)gwi.net (rv9a(at)gwi.net)
(Rv9a(at)gwi.net)
PFolbrecht(at)starkinvest
PostPosted: Tue Sep 05, 2006 12:24 pm    Post subject: Vor Antenna Reply with quote
Where did you run the wire? Thru the VS?
From: owner-rv9-list-server(at)matronics.com [mailto:owner-rv9-list-server(at)matronics.com] On Behalf Of Russ & Marilyn
Sent: Sunday, September 03, 2006 7:06 AM
To: rv9-list(at)matronics.com
Subject: Re:Vor Antenna
Wayne,
Russ Keith
RV9A slow build
(Rv9a(at)gwi.net)
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV9-List All times are GMT - 8 Hours
