Van's Wheel Fairings
n184da(at)volcano.net
PostPosted: Tue Aug 29, 2006 6:45 am    Post subject: Van's Wheel Fairings Reply with quote
I am replacing (finally!) my original, old style wheel fairings, for Van's "new" Pressure Recovery fairings.Any ideas on what works best for a minimal tire-to-faring clearance around the lower opening?
Derrick L. Aubuchon
RV-4: N184DA (450+ hrs)
Jackson/Westover -Amador County (O70)
n184da(at)volcano.net (n184da(at)volcano.net)
dan(at)rvproject.com
PostPosted: Tue Aug 29, 2006 7:23 am    Post subject: Van's Wheel Fairings Reply with quote
Fingertip width clearance imho. Your finger may vary... Wink
)_( Dan
RV-7 N714D
http://www.rvproject.com
truflite(at)yahoo.com
PostPosted: Tue Aug 29, 2006 9:38 am    Post subject: Van's Wheel Fairings Reply with quote
Pardon my ignorance, but what is a pressure recovery
wheel pant as opposed to a regurlar wheel pant?
Dave Nellis
N416DN (Res.)
7A Emp
--- Dan Checkoway <dan(at)rvproject.com> wrote:
[quote] Fingertip width clearance imho. Your finger may
vary... Wink
)_( Dan
RV-7 N714D
Dale Ensing
PostPosted: Tue Aug 29, 2006 10:01 am    Post subject: Van's Wheel Fairings Reply with quote
They have more rounded sides, front to back, with a taber toward the rear
that sort of reverses or becomes neutral at the trailing edge vs. the older
fairing which had more flat sides. Van made change in about 2000. New one
supposed to have less drag.
Dale Ensing
Dale Ensing
RV-6A
Aero Plantation
Weddington NC
ronlee(at)pcisys.net
PostPosted: Tue Aug 29, 2006 10:28 am    Post subject: Van's Wheel Fairings Reply with quote
The old style are narrower. I doubt that you need to worry about
having the old style.
Ron Lee
c.ennis(at)insightbb.com
PostPosted: Tue Aug 29, 2006 12:13 pm    Post subject: Van's Wheel Fairings Reply with quote
Derrick,
If you expect to fly from only asphalt and never have a tire low on pressure..a 1/4 inch around is enough.
If on the other hand you will be flying in the real world, 5/8 inch is the minimum side clearance I could stand. Front and rear of the tread I use 1 inch which allows most of the grass I pick up from my home field to exit without excessive buildup. Yes, I did start with 1/4 inch all around and increased the clearance from there.
Your results may vary. Wink
Charlie Ennis N60CE
lsbrv7a(at)yahoo.com
PostPosted: Tue Aug 29, 2006 12:24 pm    Post subject: Van's Wheel Fairings Reply with quote
I understand there is a high pressure area formed on the trailing portion of this shape that in effect recovers some of the pressure required to push the leading edge through the air.
I heard a story of a blimp with this shape collapsed the aft portion of the blimp when sufficient speed and recoverd pressure was obtained.
Dave Nellis <truflite(at)yahoo.com> wrote:
--> RV-List message posted by: Dave Nellis
Sherman Butler
RV-7a Wings
Idaho Falls
Get your own [url= http://us.rd.yahoo.com/evt=43290/*http://smallbusiness.yahoo.com/domains]web address for just $1.99/1st yr[/url]. We'll help.
martin(at)gbonline.com
PostPosted: Tue Aug 29, 2006 6:14 pm    Post subject: Van's Wheel Fairings Reply with quote
Derrick,
When I built my RV8 in 1999, I experimented with several wheelpant and tire variations. My objective was to obtain the most speed and the least drag possible. I found out that when I used any of the various cheap tires, I needed at least a 1/2 inch clearance around the tire casing, because when landing etc. the cheap tires would expand and rub the wheelpant. I solved the problem by installing Goodyear Custom III tires and tubes. The Custom III series has a much stiffer tred and side casing and holds its shape even with a hard landing. Note: the lower (closer to ground) you install the wheel pant, the faster you will go.
I tried Vans pressure recovery pants first and then went to Sam James pressure recovery pants because they went faster and looked better.
Good luck with your project.
Dick Martin
RV8 N233M
the fast one
1350 hours - it gets better every day
chaztuna(at)adelphia.net
PostPosted: Wed Aug 30, 2006 4:08 am    Post subject: Van's Wheel Fairings Reply with quote
Dick
Two questions.
Can you recommend any other name brand tires besides Goodyear?
What speed gain did you see by using the Sam James wheel pants?
Charlie Kuss
[quote]Derrick,
Dick Martin
RV8 N233M
the fast one
Jerry Grimmonpre'
PostPosted: Wed Aug 30, 2006 5:49 am    Post subject: Van's Wheel Fairings Reply with quote
Does anyone know the difference between Goodyear Custom III tires and the earlier Custom II tires?
Many thanks ....
Jerry Grimmonpre'
tcervin(at)valkyrie.net
PostPosted: Wed Aug 30, 2006 4:10 pm    Post subject: Van's Wheel Fairings Reply with quote
I have Goodyear Custom II tires and they also maintain their shape.....stiff well made sidewalls.
                  Tom in Ohio RV6-A
PostPosted: Sat Sep 02, 2006 6:23 pm    Post subject: Van's Wheel Fairings Reply with quote
Charlie,
I used Goodyear because at the time they were readily available to me. I have not kept up with the airplane tire market, so I cannot recommend any other brand. I will say, however, that the performance and service life on my RV8 with the Goodyear Custom III has been excellent.
As near as I can tell, I gained about 5 knots with the Sam James wheel pants. I flight tested both pants and the James pants are faster.
Dick Martin
RV8 N233M
the fast one
Doug Gray
PostPosted: Sat Sep 02, 2006 9:06 pm    Post subject: Van's Wheel Fairings Reply with quote
Gained 5 knots against which wheel pants from Vans? PR or the earlier
boxy ones.
On Sat, 2006-09-02 at 21:21 -0500, dick martin wrote:
Charlie,
excellent.
Dick Martin
RV8 N233M
PostPosted: Sun Sep 03, 2006 5:42 pm    Post subject: Van's Wheel Fairings Reply with quote
I had Vans later style round profile "pressure recovery" wheel pants, not
the old style
Dick Martin
RV8 N233M
the fast one
FLYaDIVE(at)aol.com
PostPosted: Sun Sep 17, 2006 3:55 am    Post subject: Van's Wheel Fairings Reply with quote
In a message dated 8/29/06 10:16:43 PM Eastern Daylight Time,
martin(at)gbonline.com writes:
Dick Martin
RV8 N233M
Dick:
I can understand the looking better part. But, how much faster and how did
you determine that?
Barry
"Chop'd Liver"
PostPosted: Mon Sep 18, 2006 5:55 pm    Post subject: Van's Wheel Fairings Reply with quote
Barry,
I had Vans pants installed and flying first. I fitted Sam James pants and
flew them. Inorder to determine the performance, which appeared to be
faster, I reinstalled Vans pants and flew them and then removed them and
flew the Sam James pants an hour later. The James pants were approx 5 knot
faster +/- l knot..
Dick Martin
RV8 N233M
the fast one
